標題: 為什么我的時鐘程序Proteus仿真可以,開發板上程序會出現錯誤 [打印本頁]
作者: zfb123456    時間: 2020-8-7 15:22
程序如下,請教程序哪里有問題,謝謝!
#include<reg52.h>
sbit lcdrs=P2^6;
sbit lcdrw=P2^5;
sbit lcden=P2^7;
sbit ds1302_IO=P3^4;
sbit ds1302_CLK=P3^6;
sbit ds1302_RST=P3^5;
uchar num,i;
uchar code read_addr[7] = {0x81, 0x83, 0x85, 0x87, 0x89, 0x8b, 0x8d};
uchar code write_addr[7] = {0x80, 0x82, 0x84, 0x86, 0x88, 0x8a, 0x8c};
uchar time[7] = {0x57,0x59,0x23,0x06,0x08,0x04,0x20};
LCD1206 程序
void delay(uint z)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com) //寫地址
    lcdrs=0;
    P0=com;
    delay(5);
    lcden=1;
    delay(5);
    lcden=0;
void write_date(uchar date)  //讀數據
    lcdrs=1;
    P0=date;
    delay(5);
    lcden=1;
    delay(5);
    lcden=0;
void init()              //LCD1206初始化
    lcden=0;
    lcdrw=0;
    write_com(0x38);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
DS1302 寫數據
void ds1302_write(uchar addr,uchar date)
        uchar n;
    ds1302_CLK=0;
        ds1302_RST=1;
        for(n=0;n<8;n++)
        ds1302_IO=addr&0x01;
        addr>>=1;
        ds1302_CLK=1;
        ds1302_CLK=0;
    for(n=0;n<8;n++)
        ds1302_IO=date&0x01;
        date>>=1;
        ds1302_CLK=1;
        ds1302_CLK=0;
        ds1302_RST=0;
讀數據
uchar ds1302_read(uchar addr)
    uchar n,dat=0;
    ds1302_RST=1;
    for(n=0;n<8;n++)
        addr>>=1;
        ds1302_CLK=1;
        ds1302_CLK=0;
    for(n=0;n<8;n++)
        dat=dat>>1;
        if(ds1302_IO==1)
            dat=dat|0x80;
        ds1302_CLK=1;
        ds1302_CLK=0;
    ds1302_RST=0;
    return dat;
void ds1302init()   //ds1302初始化
    uchar n;
    ds1302_write(0x8e,0x00);
    for(n=0;n<7;n++)
        ds1302_write(write_addr[n],time[n]);
    ds1302_write(0x8e,0x80);
void ds1302_readtime()  //ds1302讀數據
    uchar n;
    for(n=0;n<7;n++)
        time[n]=ds1302_read(read_addr[n]);
void LcdDisplay()
        write_com(0x80+0X40);
        write_date('0'+time[2]/16);                                //時
        write_date('0'+(time[2]&0x0f));
        write_date('-');
        write_date('0'+time[1]/16);                                //分
        write_date('0'+(time[1]&0x0f));
        write_date('-');
        write_date('0'+time[0]/16);                                //秒
        write_date('0'+(time[0]&0x0f));
        write_com(0x80);
        write_date('2');
    write_date('0');
        write_date('0'+time[6]/16);                        //年
        write_date('0'+(time[6]&0x0f));
        write_date('-');
        write_date('0'+time[4]/16);                        //月
        write_date('0'+(time[4]&0x0f));
        write_date('-');
        write_date('0'+time[3]/16);                        //日
        write_date('0'+(time[3]&0x0f));
        write_com(0x8D);
        write_date('0'+(time[5]&0x07));        //星期
    init();
    ds1302init();
       ds1302_readtime();
    LcdDisplay();
作者: xianfajushi    時間: 2020-8-7 16:33
要看是蝦米錯才能分析,是時序還是延時?
作者: hantu    時間: 2020-8-7 16:37
你自己對照實物板的原理圖看看,lcd1602的控制引腳以及DS1302的引腳對了沒有呢
作者: wufeng391    時間: 2020-8-7 16:40
你的lcd不需要忙檢測么?
作者: OHHO    時間: 2020-8-7 20:25
如果是時間不對,仿真可能存在PC自動授時的設置,所以你proteus的時間可能根本不是來自程序。
作者: zfb123456    時間: 2020-8-7 22:12
xianfajushi 發表于 2020-8-7 16:33
要看是蝦米錯才能分析,是時序還是延時?
像是顯示程序沒有寫好,但是不懂哪里的錯誤。
hantu 發表于 2020-8-7 16:37
引腳都是對應的,原理圖已經確認過
作者: zfb123456    時間: 2020-8-7 22:19
OHHO 發表于 2020-8-7 20:25
不知道是不是DS1302讀取的程序不對,顯示出來就不是我初值的值
作者: zfb123456    時間: 2020-8-8 00:24
問題已經找到,程序中讀數據SCLK沒有拉低,
    uchar n,dat=0;
   ds1302_CLK=0;   這句漏了
    ds1302_RST=1;
    for(n=0;n<8;n++)
        addr>>=1;
        ds1302_CLK=1;
        ds1302_CLK=0;
    for(n=0;n<8;n++)
        dat=dat>>1;
        if(ds1302_IO==1)
            dat=dat|0x80;
        ds1302_CLK=1;
        ds1302_CLK=0;
    ds1302_RST=0;
    return dat;
