標題: 單片機24C02的讀寫程序搞了兩天了,還是搞不定,有大佬幫忙看看的嗎? [打印本頁]
作者: Coolguyisme    時間: 2020-11-18 19:28
本想做個外部存儲,就是24C02程序搞了一段時間,始終無法寫進和讀出數據·····實在不知道哪里有問題,看到上網上很多版本,改來改去都沒用······
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. #define ulong unsigned long
  5. sbit sda=P3^3;
  6. sbit scl=P3^2;
  7. sbit s=P2^3;
  8. sbit b=P2^4;
  9. sbit d=P2^5;
  10. uchar i;
  11. uchar array1[]={0xF0,0x01,0x00,0x01,0x00,0x01,0x00,0x01};
  12. uchar array2[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  13. void delay(uint z)
  14. {
  15.         uint x,y;
  16.         for(x=z;x>0;x--)
  17.                 for(y=110;y>0;y--);
  18. }
  19. void start()//kaishi
  20. {
  21.         sda=1;
  22.         delay(10);
  23.         scl=1;
  24.         delay(50);
  25.         sda=0;
  26.         delay(50);
  27.               scl=0;
  28.               delay(20);
  29. }
  30. void stop()//tingzhi
  31. {
  32.         sda=0;
  33.         delay(10);
  34.         scl=1;
  35.         delay(50);
  36.         sda=1;
  37.         delay(40);
  38. }
  39. void respons()//yingda
  40. {
  41.         uchar i;
  42.         scl=1;
  43.         delay(10);
  44.         while((sda==1)&&(i<250))
  45.         i++;
  46.         scl=0;
  47.         delay(10);
  48. }
  49. void init()//chushihua
  50. {
  51.         sda=1;
  52.         delay(10);
  53.         scl=1;
  54.         delay(10);
  55. }
  56. void write_byte(uchar date)//xiezijie
  57. {
  58.         uchar i,temp;
  59.         temp=date;
  60.         for(i=0;i<8;i++)
  61.         {
  62.                 temp=temp<<1;
  63.                 scl=0;
  64.                 delay(10);
  65.                 sda=CY;
  66.                 delay(10);
  67.                 scl=1;
  68.                 delay(10);
  69.         }
  70.         scl=0;
  71.         delay(10);
  72.         sda=1;
  73.         delay(10);
  74. }
  75. uchar read_byte()//duzijie
  76. {
  77.         uchar i,k;
  78.         scl=0;
  79.         delay(10);
  80.         sda=1;
  81.         delay(10);
  82.         for(i=0;i<8;i++)
  83.         {
  84.                 scl=1;
  85.                 delay(10);
  86.                 k=(k<<1)|sda;
  87.                 scl=0;
  88.                 delay(10);
  89.         }
  90.         return k;
  91. }
  92. void write_add(uchar address,uchar date)
  93. {
  94.                 init();
  95.                 start();
  96.         write_byte(0xa0);
  97.         respons();
  98.         write_byte(address);
  99.         respons();
  100.
  101.         write_byte(date);
  102.         respons();
  103.         stop();
  104.
