這個單片機st7920液晶程序里面Write_Data(00);的作用?
ADMIN_ALLENY
2020-9-16 17:24
此程序是一個開發板(51單片機的12684顯示)的教程程序,void DisplayCGRAM(unsigned char x,unsigned char y)這個函數是如何對void CGRAM()函數進行顯示的,Display是一個關鍵字嗎?還有Write_Data(00);這條語句的作用是什么?如何去理解?
求大神解答,謝謝。
名稱:st7920字庫液晶顯示
修改:無
內容:通過顯示字符、數字、漢字和圖片測試液晶基本功能
#include <reg52.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^4;
sbit RW = P2^5;
sbit E = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define DataPort P0 //MCU P0<------> LCM
unsigned char code user16x16[]={ //笑臉圖片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
unsigned char code pic1[]= // 圖片代碼
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
0xC0,0x1F,0xFF,0x81,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
0xC0,0x18,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x08,0x00,0x00,0x00,0x03,
0xC0,0x1F,0xFF,0x80,0x00,0x00,0x04,0x07,0x81,0xE0,0x10,0x10,0x03,0xC0,0x30,0x03,
0xC0,0x1F,0xFF,0x80,0x00,0x00,0x0C,0x0C,0xC3,0x30,0x08,0x20,0x0C,0xE0,0x70,0x03,
0xC0,0x18,0x01,0x87,0xFF,0xFE,0x3C,0x18,0x66,0x18,0x04,0x40,0x0C,0x60,0x70,0x03,
0xC0,0x1F,0xFF,0x87,0xFF,0xFE,0x0C,0x18,0x66,0x18,0x02,0x80,0x18,0x00,0xB0,0x03,
0xC0,0x1F,0xFF,0x80,0x06,0x00,0x0C,0x18,0x66,0x18,0x01,0x00,0x1B,0x81,0x30,0x03,
0xC0,0x01,0x98,0x00,0x06,0x00,0x0C,0x00,0xE3,0x30,0x02,0x80,0x1C,0xC1,0x30,0x03,
0xC0,0x19,0x99,0x80,0x66,0x60,0x0C,0x00,0xC1,0xE0,0x04,0x40,0x18,0x62,0x30,0x03,
0xC0,0x19,0x99,0x80,0x66,0x30,0x0C,0x01,0x83,0x30,0x08,0x20,0x18,0x66,0x30,0x03,
0xC0,0x0D,0x9B,0x00,0xC6,0x38,0x0C,0x03,0x06,0x18,0x10,0x10,0x18,0x67,0xFC,0x03,
0xC0,0x0D,0x9B,0x01,0xC6,0x1C,0x0C,0x06,0x06,0x18,0x20,0x08,0x18,0x60,0x30,0x03,
0xC0,0x01,0x98,0x03,0x86,0x0C,0x0C,0x0C,0x06,0x18,0x00,0x00,0x08,0x60,0x30,0x03,
0xC0,0x7F,0xFF,0xE3,0x06,0x00,0x0C,0x18,0x03,0x30,0x00,0x00,0x0C,0xC0,0x30,0x03,
0xC0,0x7F,0xFF,0xE0,0x1E,0x00,0x0C,0x1F,0xE1,0xE0,0x00,0x00,0x07,0x80,0x30,0x03,
0xC0,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
0xC0,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x18,0x00,0x00,0x00,0x06,0x0C,0x03,
0xC3,0xFF,0xFC,0x3F,0xF0,0x80,0x0C,0x00,0x3F,0x18,0x01,0xFF,0xFE,0x06,0x0C,0x03,
0xC3,0xFF,0xFC,0x3F,0xF1,0x80,0x0F,0xFC,0x3F,0x18,0x01,0xFF,0xFE,0x06,0x0C,0x03,
0xC3,0x0C,0x0C,0x0C,0xC3,0x00,0x0F,0xFC,0x33,0x7F,0xE1,0x86,0x06,0x06,0x0C,0x03,
0xC3,0x1F,0xCC,0x0C,0xC6,0x00,0x0C,0x00,0x33,0x7F,0xE1,0x8F,0xE6,0x06,0x0C,0x03,
0xC3,0x3F,0xCC,0x0C,0xCC,0x00,0x0C,0x00,0x36,0x30,0x01,0x9F,0xE6,0x07,0xFF,0xE3,
0xC3,0x79,0x8C,0x0C,0xC8,0x00,0xFF,0xF0,0x36,0x36,0x01,0xBC,0xC6,0x07,0xFF,0xE3,
0xC3,0x6F,0x0C,0x7F,0xF0,0xC0,0xFF,0xF0,0x36,0x66,0x01,0xB7,0x86,0x06,0x00,0x03,
0xC3,0x0F,0x0C,0x7F,0xF1,0x80,0xC0,0x30,0x36,0x7F,0xC1,0x87,0x86,0x06,0x00,0x03,
0xC3,0x79,0xEC,0x0C,0xC3,0x00,0xC0,0x30,0x33,0x7F,0xC1,0xBC,0xF6,0x06,0x00,0x03,
0xC3,0x76,0xEC,0x0C,0xC6,0x00,0xC0,0x30,0x33,0x06,0x01,0xBB,0x76,0x07,0xFF,0x03,
0xC3,0x07,0x0C,0x0C,0xCC,0x20,0xFF,0xF0,0x33,0x06,0x01,0x83,0x86,0x07,0xFF,0x03,
