MSP430f5529小車源碼
arduino小學徒
2020-10-11 17:49
MSP430f5529小車源碼
https://www.bilibili.com/video/BV1Jz4y1o7Lv/
// Author:wwj
// Built with IAR V7.0
// Gui Lin
// IDE IAR430
/*截止當前:
功能:
本程序從平衡車程序移植出來,仍有平衡車的影子,但不影響運行。
1.硬件IIC讀取6050,并在OLED上顯示
2.中斷測速
3.pwm電機驅動
4.循跡(由于每個人裝循跡模塊的位置都會有差異,需要自己調整傳感器)
5.按鍵檢測
6.藍牙控制
7....ADD ING
勿拿本代碼做交易。!
勿拿本代碼做交易。!
勿拿本代碼做交易。!
本來只想放出來演示,突然發現有人從中謀取利益,于是決定共享源碼!!!
各位朋友加油,未來的科技看你們!!!
#include <msp430.h>
#include <stdint.h>
#include <stdbool.h>
//#include "oledfont.h"
//#include "msp430f5529.h"
#include "MPU6050.h"
#include "uart.h"
#include "exter_interr.h"
#include "pwm.h"
#include "time.h"
#include "hardw_i2c_oled.h"
#include "mathfun.h"
#include "xunji.h"
void OledDisApp(void);
void delay(unsigned int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y=5000;y>0;y--);
// Device Initialization *******************************************************
void initClockTo16MHz()
UCSCTL3 |= SELREF_2; // Set DCO FLL reference = REFO
UCSCTL4 |= SELA_2; // Set ACLK = REFO
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select DCO range 16MHz operation
UCSCTL2 = FLLD_0 + 487; // Set DCO Multiplier for 16MHz
// (N + 1) * FLLRef = Fdco
// (487 + 1) * 32768 = 16MHz
// Set FLL Div = fDCOCLK
__bic_SR_register(SCG0); // Enable the FLL control loop
// Worst-case settling time for the DCO when the DCO range bits have been
// changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
// UG for optimization.
// 32 x 32 x 16 MHz / 32,768 Hz = 500000 = MCLK cycles for DCO to settle
__delay_cycles(500000);//
// Loop until XT1,XT2 & DCO fault flag is cleared
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG); // Clear XT2,XT1,DCO fault flags
SFRIFG1 &= ~OFIFG; // Clear fault flags
}while (SFRIFG1&OFIFG); // Test oscillator fault flag
uint16_t setVCoreUp(uint8_t level){
uint32_t PMMRIE_backup, SVSMHCTL_backup, SVSMLCTL_backup;
//The code flow for increasing the Vcore has been altered to work around
//the erratum FLASH37.
//Please refer to the Errata sheet to know if a specific device is affected
//DO NOT ALTER THIS FUNCTION
//Open PMM registers for write access
PMMCTL0_H = 0xA5;
//Disable dedicated Interrupts
//Backup all registers
PMMRIE_backup = PMMRIE;
PMMRIE &= ~(SVMHVLRPE | SVSHPE | SVMLVLRPE |
SVSLPE | SVMHVLRIE | SVMHIE |
SVSMHDLYIE | SVMLVLRIE | SVMLIE |
SVSMLDLYIE
SVSMHCTL_backup = SVSMHCTL;
SVSMLCTL_backup = SVSMLCTL;
//Clear flags
PMMIFG = 0;
//Set SVM highside to new level and check if a VCore increase is possible
SVSMHCTL = SVMHE | SVSHE | (SVSMHRRL0 * level);
//Wait until SVM highside is settled
while((PMMIFG & SVSMHDLYIFG) == 0)
//Clear flag
PMMIFG &= ~SVSMHDLYIFG;
//Check if a VCore increase is possible
if((PMMIFG & SVMHIFG) == SVMHIFG)
//-> Vcc is too low for a Vcore increase
//recover the previous settings
SVSMHCTL = SVSMHCTL_backup;
//Clear all Flags
PMMIFG &= ~(SVMHVLRIFG | SVMHIFG | SVSMHDLYIFG |
SVMLVLRIFG | SVMLIFG |
SVSMLDLYIFG
//Restore PMM interrupt enable register