  105. }
  106. uchar read_add(uchar address)
  107. {
  108.         uchar date;
  109.         init();
  110.                 start();
  111.         write_byte(0xa0);
  112.         respons();
  113.         write_byte(address);
  114.         respons();
  115.         start();
  116.         write_byte(0xa1);
  117.         respons();
  118.         date=read_byte();
  119.         stop();
  120.         return date;
  121. }
  122. void writearray() //D′èëêy×é
  123. {
  124. uchar i=0;
  125. while(1)
  126. {
  127. write_add(i,array1[i]); //½«êy×éarray1ÖDμÄêy′óμØÖ·¡°0¡±òà′ÎD′èë′æ′¢Çø
  128. i++;
  129. if(i==8)
  130. break;
  131. }
  132. }
  133. void readarray()
  134. {
  135. uchar i=0;
  136. while(1)
  137. {
  138. array2[i]=read_add(i);
  139. i++;
  140. if(i==8)
  141. break;
  142. }
  143. }
  144. void main()
  145. {
  146.     //uchar j;
  147.                 init();
  148.           write_add(0x00,array1[0]);
  149.                 read_add(0x00);
  150.     while(1)
  151.                 {
  152.                 P1=array2[0];
  153.                 }
  154. }
作者: 0711zhao    時間: 2020-11-18 20:17
#include "i2c.h"
#include "intrins.h"
void i2c_delay(void)
        _nop_();_nop_();_nop_();_nop_();_nop_();
void i2c_start(void)
        SCL=1;
        SDA=1;
        i2c_delay();
        SDA=0;
        i2c_delay();
        SCL=0;
        i2c_delay();
void i2c_stop(void)
        SCL=1;
        SDA=0;
        i2c_delay();
        SDA=1;
        i2c_delay();
//主機應答從機
void send_ACK(bit ack)
        SCL=0;
        i2c_delay();
        if(ack==ACK)
                SDA=0;
    i2c_delay();
                SDA=1;
    i2c_delay();
        SCL=1;
        i2c_delay();
        SCL=0;
//主機檢查從機
bit check_ACK(void)
        bit ack;
        SCL=0;
        i2c_delay();
        SCL=1;
        _nop_();_nop_();
        if(SDA)
                ack=NACK;
                ack=ACK;
        _nop_();_nop_();
        SCL=0;
        return(ack);
//發送數據,寫
void i2c_send_byte(uint8 dat)
        uint8 i;
        for(i=0;i<8;i++)
                SCL=0;
        i2c_delay();
                if(dat&0x80)
                        SDA=1;
                        SDA=0;
                i2c_delay();
                SCL=1;
                dat=dat<<1;
//接收數據,讀
uint8 i2c_read_byte(void)
        uint8 i,temp;
        for(i=0;i<8;i++)
                SCL=0;
                i2c_delay();
                SCL=1;
          temp<<=1;
                if(SDA)
                        temp|=0x01;
    i2c_delay();
                SCL=0;     //感覺應要拉低
        return(temp);
作者: 0711zhao    時間: 2020-11-18 20:19
#include <reg52.h>
#include <intrins.h>
#include "24c02.h"
#define  NOP()   _nop_()   /* 定義空指令 */
#define  _Nop()  _nop_()   /*定義空指令*/
sbit     SCL=P2^0;     //I2C  時鐘
sbit     SDA=P2^1;     //I2C  數據 普中定義
bit ack;                 /*應答標志位*/
//AT2402的功能函數
                    向有子地址器件發送多字節數據函數
函數原型: bit  ISendStr(UCHAR sla,UCHAR suba,ucahr *s,UCHAR no);
功能:     從啟動總線到發送地址,子地址,數據,結束總線的全過程,從器件
          地址sla,子地址suba,發送內容是s指向的內容,發送no個字節。
          如果返回1表示操作成功,否則操作有誤。
注意:    使用前必須已結束總線。
bit ISendStr(unsigned char  sla,unsigned char  suba,unsigned char  *s,unsigned char  no)
   unsigned char i;
   Start_I2c();               /*啟動總線*/
   SendByte(sla);             /*發送器件地址*/
   if(ack==0)return(0);
   SendByte(suba);            /*發送器件子地址*/
   for(i=0;i<no;i++)
     SendByte(*s);            /*發送數據*/
     s++;
   Stop_I2c();                /*結束總線*/
   return(1);
                    向有子地址器件讀取多字節數據函數
函數原型: bit  RecndStr(UCHAR sla,UCHAR suba,ucahr *s,UCHAR no);
功能:     從啟動總線到發送地址,子地址,讀數據,結束總線的全過程,從器件
          地址sla,子地址suba,讀出的內容放入s指向的存儲區,讀no個字節。
           如果返回1表示操作成功,否則操作有誤。
注意:    使用前必須已結束總線。
bit IRcvStr(unsigned char  sla,unsigned char  suba,unsigned char  *s,unsigned char  no)
   unsigned char i;
   Start_I2c();                 /*重新啟動總線*/
   SendByte(sla+1);
   for(i=0;i<no-1;i++)
     *s=RcvByte();               /*發送數據*/
      Ack_I2c(0);                /*發送就答位*/
     s++;
   *s=RcvByte();
   Ack_I2c(1);                   /*發送非應位*/
   return(1);
                     起動總線函數
函數原型: void  Start_I2c();
功能:     啟動I2C總線,即發送I2C起始條件.
