標題: 51單片機驅動16x64點陣的問題希望各位朋友幫我解答一下 [打印本頁]
作者: YZYNULL    時間: 2020-11-3 18:36
我這個程序只要加入一些延時比如_nop_和for(i=10;i>0;i--)就會造成點陣的閃爍原因不知采用16個74HC595進行驅動
還有我想加入左移功能怎么實現?希望各位幫幫小白我
本程序使用keil4編譯,仿真為protues8.6
單片機程序和仿真都在我的附件里方便查看,謝謝各位了(^v^)
16x64點陣.rar (142.86 KB, 下載次數: 13)
  1. /*----------------------------------------------------------------------------------*/
  2. #include<reg51.h>
  3. #include<intrins.h>
  4. #define uint unsigned int
  5. #define uhar unsigned char
  6. sbit HC595_SH=P2^0;  //數據鎖存端
  7. sbit HC595_DS=P2^1;  //數據輸出端
  8. sbit HC595_ST=P2^2  ;//并行輸出端
  9. uhar Mould[8];                  //位寄存
  10. uhar Upright[8];                  //段寄存
  11. uint code LED[4][32]= //4字數組
  12. {{
  13. 0x20,0x18,0x0A,0xAA,0xAA,0xAA,0x0A,0xFE,0x0A,0xAA,0xAA,0xAA,0x0A,0x28,0x18,0x00,
  14. 0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0xFE,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
  15. },
  16. {
  17. 0x10,0x0C,0x05,0x55,0x55,0x55,0x05,0x7F,0x05,0x55,0x55,0x55,0x85,0x14,0x0C,0x00,
  18. 0x00,0x91,0xA9,0x4D,0xAB,0x99,0xA0,0xAA,0xAA,0xAA,0xBF,0xA9,0xA9,0xA9,0xA0,0x00,
  19. },
  20. {
  21. 0x00,0xFC,0x04,0x04,0xFC,0x01,0xFD,0x55,0x57,0x55,0x55,0x55,0xFD,0x01,0x00,0x00,
  22. 0x00,0x0F,0x04,0x04,0x8F,0x88,0x89,0x4F,0x59,0x25,0x65,0x57,0x85,0x84,0xE0,0x00,
  23. },
  24. {
  25. 0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0xFE,0x00,0x00,0x00,
  26. 0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x41,0x40,0x78,0x00,
  27. }
  28. };
  29. /*----------------------------------------------------------------------------------*/
  30. void HC595_write()  //數據輸出
  31. {
  32.         uhar i,j;
  33.         HC595_SH=1;
  34.         HC595_DS=1;
  35.         HC595_ST=1;
  36.         for(j=4;j>0;j--)
  37.         {
  38.                 for(i=0;i<8;i++)
  39.                 {
  40.                         HC595_SH=0;
  41.                         HC595_DS=Mould[j*2-2]&0x80;
  42.                         Mould[j*2-2]<<=1;
  43.                         HC595_SH=1;
  44.                 }
  45.                 for(i=0;i<8;i++)
  46.                 {
  47.                         HC595_SH=0;
  48.                         HC595_DS=Mould[j*2-1]&0x80;
  49.                         Mould[j*2-1]<<=1;
  50.                         HC595_SH=1;
  51.                 }
  52.                 for(i=0;i<8;i++)
  53.                 {
  54.                         HC595_SH=0;
  55.                         HC595_DS=Upright[j*2-1]&0x80;
  56.                         Upright[j*2-1]<<=1;
  57.                         HC595_SH=1;
  58.                 }
  59.                 for(i=0;i<8;i++)
  60.                 {
  61.                         HC595_SH=0;
  62.                         HC595_DS=Upright[j*2-2]&0x80;
  63.                         Upright[j*2-2]<<=1;
  64.                         HC595_SH=1;
  65.                 }
  66.         }
  67.         HC595_ST=0;
  68.         HC595_ST=1;
  69. }
  70. /*----------------------------------------------------------------------------------*/
  71. void LED_DISPLAY()  //選擇數據
  72. {
  73.         static uint i;
  74.         static uint k=0x0001;
  75.
  76.         Mould[6]=~k/256;
  77.         Mould[7]=~k%256;
  78.         Upright[6]=LED[3][ i];[ i]
  79.         Upright[7]=LED[3][i+16];
  80.
  81.         Mould[4]=~k/256;
  82.         Mould[5]=~k%256;
  83.         Upright[4]=LED[2][ i];[ i]
  84.         Upright[5]=LED[2][i+16];
  85.
  86.         Mould[2]=~k/256;
  87.         Mould[3]=~k%256;
  88.         Upright[2]=LED[1][ i];[ i]
  89.         Upright[3]=LED[1][i+16];
  90.
  91.         Mould[0]=~k/256;
  92.         Mould[1]=~k%256;
  93.         Upright[0]=LED[0][ i];[ i]
  94.         Upright[1]=LED[0][i+16];
  95.
  96.         k=_irol_(k,1);
  97.         HC595_write();
  98.         i++;
  99.         if(i==16)
  100.         {
  101.                 i=0;
  102.         }
  103. }
  104. /*----------------------------------------------------------------------------------*/
  105. void main()
  106. {
  107.         while(1)
  108.         {
  109.                 while(1)
  110.                 {
  111.                         LED_DISPLAY();
  112.                 }
  113.         }
  114. }
  115. /*----------------------------------------------------------------------------------*/
