標題: 各位大神,求告知這個oled的程序怎么改為豎屏顯示呀 [打印本頁]
作者: 啊h啊    時間: 2020-9-16 00:09
#include "LM13232A.h"
#include "LMFONT.h"
#define        _CS1                PCout(0)
#define        _RST                 PCout(1)
#define        RS                         PCout(11)
#define        SCLK                PCout(10)
#define        SID                 PCout(9)
extern unsigned char LIG1[2];
extern unsigned char LIG2[2];
uchar   ContrastLevel;     // 對比度設置級別
void lm13232_GPIO_ITN(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//-------寫命令------------------------
void SdCmd(uchar Command)
   uchar j;
   SCLK = 1;
    RS = 0;       //0寫命令
    _CS1 = 0;
   for(j=0;j<8;j++)
      if(Command&0x80) SID=1;
      else         SID=0;
      SCLK=0;
      SCLK=1;
                Command=Command<<1;
   _CS1=1;
//-----寫數據--------------------------
void SdData(uchar DData)
   uchar j;
   SCLK = 1;
   RS  = 1; //1寫數據
   _CS1 = 0;
   for(j=0;j<8;j++)
          if(DData&0x80) SID=1;
      else         SID=0;
      SCLK=0;
      SCLK=1;
          DData=DData<<1;
   _CS1=1;
// 寫一個字節
void WriteScreen(uchar *DisplayData)        // 顯示為: 132x32/8 byte
        uchar TempData;
        uchar i, j;
        for(i=0;i<4;i++)
                        SdCmd(0xb0 | i);        // select page
                        SdCmd(0x10);            // start form column 0開始
                        SdCmd(0x00);            // (2byte command)
                        for(j=0;j<132;j++)
                                        TempData=(*(DisplayData+(i*132)+j));
                                        SdData(TempData);
/*顯示位置*/
void LM_Pos(uchar x,uchar y)
        SdCmd(0xb0+y);
        SdCmd(((x&0xf0)>>4)|0x10);
        SdCmd((x&0x0f)|0x01);
/*清屏函數*/
void LM_Cler(void)
        uchar i,n;
        for(i=0;i<8;i++)
                        SdCmd(0xb0+i);
                        SdCmd(0x00);
                        SdCmd(0x10);
                        for(n=0;n<132;n++)SdData(0x00);
//在指定位置顯示一個字符,包括部分字符
//x:0~127
//y:0~63
//mode:0,反白顯示;1,正常顯示
//size:選擇字體 16/12
void LM_ShowChar(uchar x,uchar y,uchar chr)
        uchar c=0,i=0;
        c=chr-' ';//得到偏移后的值
        if(x>Max_Column-1){x=0;y=y+2;}
        if(SIZE ==16)
                        LM_Pos(x,y);
                        for(i=0;i<8;i++)
                        SdData(F8X16[c*16+i]);
                        LM_Pos(x,y+1);
                        for(i=0;i<8;i++)
                        SdData(F8X16[c*16+i+8]);
                                LM_Pos(x,y+1);
                                for(i=0;i<6;i++)
                                SdData(F6x8[c][i]);
//m^n函數
int LM_pow(uchar m,uchar n)
        int result=1;
        while(n--)result*=m;
        return result;
//顯示2個數字
//x,y :起點坐標
//len :數字的位數
//size:字體大小
//mode:模式        0,填充模式;1,疊加模式
//num:數值(0~4294967295);
void LM_ShowNum(uchar x,uchar y,int num,uchar len,uchar size)
        uchar t,temp;
        uchar enshow=0;
        for(t=0;t<len;t++)
                temp=(num/LM_pow(10,len-t-1))%10;
                if(enshow==0&&t<(len-1))
                        if(temp==0)
                                LM_ShowChar(x+(size/2)*t,y,' ');
                                continue;
                        }else enshow=1;
                 LM_ShowChar(x+(size/2)*t,y,temp+'0');
//顯示一個字符號串
void LM_ShowString(uchar x,uchar y,uchar *chr)
        unsigned char j=0;
        while (chr[j]!='\0')
        {                LM_ShowChar(x,y,chr[j]);
                        x+=8;
                if(x>120){x=0;y+=2;}
                        j++;
//顯示漢字
void LM_ShowCHinese(uchar x,uchar y,uchar no)
        u8 t,adder=0;
        LM_Pos(x,y);
    for(t=0;t<16;t++)
                        SdData(Hzk[2*no][t]);
                        adder+=1;
        LM_Pos(x,y+1);
    for(t=0;t<16;t++)
                                SdData(Hzk[2*no+1][t]);
                                adder+=1;
/***********功能描述:顯示顯示BMP圖片128×64起始點坐標(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
void LM_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
  if(y1%8==0) y=y1/8;
  else y=y1/8+1;
        for(y=y0;y<y1;y++)
                LM_Pos(x0,y);
    for(x=x0;x<x1;x++)
                    SdData(BMP[j++]);
// 對比度調節
void LCD_Darker(void)
        if (ContrastLevel<0x3F)
        ContrastLevel++;
    SdCmd(0x81);                     // E-Vol setting
        SdCmd(ContrastLevel);   // (2byte command)
void LCD_Lighter(void)
        if (ContrastLevel>0x00)
             ContrastLevel--;
// 初始化lcd
void initLCDM(void)
        lm13232_GPIO_ITN();
          _CS1    = 1;
    _RST    = 1;
    RS      = 1;
    SCLK    = 1;
    SID     = 1;
//        _RST=1;                 // 復位lcd
        _RST=0;
        delay_ms(1);
        _RST=1;
        delay_ms(100);
    ContrastLevel=0x0f;     // 默認對比度
        SdCmd(0xaf);            // 開
        SdCmd(0x40);            // 顯示起點0
    SdCmd(0xa0);            // ADC=0
    SdCmd(0xa6);            // 正常顯示
    SdCmd(0xa4);            // 全部開
    SdCmd(0xa2);            // 偏差 = 1/6 (duty=1/33)
    SdCmd(0xc8);            // 公共輸出模式為反向
    SdCmd(0x2f);            // 全部開
           SdCmd(0x23);                        // RA/RB setting
           SdCmd(0xf8);SdCmd(0x00);// Booster Ratio Set= 2x,3x,4x (2byte command)
作者: weijoyer    時間: 2020-9-16 08:54
你只能取模的時候旋轉字模方向
作者: 心有浮生    時間: 2020-9-16 09:02
你取模取豎屏的試試
作者: cdlongbo    時間: 2020-9-16 10:12
OLED點陣沒有多少,你可以做一個顯存,然后全局刷新
