標題: 請求大佬幫忙看看單片機程序,為什么我的16*16的漢字可以正常顯示32*32的不行 [打印本頁]
作者: 啊h啊    時間: 2020-9-16 17:46
void LM_ShowCHinese(uchar x,uchar y,uchar no)
        u8 t,adder=0;
        LM_Pos(x,y);
    for(t=0;t<16;t++)
                                SdData(Hzk[2*no][t]);
                                adder+=1;
                LM_Pos(x,y+1);
    for(t=0;t<16;t++)
                                SdData(Hzk[2*no+1][t]);
                                adder+=1;
        //32*32
void LM_ShowCHinese_32(uchar x,uchar y,uchar no)
        u8 t,z,b,adder=0;
                b=0;
                for(z=0;z<8;z++)
                                LM_Pos(x,y+b);
                                b += 1;
                                for(t=0;t<16;t++)
                                                SdData(YH[8*no+adder][t]);
                                                adder+=1;
//16*16
char Hzk[][32]={
{0xC0,0xE0,0xF8,0xFC,0xFE,0xFC,0xF8,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x03,0x07,0x47,0x63,0x7F,0x63,0x47,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"?",0*/
{0x03,0x07,0x47,0x63,0x7F,0x63,0x47,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"oúìò",1*/
{0xF0,0xF8,0xFC,0xF8,0xF0,0xF8,0xFC,0xF8,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x01,0x07,0x0F,0x3F,0x7F,0x3F,0x0F,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"D:\oììò.BMP",2*/
{0x80,0xC0,0xDC,0xBE,0xFE,0xBE,0xDC,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x07,0x0F,0x4F,0x67,0x7F,0x67,0x4F,0x0F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"D:\÷»¨.BMP",3*/
{0x80,0xE0,0xF0,0xFC,0xFE,0xFC,0xF0,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x01,0x07,0x0F,0x3F,0x7F,0x3F,0x0F,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"D:\·½¿é.BMP",4*/
{0x00,0xFC,0x00,0xF8,0x04,0x04,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x3F,0x00,0x1F,0x20,0x20,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//10,5
{0x00,0x00,0xF8,0x08,0x08,0x08,0x08,0x09,0xEE,0x08,0x08,0x08,0x08,0x08,0x00,0x00},
{0x80,0x60,0x1F,0x40,0x41,0x41,0x41,0x41,0x7F,0x41,0x41,0x41,0x41,0x41,0x40,0x00},/*"×ˉ",6*/
{0x00,0xF8,0x01,0x42,0x40,0x42,0x42,0xFA,0x42,0x42,0x42,0x42,0x02,0xFE,0x00,0x00},
{0x00,0xFF,0x00,0x08,0x04,0x02,0x01,0x3F,0x01,0x02,0x04,0x48,0x80,0x7F,0x00,0x00},/*"ÏD",7*/
{0x20,0x24,0x24,0xA4,0xFE,0x23,0x22,0x20,0x00,0xF8,0x08,0x08,0x08,0xF8,0x00,0x00},
{0x10,0x08,0x06,0x01,0xFF,0x01,0x06,0x00,0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00},/*"oí",8*/
//32*32
char YH[][32]={
{0x00,0x00,0x00,0x00,0xF0,0xE0,0x20,0x20,0x20,0x20,0xA0,0xE0,0xA0,0x20,0xA0,0xE4},
{0xBC,0x38,0x20,0x20,0xE0,0xA0,0x20,0x20,0x20,0x20,0x30,0x38,0x30,0x20,0x00,0x00},
{0x00,0x00,0x00,0x00,0xFF,0xFF,0x20,0x10,0x08,0xFE,0xFF,0x10,0x08,0x06,0xFF,0xAA},
{0xAA,0xAA,0xAA,0xAA,0xFE,0xAB,0xAA,0xAA,0xAA,0xBF,0xEB,0x82,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0xFF,0x0F,0x00,0x00,0x00,0x03,0xFD,0xFC,0x08,0x08,0x09,0x14},
{0x6B,0x68,0x08,0x08,0x48,0xC8,0x7C,0x3C,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00},
{0x00,0x20,0x18,0x07,0x01,0x00,0x08,0x08,0x08,0x08,0x09,0x09,0x09,0x09,0x09,0x09},
{0x09,0x09,0x09,0x09,0x19,0x2D,0x2D,0x29,0x61,0x71,0x3F,0x07,0x01,0x00,0x00,0x00},/*"ó¥",0*/
{0x00,0x00,0x00,0x00,0x20,0xC0,0x40,0x40,0x7C,0x4C,0x40,0x40,0xC0,0xC0,0x00,0x00},
{0x00,0x00,0x00,0x00,0x18,0xF0,0x60,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x02,0x0C,0x38,0x00,0x00,0xFF,0x00,0x01,0x01},
{0x01,0xF1,0xE1,0x21,0x21,0x21,0x21,0xE1,0xF1,0x21,0x01,0x01,0x01,0x00,0x00,0x00},
{0x00,0x00,0x01,0x01,0xE1,0xFF,0x01,0x05,0x19,0x71,0x61,0x01,0xFF,0x00,0x00,0x00},
{0x00,0xFF,0x7F,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x40,0x30,0x0C,0x07,0x00,0x00,0x00,0x00,0x10,0x30,0x30,0x3F,0x40,0x20,0x18},
{0x0E,0x03,0x00,0x00,0x00,0x00,0x00,0x0F,0x3F,0x20,0x20,0x20,0x3F,0x38,0x10,0x00},/*"o½",1*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC},
{0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x81,0x81,0x81,0x81,0x81,0x81,0x81,0xFF,0xFF},
{0x81,0x81,0x81,0x81,0x81,0x81,0x81,0x81,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0xFF},
{0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x7F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x3F},
{0x30,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x39,0x3E,0x10,0x00,0x00},/*"μç×",2*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10},
{0x10,0x10,0x10,0x10,0x10,0x90,0xD0,0x70,0x38,0x38,0x30,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xFC},
{0xFC,0x8C,0x82,0x83,0x81,0x80,0x80,0x80,0x80,0x80,0xC0,0xE0,0xC0,0x80,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF},
{0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x10,0x30,0x70,0x3F},
{0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"×ó",3*/
作者: wc86110    時間: 2020-9-16 18:22
16*16行,32*32不行有可能與硬件有關
作者: yzwzfyz    時間: 2020-9-18 16:02
一定是你還未真正理解掃描顯示的原理。
先補一下課。循序漸進。不要急于求成。