PMMRIE = PMMRIE_backup;
//Lock PMM registers for write access
PMMCTL0_H = 0x00;
//return: voltage not set
return false;
//Set also SVS highside to new level
//Vcc is high enough for a Vcore increase
SVSMHCTL |= (SVSHRVL0 * level);
//Clear flag
//Set VCore to new level
PMMCTL0_L = PMMCOREV0 * level;
//Set SVM, SVS low side to new level
SVSMLCTL = SVMLE | (SVSMLRRL0 * level) |
SVSLE | (SVSLRVL0 * level);
//Wait until SVM, SVS low side is settled
while((PMMIFG & SVSMLDLYIFG) == 0)
//Clear flag
PMMIFG &= ~SVSMLDLYIFG;
//SVS, SVM core and high side are now set to protect for the new core level
//Restore Low side settings
//Clear all other bits _except_ level settings
SVSMLCTL &= (SVSLRVL0 + SVSLRVL1 + SVSMLRRL0 +
SVSMLRRL1 + SVSMLRRL2
//Clear level settings in the backup register,keep all other bits
SVSMLCTL_backup &=
~(SVSLRVL0 + SVSLRVL1 + SVSMLRRL0 + SVSMLRRL1 + SVSMLRRL2);
//Restore low-side SVS monitor settings
SVSMLCTL |= SVSMLCTL_backup;
//Restore High side settings
//Clear all other bits except level settings
SVSMHCTL &= (SVSHRVL0 + SVSHRVL1 +
SVSMHRRL0 + SVSMHRRL1 +
SVSMHRRL2
SVSMHCTL_backup &=
~(SVSHRVL0 + SVSHRVL1 + SVSMHRRL0 + SVSMHRRL1 + SVSMHRRL2);
//Restore backup
SVSMHCTL |= SVSMHCTL_backup;
//Wait until high side, low side settled
while(((PMMIFG & SVSMLDLYIFG) == 0) &&
((PMMIFG & SVSMHDLYIFG) == 0))
//Clear all Flags
SVMLVLRIFG | SVMLIFG | SVSMLDLYIFG
PMMCTL0_H = 0x00;
return true;
bool increaseVCoreToLevel2()
uint8_t level = 2;
uint8_t actlevel;
bool status = true;
//Set Mask for Max. level
level &= PMMCOREV_3;
//Get actual VCore
actlevel = PMMCTL0 & PMMCOREV_3;
//step by step increase or decrease
while((level != actlevel) && (status == true))
if(level > actlevel)
status = setVCoreUp(++actlevel);
return (status);
void initGPIO()
//I2C Pins
P3SEL |= BIT0 + BIT1; // P3.0,1 option select
P1DIR |=BIT0;
P4DIR |=BIT7;
//按鍵輸入
P2DIR &=~BIT1;
P1DIR &=~BIT1;
P2REN |= BIT1;//使能上下拉
P2OUT |= BIT1;//上拉
P1REN |= BIT1;//使能上下拉
P1OUT |= BIT1;//上拉
void initI2C()
UCB0CTL1 |= UCSWRST; // Enable SW reset(復位使能)
UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // Master, I2C,synchronous mode(同步模式)
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB0BR0 = 160; // fSCL = SMCLK/160 = ~100kHz
UCB0BR1 = 0;
UCB0CTL0 &=~UCSLA10; //7位地址模式
UCB0I2CSA = SLAVE_ADDR>>1; //SlaveAddress>>1;//SLAVE_ADDR>>1; //
UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
UCB0IFG &=~UCTXIFG;
int num;
int main(void) {
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
increaseVCoreToLevel2();
initClockTo16MHz(); //配置系統時鐘為16Mhz
//delay(10);
initGPIO();
initI2C();
//delay(10);
OLED_Init();
//delay(10);
UART_Init('n',8,1);
InitMPU6050();
//delay(10);
exterPin();//外部引腳中斷
//MotorSpeedDetectionInit();
PWMInit();
TB6612INOUT();
time0InterInit();
xunioinit();//尋跡引腳初始化
delay(10);
//OLED_ShowChar(0,0,'A',16);
//OLED_ShowChar(16,0,'B',16);
//OLED_ShowChar(16*2,0,'C',16);
_EINT();//開啟總中斷
//曾經由于沒開總中斷,調了一下午...