void Start_I2c()
  SDA=1;         /*發送起始條件的數據信號*/
  _Nop();
  SCL=1;
  _Nop();        /*起始條件建立時間大于4.7us,延時*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SDA=0;         /*發送起始信號*/
  _Nop();        /* 起始條件鎖定時間大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SCL=0;       /*鉗住I2C總線,準備發送或接收數據 */
  _Nop();
  _Nop();
                      結束總線函數
函數原型: void  Stop_I2c();
功能:     結束I2C總線,即發送I2C結束條件.
void Stop_I2c()
  SDA=0;      /*發送結束條件的數據信號*/
  _Nop();       /*發送結束條件的時鐘信號*/
  SCL=1;      /*結束條件建立時間大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SDA=1;      /*發送I2C總線結束信號*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
                 字節數據發送函數
函數原型: void  SendByte(UCHAR c);
功能:     將數據c發送出去,可以是地址,也可以是數據,發完后等待應答,并對
          此狀態位進行操作.(不應答或非應答都使ack=0)
           發送數據正常,ack=1; ack=0表示被控器無應答或損壞。
void  SendByte(unsigned char  c)
unsigned char  BitCnt;
for(BitCnt=0;BitCnt<8;BitCnt++)  /*要傳送的數據長度為8位*/
     if((c<<BitCnt)&0x80)SDA=1;   /*判斷發送位*/
       else  SDA=0;
     _Nop();
     SCL=1;               /*置時鐘線為高,通知被控器開始接收數據位*/
      _Nop();
      _Nop();             /*保證時鐘高電平周期大于4μs*/
      _Nop();
      _Nop();
      _Nop();
     SCL=0;
    _Nop();
    _Nop();
    SDA=1;                /*8位發送完后釋放數據線,準備接收應答位*/
    _Nop();
    _Nop();
    SCL=1;
    _Nop();
    _Nop();
    _Nop();
    if(SDA==1)ack=0;
       else ack=1;        /*判斷是否接收到應答信號*/
    SCL=0;
    _Nop();
    _Nop();
                 字節數據接收函數
函數原型: UCHAR  RcvByte();
功能:        用來接收從器件傳來的數據,并判斷總線錯誤(不發應答信號),
          發完后請用應答函數應答從機。
unsigned char   RcvByte()
  unsigned char  retc;
  retc=0;
  SDA=1;                       /*置數據線為輸入方式*/
        _Nop();
        SCL=0;                  /*置時鐘線為低,準備接收數據位*/
        _Nop();
        _Nop();                 /*時鐘低電平周期大于4.7μs*/
        _Nop();
        _Nop();
        _Nop();
        SCL=1;                  /*置時鐘線為高使數據線上數據有效*/
        _Nop();
        _Nop();
        retc=retc<<1;
        if(SDA==1)retc=retc+1;  /*讀數據位,接收的數據位放入retc中 */
        _Nop();
        _Nop();
  SCL=0;
  _Nop();
  _Nop();
  return(retc);
                     應答子函數
函數原型:  void Ack_I2c(bit a);
功能:      主控器進行應答信號(可以是應答或非應答信號,由位參數a決定)
void Ack_I2c(bit a)
  if(a==0)SDA=0;              /*在此發出應答或非應答信號 */
  else SDA=1;
  _Nop();
  _Nop();
  _Nop();
  SCL=1;
  _Nop();
  _Nop();                    /*時鐘低電平周期大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  SCL=0;                     /*清時鐘線,鉗住I2C總線以便繼續接收*/
  _Nop();
  _Nop();
你參考我這個源碼看看,我這是可以用的
作者: epson009    時間: 2020-11-19 01:26
你說的無法讀寫的問題可以按以下兩步解決:
1.修改delay(),我感覺你的delay()延時太長了。可試試
    void delay()
  這個應該可以解決無法寫的問題。
2.在 write_add(0x00,array1[0]);
                read_add(0x00);
之間加延時,也就是寫完數據后稍等一會再進行讀操作。如:
              write_add(0x00,array1[0]);              for(i=100;i>0;i--)
                   for(j=100;j>0;j--)
              read_add(0x00);
這個應該可以解決無法讀的問題。
附圖:
作者: Y_G_G    時間: 2020-11-19 08:29
樓上有人說是延時太長,這個應該不會的
24C02對延時好像只有最短要求,但對最長并沒有規定,我之前調試的時候是1秒鐘一個時鐘,那都是可以正常讀寫的
個人感覺應該是在下面的這個應答函數里面,你不覺得while循環下面的三個語句應該加一個{}嗎?,你這個應該只查詢了250次,很有可能還沒有寫入完成就退出了等待應答函數了
作者: chenyinhu    時間: 2020-11-19 08:48
如果參考的網上的代碼也不一定就是時序問題,可能就是簡單的引腳定義不一致導致的
作者: wulin    時間: 2020-11-19 14:10
樓主調試失敗有兩個原因。1.延時函數錯誤,2驗證方式錯誤。其它代碼沒有問題。修改后經仿真驗證無誤:
void delay(uint z)//大致延時長度 T=z*2+5 us
        while(--z);
        P1=array2[0]; //顯示原來數據
        delay(0xffff);//延長顯示時間
        write_add(0x00,array1[0]);//寫EEPROM
        array2[0]=read_add(0x00);//讀EEPROM并保存
        P1=array2[0]; //顯示保存的數據
        while(1);
作者: ty417502873    時間: 2020-11-19 17:36
epson009 發表于 2020-11-19 01:26
1.修改delay(),我感覺你的delay()延時太長了?稍囋
    vo ...
