int LED = 13;
int BUTTON = 3;
int val;
void setup()
// put your setup code here, to run once:
pinMode(LED,OUTPUT);
pinMode(BUTTON,INPUT);
void loop()
// put your main code here, to run repeatedly:
val = digitalRead(BUTTON);
if(val == HIGH)
digitalWrite(LED,HIGH);
digitalWrite(LED,LOW);
