簡易51單片機跑馬燈,含源碼、仿真原理圖
吃魚的木
2020-10-27 15:59
可供初學(xué)者學(xué)習(xí),代碼清晰易懂,八個按鈕,四個不同跑馬燈形式,四個調(diào)節(jié)頻率。
(38.64 KB, 下載次數(shù): 110)
2020-10-27 15:57 上傳
#include"reg51.h"
code unsigned char leddat1[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
code unsigned char leddat2[]={0x01,0x80,0x02,0x40,0x04,0x20,0x08,0x10};
code unsigned char leddat3[]={0x01,0x02,0x04,0x08,0x80,0x40,0x20,0x10};
code unsigned char leddat4[50]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x81,0x82,
0x84,0x88,0x90,0xA0,0xC0,0xC1,0xC2,0xC4,0xC8,0xD0,
0xE0,0xE1,0xE2,0xE4,0xE8,0xF0,0xF1,0xF2,0xF4,0xF8,
0xF9,0xFA,0xFC,0xFD,0xFE,0xFF,0xFF,0x00,0xFF,0x00};
void delay(unsigned int n)
unsigned int i=0,j=0;
for(i=0;i<n;i++)
for(j=0;j<120;j++);
void led1()
int i=0;
for(i=0;i<8;i++)
P2=~leddat1[i];
delay(400);
void led2()
int i=0;
for(i=0;i<8;i++)
P2=~leddat2[i];
delay(400);
void led3()
int i=0;
for(i=0;i<8;i++)
P2=~leddat3[i];
delay(400);
void led4()
int i=0;
for(i=0;i<50;i++)
P2=~leddat4[i];
delay(400);
void ledF1()
int i=0;
for(i=0;i<8;i++)
P2=~leddat1[i];
delay(100);
void ledF2()
int i=0;
for(i=0;i<8;i++)
P2=~leddat1[i];
delay(400);
void ledF3()
int i=0;
for(i=0;i<8;i++)
P2=~leddat1[i];
delay(1000);
void ledF4()
int i=0;
for(i=0;i<8;i++)
P2=~leddat1[i];
delay(2000);
if(P1==~0x01)
{led1();}
if(P1==~0x02)
{led2();}
if(P1==~0x04)
{led3();}
if(P1==~0x08)
{led4();}
if(P1==~0x10)
{ledF1();}
if(P1==~0x20)
{ledF2();}
if(P1==~0x40)
{ledF3();}
if(P1==~0x80)
{ledF4();}
MCS-51單片機完成頻率、花色可調(diào)的跑馬燈.zip
(51.08 KB, 下載次數(shù): 41)
2020-10-27 15:55 上傳