請問這是什么軟件操作的?
作者: 黑色風信子    時間: 2020-11-20 09:16
建議對照I2C時序圖檢查一下程序細節,確保基礎的I2C通信沒問題;再對照24C02數據手冊查看命令是否正確
作者: 老馬工作室    時間: 2020-11-20 18:38
I2C總線上,接上拉電阻了嗎?不接上拉不行的。
作者: 昆明路口賣提莫    時間: 2020-11-21 16:31
剛寫完是不能去讀取的,最好加一段小延時,這個我以前也是這樣
作者: Coolguyisme    時間: 2020-12-30 13:36
    vo ...
謝謝  之前忙 沒看帖  現在搞好了
作者: Coolguyisme    時間: 2020-12-30 13:37
謝謝大家    之前忙 沒看帖  現在搞好了
作者: cheney03    時間: 2020-12-30 22:32
Coolguyisme 發表于 2020-12-30 13:37
謝謝大家    之前忙 沒看帖  現在搞好了
什么問題,怎么解決的,說一下,后來人好參考。
作者: 人人學會單片機    時間: 2020-12-31 11:40
void IIC_Delay()
void IIC_Init()
        P2M0&=0x3f;
        P2M1&=0x3f;
        SDA_GPIO=1;
        SCL_GPIO=1;
void IIC_Start()//IIC啟動信號
        SDA_GPIO=1;
        SCL_GPIO=1;
        IIC_Delay();
        SDA_GPIO=0;
        IIC_Delay();
        SCL_GPIO=0;
        IIC_Delay();
void IIC_Stop()//IIC停止信號
        SDA_GPIO=0;
        SCL_GPIO=1;
        SDA_GPIO=1;
        IIC_Delay();
void IIC_Write_Byte(u8 IIC_Byte)//向總線發送一個字節
        u8 i;
        SCL_GPIO=0;
        SDA_GPIO=1;
        for(i=0;i<8;i++)
                SDA_GPIO=(bit)(IIC_Byte&0x80);
                IIC_Byte<<=1;
                IIC_Delay();
                SCL_GPIO=1;
                IIC_Delay();
                SCL_GPIO=0;
                IIC_Delay();
u8 IIC_Read_Byte()
        u8 i,Value;
        SCL_GPIO=0;
        SDA_GPIO=1;
        for(i=0;i<8;i++)
                Value=(Value<<1)|SDA_GPIO;
                IIC_Delay();
                SCL_GPIO=1;
                IIC_Delay();
                SCL_GPIO=0;
                IIC_Delay();
        return Value;
u8 IIC_Read_Ack()//單片機檢測IIC從機發來的應答信號
        u8 ack=1,i=0;
        SCL_GPIO=1;
        IIC_Delay();
        while((ack)&&(i<5))
                ack=SDA_GPIO;
                i++;
        SCL_GPIO=0;
        return ack;
void IIC_Write_Ack(bit ack)//單片機發送應答給從機
        SDA_GPIO=ack;
        IIC_Delay();
        SCL_GPIO=1;
        IIC_Delay();
        SCL_GPIO=0;
        IIC_Delay();
        SDA_GPIO=1;
        IIC_Delay();
IIC代碼 用我這個
作者: Coolguyisme    時間: 2021-1-4 20:10
cheney03 發表于 2020-12-30 22:32
我直接重新參考了另外一段程序,之前的那個好像是函數的聲明順序錯了  具體那個有問題  我也忘了額·····
作者: Coolguyisme    時間: 2021-1-4 20:15
我后來直接用了另一段程序,當時心切,就沒有過多的對比··· 現在在搞AS608的程序,感覺指紋的程序也不怎么好搞····· 謝謝 大家的積極回復!