0xC3,0x03,0x0C,0x18,0xC8,0x60,0xFF,0xF0,0x3F,0x06,0x01,0x81,0x86,0x06,0x03,0x03,
0xC3,0x1C,0x0C,0x18,0xC0,0xC0,0x00,0x00,0x3E,0xFF,0xE1,0x8E,0x06,0x06,0x03,0x03,
0xC3,0x1F,0x0C,0x18,0xC1,0x81,0xB1,0x8C,0x30,0xFF,0xE1,0x8F,0x86,0x06,0x03,0x03,
0xC3,0x03,0x0C,0x30,0xC7,0x01,0xB1,0x8C,0x30,0x06,0x01,0x81,0x86,0x0C,0x03,0x03,
0xC3,0xFF,0xFC,0x70,0xDE,0x03,0x18,0xC6,0x30,0x06,0x01,0xFF,0xFE,0x0C,0x03,0x03,
0xC3,0xFF,0xFC,0x20,0x18,0x03,0x18,0xC6,0x30,0x06,0x01,0xFF,0xFE,0x18,0x03,0x03,
檢測忙位
void Check_Busy()
RS=0;
RW=1;
E=1;
DataPort=0xff;
while((DataPort&0x80)==0x80);//忙則等待
E=0;
寫命令
void Write_Cmd(unsigned char Cmd)
Check_Busy();
RS=0;
RW=0;
E=1;
DataPort=Cmd;
DelayUs2x(5);
E=0;
DelayUs2x(5);
寫數據
void Write_Data(unsigned char Data)
Check_Busy();
RS=1;
RW=0;
E=1;
DataPort=Data;
DelayUs2x(5);
E=0;
DelayUs2x(5);
液晶屏初始化
void Init_ST7920()
DelayMs(40); //大于40MS的延時程序
PSB=1; //設置為8BIT并口工作模式
DelayMs(1); //延時
RES=0; //復位
DelayMs(1); //延時
RES=1; //復位置高
DelayMs(10);
Write_Cmd(0x30); //選擇基本指令集
DelayUs2x(50); //延時大于100us
Write_Cmd(0x30); //選擇8bit數據流
DelayUs2x(20); //延時大于37us
Write_Cmd(0x0c); //開顯示(無游標、不反白)
Write_Cmd(0x01); //清除顯示,并且設定地址指針為00H
DelayMs(15); //延時大于10ms
Write_Cmd(0x06); //指定在資料的讀取及寫入時,設定游標的移動方向及指定顯示的移位,光標從右向左加1位移動
用戶自定義字符
void CGRAM()
int i;
Write_Cmd(0x30);
Write_Cmd(0x40);
for(i=0;i<16;i++)
Write_Data(user16x16[i*2]);
Write_Data(user16x16[i*2+1]);
顯示用戶自定義字符
switch(y)
case 1: Write_Cmd(0x80+x);break;
case 2: Write_Cmd(0x90+x);break;
case 3: Write_Cmd(0x88+x);break;
case 4: Write_Cmd(0x98+x);break;
default:break;
Write_Data(00);
Write_Data(00);
顯示字符串
x:橫坐標值,范圍0~8
y:縱坐標值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
default:break;
while(*s>0)
Write_Data(*s);
s++;
DelayUs2x(50);
清屏
void ClrScreen()
Write_Cmd(0x01);
DelayMs(15);
顯示圖片
void LCD_PutGraphic(unsigned char code *img)
int i,j;
//顯示上半屏內容設置
for(i=0;i<32;i++)
Write_Cmd(0x80 + i); //SET 垂直地址 VERTICAL ADD
Write_Cmd(0x80); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
//顯示下半屏內容設置
for(i=0;i<32;i++)
Write_Cmd(0x88); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<16;j++)
Write_Data(*img);
img++;
設置到繪圖模式
void SetGraphicMode()
Write_Cmd(0x36); //選擇8bit數據流 圖形模式
DelayUs2x(20);
主程序
main()
unsigned char i;
CGRAM(); //寫入自定義字符
Init_ST7920(); //初始化
LCD_PutString(0,1," 單片機 ");
LCD_PutString(0,2,"技術論壇");
LCD_PutString(0,3,"LCD12864點陣液晶");
LCD_PutString(0,4,"ST7920 測試程序");
DisplayCGRAM(7,1); //在第一行第一個位置和
DisplayCGRAM(0,1);//最后一個位置寫入自定義圖片笑臉
//延時30x200ms
for(i=0;i<30;i++)
DelayMs(200);
LCD_PutString(0,1," 專用技術論壇 ");
LCD_PutString(0,2," wwwxxxx.net ");
LCD_PutString(0,3," wwwxxxxxcom ");
LCD_PutString(0,4," 專業成就卓越! ");
DisplayCGRAM(0,1); //寫入自定義圖片笑臉
DisplayCGRAM(0,4);
//延時30x200ms
for(i=0;i<30;i++)
DelayMs(200);
ClrScreen(); //清屏
SetGraphicMode(); //設置成繪圖模式
LCD_PutGraphic(pic1); //調入一幅圖畫
//延時20x200ms
for(i=0;i<20;i++)
DelayMs(200);
ClrScreen();
51hei團團
2020-9-16 21:10
這個是往st7920寄存器里面寫數據,要弄懂這個必須得先精通液晶的寄存器才行
