單片機寫數據到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM源程序
51黑電子會員
2020-8-27 11:13
本帖最后由 51黑電子會員 于 2020-8-27 13:27 編輯
#include <reg52.h>
#define LCD12864Data P2//LCD12864點陣型液晶顯示器輸入輸出數據/命令端口
sbit LCD12864_RS=P0^7;//LCD12864點陣型液晶顯示器數據/命令選擇端
sbit LCD12864_RW=P0^6;//LCD12864點陣型液晶顯示器讀/寫端
sbit LCD12864_EN=P0^5;//LCD12864點陣型液晶顯示器使能端
//太陽
uchar code sun[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x08,0x10,0x00,0x00,0x10,0x08,0x00,0x00,0x10,0x08,0x00,0x00,0x08,0x10,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00};
//月亮
uchar code moon[]={0x00,0x00,0x00,0x00,0x03,0x80,0x02,0x40,0x02,0x20,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x20,0x02,0x40,0x03,0x80,0x00,0x00,0x00,0x00};
//星星
uchar code star[]={0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x80,0x00,0x00,0x54,0x54,0x20,0x08,0x08,0x20,0x02,0x80,0x12,0x90,0x08,0x20,0x20,0x08,0x00,0x00,0x00,0x00};
//人
uchar code robot[]={0x07,0xE0,0x08,0x10,0x12,0x48,0x10,0x08,0x1F,0xF8,0x10,0x08,0x30,0x0C,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x5F,0xFA,0x04,0x20,0x04,0x20,0x04,0x20,0x0E,0x70};
void Delay(uint i)
while(--i);
void ReadBuzy()//讀忙函數
P2=0x00;
LCD12864_RS=0;
LCD12864_RW=1;
LCD12864_EN=1;
while(P2 & 0x80);
LCD12864_EN=0;
void LCD12864WriteCommand(uchar command)//寫指令函數
ReadBuzy();//讀忙
LCD12864_RS=0;
LCD12864_RW=0;
LCD12864_EN=1;
LCD12864Data=command;
Delay(100);
LCD12864_EN=0;
void LCD12864WriteData(uchar value)//寫數據函數
ReadBuzy();//讀忙
LCD12864_RS=1;
LCD12864_RW=0;
LCD12864_EN=1;
LCD12864Data=value;
Delay(100);
LCD12864_EN=0;
void LCD12864Init()//LCD12864點陣型液晶顯示器初始化函數
ReadBuzy();//讀忙
Delay(4000);
LCD12864WriteCommand(0x30);//8位數據端口傳輸,且設置為基本指令集動作。
Delay(100);
Delay(37);
LCD12864WriteCommand(0x0c);//設置整體顯示,光標、閃爍全關,不反白。
Delay(100);
LCD12864WriteCommand(0x01);//清屏,并且DDRAM數據指針清零。
Delay(10000);
LCD12864WriteCommand(0x06);//進入點設定模式,設置地址指針自動加1。
void CGRAM()//寫自定義字符函數
uchar i;
LCD12864WriteCommand(0x30);//設置LCD12864點陣型液晶顯示器數據端口D0-D7為8位控制接口,且這8位控制接口接收基本指令操作。
LCD12864WriteCommand(0x40);//寫自定義字符到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM第1個內存地址
for(i=0;i<16;i++)//一個完整自定義字符占用LCD12864點陣型液晶顯示器16(行)x16(列)顯示界面,每一行占用2個字節(即16列)才顯示該行某點字符,因單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,且一個完整自定義字符占用32個字節,那么要寫完一個完整自定義字符占用的32個字節,必須分16次來寫,這就是循環16次的原由。
LCD12864WriteData(sun[i*2]);//把第一個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteData(sun[i*2+1]);//把第二個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,所以要乘以2。
LCD12864WriteCommand(0x50);//寫自定義字符到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM第2個內存地址
LCD12864WriteData(moon[i*2]);//把第一個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteData(moon[i*2+1]);//把第二個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,所以要乘以2。
LCD12864WriteCommand(0x60);//寫自定義字符到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM第3個內存地址
LCD12864WriteData(star[i*2]);//把第一個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteData(star[i*2+1]);//把第二個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,所以要乘以2。
LCD12864WriteCommand(0x70);//寫自定義字符到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM第4個內存地址
for(i=0;i<16;i++)//一個完整自定義字符占用LCD12864點陣型液晶顯器16(示行)x16(列)顯示界面,每一行占用2個字節(即16列)才顯示該行某點字符,因單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,且一個完整自定義字符占用32個字節,那么要寫完一個完整自定義字符占用的32個字節,必須分16次來寫,這就是循環16次的原由。
LCD12864WriteData(robot[i*2]);//把第一個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteData(robot[i*2+1]);//把第二個字節的自定義字符寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,供LCD12864點陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機寫數據是以寫2個字節為一次寫到LCD12864點陣型液晶顯示器內部ST7920芯片的CGRAM內存地址上,所以要乘以2。
void main()//主函數
LCD12864Init();//LCD12864點陣型液晶顯示器初始化函數
CGRAM();//寫自定義字符函數
LCD12864WriteCommand(0x98);//LCD12864點陣型液晶顯示器下半屏第二行第1個顯示位置
LCD12864WriteData(0x00);//清空DRAM內存地址上的內容
LCD12864WriteData(0x00);//把自定義字符寫進DDRAM內存地址0x00,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteCommand(0x99);//LCD12864點陣型液晶顯示器下半屏第二行第2個顯示位置
LCD12864WriteData(0x02);//把自定義字符寫進DDRAM內存地址0x02,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteCommand(0x9A);//LCD12864點陣型液晶顯示器下半屏第二行第3個顯示位置
LCD12864WriteData(0x04);//把自定義字符寫進DDRAM內存地址0x04,供LCD12864點陣型液晶顯示器讀取顯示。
LCD12864WriteCommand(0x9B);//LCD12864點陣型液晶顯示器下半屏第二行第4個顯示位置
LCD12864WriteData(0x06);//把自定義字符寫進DDRAM內存地址0x06,供LCD12864點陣型液晶顯示器讀取顯示。
while(1);//固定循環
A星貓
2020-8-30 10:35
寫的真詳細,感謝作者的分享
zhxiufan
2020-9-1 08:48
額,作者注釋詳細的有點過了,重復部分沒必要如此注解。