//按鍵檢測
if((P2IN & BIT1) == 0)
delay(3);
P1OUT ^= BIT0;
//PWM_Motor(-20,-20);
while(!(P2IN&BIT1));
xunjiing();//尋跡
if(count_time >=20)
count_time =0;
// P1OUT ^= BIT0; //形成閃燈效果
Angle = Mpu6050AccelAngle(ACCEL_XOUT,ACCEL_ZOUT);
Angle_dot = Mpu6050GyroAngle(GYRO_YOUT);
// pwm_calculate();//PWM計算輸出
#if 1
if(count_time2 >=10)
count_time2 =0;
OledDisApp();
#endif
#if 0
if(Angle >10.0)
PWM_Motor(20,20);
else if(Angle < -10.0)
PWM_Motor(-20,-20);
Stop();
#endif
//printf ("Pwm = %d \r\n",Pwm);
// OLED_Show_Number(0,6,abs(Angle),16);
//P1OUT ^=BIT0;
//printf("angle = %1f , angle_dot = %2f \r\n",Angle,Angle_dot);
//printf("ML = %d , MR = %d \r\n",speed_mL,speed_mR);//打印編碼器
//PWM_Motor(20,-20);//測試電機,應看到左輪后退,右輪前進
//TA2CCR1 = abs(-100);//L
//TA1CCR1 = abs(256/2);//R
P4OUT ^=BIT7;
// delay(10);
#if 1
if(Angle < 0.0)
//sprintf
OLED_ShowChar(32, 2, '-', 16);
OLED_ShowChar(32, 2, ' ', 16);
OLED_ShowNum(32+8, 2, abs(Angle), 3, 16);
OLED_ShowNum(32+8, 5, speedcar/2, 3, 16);
#endif
//================Speed====================
#if 0
if(Speed < 0.0)
//sprintf
OLED_ShowChar(50, 2, '-', 16);
OLED_ShowChar(50, 2, ' ', 16);
OLED_ShowNum(50+8, 2, abs(Speed), 3, 16);
#endif
//fillRect(124, 64/2, 2, -63, 1,1);
arduino小學徒
2020-10-11 22:52
使用FDC2214尋跡效果更佳
newt的星星
2020-10-12 01:07
開發環境是ccs嗎?
凌丁默
2020-10-12 01:48
大佬有接線圖嗎,I2C不是很看得懂,不會接線???
ball ball you。。。。。
沐浴
2020-10-12 05:51
樓主拿過來接上線就能跑哇
超大俠2
2020-10-12 17:20
沐浴 發表于 2020-10-12 05:51
樓主拿過來接上線就能跑哇
大哥,求接線
tanghuiwen
2021-5-5 11:32
這代碼不完整
faithblue
2021-7-12 11:25
頭文件能否分享
lhyyds
2021-7-18 23:30
是用keil開發的嗎?
電工小白
2021-7-20 09:32
大佬可以分享一下頭文件嘛
xjc147687
2021-7-22 18:39
這代碼少了個子函數啊,求完整的
KIVENDon
2022-7-15 11:10
求完整的代碼和接線圖,謝謝
KIVENDon
2022-7-25 10:16
這個咋接線啊,大佬
寧安樂
2023-7-21 17:29
頭文件里的.C文件可以分享嗎,否則不能用啊
林66666
2023-7-24 11:29
求完整代碼
