求大神指教啊我的1602為什么不顯示啊?
[打印本頁(yè)]
zzyix123
時(shí)間:
2020-8-29 23:36
(99.75 KB, 下載次數(shù): 14)
2020-8-29 23:34 上傳
#include<reg51.h>
#define uint signed int
#define uchar signed char
uchar aa[]={"current voiltage :"};
sbit lcden = P3^4;
sbit lcdrs = P3^5;
sbit START = P2^0;
sbit CLK = P2^1;
sbit EOC = P2^2;
sbit OE = P2^3;
sbit AA = P2^4;
sbit BB = P2^5;
sbit CC = P2^6;
float v;
void delay(uint ms) //延時(shí)函數(shù)
uchar i;
while(ms--);
for(i<0;i<120;i++);
void write_com(uchar com) //寫命令函數(shù)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date) //寫數(shù)據(jù)函數(shù)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void LCD1602_init() //1602初始化函數(shù)
lcden=0;
write_com(0x38);
write_com(0x0C);
write_com(0x01);
void display (int v)
int shu,i;
write_com(0x80);
for(i=0;i<16;i++)
write_data(aa[i]);
write_com(0x80+0x46);
shu=v/100;
write_data(shu+'0');
delay(5);
write_data('.');
delay(5);
shu=v%100/10;
delay(5);
delay(5);
shu=v%10;
delay(5);
write_data('V');
LCD1602_init();
TMOD=0x02;
TH0=0x14;
TL0=0X14;
IE=0X82;
TR0=1;
P2=0x0f; //選用通道0,CLK=1,START=1,EOC=1,OE=1.
START=0;
START=1;
START=0;
while(EOC=0);
OE=1;
v=P1*1.0/255*500;
display(v);
OE=0;
void Timer0() interrupt 1
CLK=!CLK;
zzyix123
時(shí)間:
2020-8-29 23:38
顯示函數(shù)沒的問(wèn)題 就是“v=P1*1.0/255*500”;如果把P1改成255 就可以正確顯示5.00V
zzyix123
時(shí)間:
2020-8-29 23:58
主函數(shù)中 WHILE(EOC==0)這里少打個(gè)=
Kelan
時(shí)間:
2020-8-30 11:26
建議 LCD接口的RW 用單片機(jī)的IO來(lái)控制,而不是一直接低電平
梁廷明
時(shí)間:
2020-8-31 09:13
等待釋放,估計(jì)是卡在那里了
梁廷明
時(shí)間:
2020-8-31 09:17
while(EOC=0); 在這里了,應(yīng)該改為EOC==0
小文文
時(shí)間:
2020-8-31 14:55
RW接IO扣一開始給顯示屏顯示幾個(gè)字母一下看能不能正常,再清屏接著你程序又不影響,可以檢查一下你上面的程序會(huì)不會(huì)卡死沒運(yùn)行下來(lái)
aayon1979
時(shí)間:
2020-8-31 16:08
while(EOC=0);這里有錯(cuò)