C文件:
#include "delay.h"
#include "reg52.h"
#include "function.h"
#include "24c02.h"
#include "key.h"
#include "control.h"
#include "1602.h"
#include "time.h"
sbit sda=P3^3;
sbit scl=P3^2;
uchar mima2[]={0,0,0,0,0,0,0,0};
void delay1()
void AT24c02_init()         //初始化
        sda=1;
        scl=1;
        delay1();
void start()        //開始信號
        sda=1;
delay1();
        scl=1;
        delay1();
        sda=0;
        delay1();
void stop()       //停止信號
        sda=0;
        delay1();
        scl=1;
        delay1();
        sda=1;
        delay1();
void respons()     //應答信號
        uchar i;
        scl=1;
        delay1();
        while((sda==1)&&(i<255))i++;
        scl=0;
        delay1();
void write_byte(uchar date)    //寫一個字節
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                scl=0;
                delay1();
                temp<<=1;
                sda=CY;
                delay1();
                scl=1;
                delay1();
        scl=0;
        delay1();
        sda=1;
        delay1();
uchar read_byte(void)     //讀一個字節
        uchar f,e;
        scl=0;
        delay1();
        sda=1;
        delay1();
        for(f=0;f<8;f++)     /*循環8次讀出一個字節數據*/
                scl=1;
                delay1();
                e=(e<<1)|sda;
                scl=0;
                delay1();
        return e;
{                        //指定地址寫數據
        start();                               /*初始信號*/
        write_byte(0xa0);                      /*寫入芯片地址0XA0*/
        respons();                             /*應答信號*/
        write_byte(address);                   /*寫入芯片內部寄存器地址ADDRESS*/
        respons();                             /*應答信號*/
        write_byte(date);                      /*寫入數據*/
        respons();                             /*應答信號*/
        stop();                                /*停止信號*/
        uchar date;
        start();                              /*初始信號*/
        respons();                            /*應答信號*/
        respons();                            /*應答信號*/
        start();                              /*初始信號*/
        write_byte(0xa1);                     /*初始信號*/
        respons();                            /*寫入芯片地址0XA1(讀)*/
        date=read_byte();                     /*讀出數據*/
        stop();                               /*停止信號*/
        return date;                          /*返回讀出值*/
void Ingest_code()                //寫入密碼
uchar i=0;
T1_NUM=0;
p=0;
d=0;
TR1=0;
AT24c02_init();
for(i=0;i<8;i++)
write_add(i,mima1[i]);
mima2[i]=mima1[i];                         //修改本地密碼
xianshi10();
xianshi5();
TR1=1;
void Ingest_code1()                  //讀取密碼
uchar i=0;
blue();
TR1=0;
T1_NUM=0;
p=0;
d=0;
AT24c02_init();
for(i=0;i<8;i++)
mima2[i]=read_add(i);
xianshi10();
xianshi5();
TR1=1;
/*void Ingest_code2()
uchar i=0;
AT24c02_init();
for(i=0;i<8;i++)
write_add(i,0);
blue();
xianshi10();
xianshi5();
TR1=0;
T1_NUM=0;
p=0;
d=0;
TR1=1;
H文件:
#ifndef __24C02_H__
#define __24C02_H__
extern void delay1();
extern void AT24c02_init();
extern void start();
extern void stop();
extern void respons();
extern void write_byte(uchar date);
extern uchar read_byte(void);
extern void write_add(uchar address,uchar date);
extern uchar read_add(uchar address);
extern void Ingest_code();
extern void Ingest_code1();
extern uchar mima2[8];
#endif
作者: Coolguyisme    時間: 2021-1-4 20:18
    vo ...
好像就是這個問題
