STM32F103帶鍵盤掃描接口的LED驅動控制程序
manderer
2020-10-27 13:03
TM1637 是一種帶鍵盤掃描接口的LED(發光二極管顯示器)驅動控制專用電路,內部集成有MCU 數字接口、數據鎖存器、LED 高壓驅動、鍵盤掃描等電路。
#include "TM1637.h"
#include "delay.h"
#include "usart.h"
#include "Buzzer.h"
#include "SysTick.h"
/** Write multiple bits in an 8-bit device register.
* @param slaveAddr I2C slave device address
* @param regAddr Register regAddr to write to
* @param bitStart First bit position to write (0-7)
* @param length Number of bits to write (not more than 8)
* @param data Right-aligned value to write
static unsigned char temp;
static unsigned char x=1;
//unsigned char channel_1=1;
unsigned char Enable_1;
extern unsigned char channel;
extern unsigned char NumDis[24],TIME[10],G_1,K1;
extern int16_t cache[6],data[6];
//__IO u32 Time_1;
extern __IO u32 Total_time;
void TM1637_Delay_us(unsigned int Nus)
for(;Nus>0;Nus--)
__nop();
void TM1637_Start(void)
TM1637_DIO_OUT();
TM1637_CLK (1);
TM1637_OUT_DIO1 = 1;
TM1637_Delay_us(2);
TM1637_OUT_DIO1 = 0;
TM1637_Delay_us(2);
TM1637_CLK ( 0);
void TM1637_Ack(void)
TM1637_DIO_IN();
TM1637_CLK ( 0);
TM1637_Delay_us(5);
while(TM1637_READ_DIO1);
TM1637_CLK (1);
TM1637_Delay_us(2);
void TM1637_Stop(void)
TM1637_DIO_OUT();
TM1637_CLK ( 0);
TM1637_Delay_us(2);
TM1637_Delay_us(2);
TM1637_CLK (1);
TM1637_Delay_us(2);
TM1637_Delay_us(2);
TM1637_CLK( 0);
void TM1637_WriteByte(unsigned char oneByte)
unsigned char i;
TM1637_DIO_OUT();
for(i=0;i<8;i++)
TM1637_CLK(0);
if(oneByte&0x01)
TM1637_Delay_us(3);
TM1637_CLK(1);
oneByte=oneByte>>1;
void TM1637_DisplayChar_1(unsigned char ch,unsigned char p)
if(ch>23)ch=0;//防止數組越界
TM1637_Start();
TM1637_WriteByte(0x44);//0x44固定模式有利于控制顯示位,0x40則采用顯示地址自加模式這里不使用
TM1637_Ack();
TM1637_Stop();
TM1637_Start();
TM1637_WriteByte(0xC0+p);//0X00地址開始顯示
TM1637_Ack();
TM1637_WriteByte(NumDis[ch]);//顯示
TM1637_Ack();
TM1637_Stop();
TM1637_Start();
TM1637_WriteByte(0x8C);
TM1637_Ack();
TM1637_Stop();
void TM1637_Display_1(void)
unsigned char a=0,b=0,c=0,d=0;
if(cache[0]<0)
d=((-cache[0])%60)%10;
c=((-cache[0])%60)/10;
b=((-cache[0])/60)%10;
a=0x40;
d=(cache[0]%60)%10;
c=(cache[0]%60)/10;
b=(cache[0]/60)%10;
a=(cache[0]/60)/10;
TM1637_Start();
TM1637_WriteByte(0x40);//0x40則采用顯示地址自加1模式
TM1637_Ack();
TM1637_Stop();
TM1637_Start();
TM1637_WriteByte(0xC0);//0X00地址開始顯示
TM1637_Ack();
TM1637_WriteByte(TIME[a]);//顯示1
TM1637_Ack();
if(x==1)
temp=TIME[b];
x++;
temp^=0x80; //10000000^11001111=01001111;01001111^10000000=11001111
TM1637_WriteByte(temp);//顯示2和跳動的冒號
TM1637_Ack();
TM1637_WriteByte(TIME[c]);//顯示0
TM1637_Ack();
TM1637_WriteByte(TIME[d]);//顯示0
TM1637_Ack();
TM1637_WriteByte(0xFF);
TM1637_Ack();
TM1637_Ack();
TM1637_Stop();
TM1637_Start();
TM1637_WriteByte(0x8c);
TM1637_Ack();
TM1637_Stop();
void time_1(void)
if(x>=2)
if((Enable_1==1)&&(channel==0))
G_1=1;
cache[0]--;
if(cache[0]<0)
if((-cache[0])>599)
Enable_1=0;
K1=1;
x=1;
void Digital_off_1(void)
TM1637_Start();
TM1637_WriteByte(0x88);
TM1637_Ack();
TM1637_Stop();
(4.4 KB, 下載次數: 114)
2020-10-27 14:38 上傳
TM1637.zip
(1.92 KB, 下載次數: 34)
2020-10-27 13:03 上傳
原理圖參考:
http://m.raoushi.com/bbs/dpj-213102-1.html
51hei團團
2020-10-27 14:40
沒有電路圖啊 樓主能分享下電路嗎?
