標(biāo)題: 單片機(jī)按鍵調(diào)節(jié)時(shí)間程序不管用 數(shù)碼管閃爍不停 求幫助 [打印本頁(yè)]
作者: zcs023017    時(shí)間: 2020-8-1 21:13
按鍵調(diào)節(jié)時(shí)間。可是不管用。還有數(shù)碼管閃爍不停;;;;;求指教
#include<reg52.h>
uchar code table[11]={0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,0x80,0x90,0xBF};
uchar timenum[6]= {0,1,2,3,4,5};
sbit seg0 = P2^0;
sbit seg1 = P2^1;
sbit seg2 = P2^2;
sbit seg3 = P2^3;
sbit seg4 = P2^4;
sbit key0 = P1^0;
sbit key1 = P1^1;
sbit key2 = P1^2;
uint miao=0,shi=0,fen=0,n=0;
void delay1ms(uint z)
        uint x,y;
        for(x = z;x>0;x--)
        for(y=100;y>0;y--);
void key()
        uint i=0,j=0,k=0;
//        EA = 0;
        if(key0 == 0)
                delay1ms(3);
                if(key0 == 0)
                        i++;
                        while(!key0);
                 if(i>=3)
                        i=0;
                        if(i==1)
                                if(key1==0)
                                        delay1ms(3);
                                         if(key1 == 0)
                                                 fen++;
                                                while(!key1);
                                         if(fen>=60)
                                         fen=0;
                                else if(key2==0)
                                        delay1ms(3);
                                        if(fen<=0)
                                        fen=60;
                                         if(key2 == 0)
                                                 fen--;
                                                while(!key2);
                        else if(i==2)
                                        if(key1==0)
                                                delay1ms(3);
                                                 if(key1 == 0)
                                                         shi++;
                                                        while(!key1);
                                                 if(shi>=25)
                                                 shi = 0;
                                        else if(key2==0)
                                                delay1ms(3);
                                                if(shi<=0)
                                                shi=25;
                                                 if(key2 == 0)
                                                         shi--;
                                                        while(!key2);
//        EA = 1;
// display();
void display(void)
         P0 = 0xff;
         seg2=0; seg1=0; seg0=0; P0=table[timenum[0]];delay1ms(5);
         P0 = 0xff;
         seg2=0; seg1=0; seg0=1; P0=table[timenum[1]];delay1ms(5);
         P0 = 0xff;
         seg2=0; seg1=1; seg0=0; P0=table[10];delay1ms(5);
         P0 = 0xff;
         seg2=0; seg1=1; seg0=1; P0=table[timenum[2]];delay1ms(5);
         P0 = 0xff;
         seg2=1; seg1=0; seg0=0; P0=table[timenum[3]];delay1ms(5);
         P0 = 0xff;
         seg2=1; seg1=0; seg0=1; P0=table[10];delay1ms(5);
         P0 = 0xff;
         seg2=1; seg1=1; seg0=0; P0=table[timenum[4]];delay1ms(5);
         P0 = 0xff;
         seg2=1; seg1=1; seg0=1; P0=table[timenum[5]];delay1ms(5);
void zhongduan()
        TMOD = 0X01;
        TH0 = 0XEA;
        TL0 = 0X60;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
        seg3 = 1;
        seg4 = 0;
        zhongduan();
                display();
                key();
void timer() interrupt 1
        TH0 = 0XEA;
        TL0 = 0X60;
        n++;
        if(n>=50)
                miao++;
                n=0;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)
                                        shi=0;
        timenum[0] = miao%10;
        timenum[1] = miao/10;
        timenum[2] = fen%10;
        timenum[3] = fen/10;
        timenum[4] = shi%10;
        timenum[5] = shi/10;
作者: xianfajushi    時(shí)間: 2020-8-2 06:48
判斷亂嵌套邏輯也就亂了,從代碼看不是單獨(dú)按鍵了,而是2個(gè)按鍵同時(shí)按下才起作用,閃爍可調(diào)節(jié)延時(shí)少點(diǎn)。
作者: wulin    時(shí)間: 2020-8-2 15:25
給你改好了
數(shù)碼管時(shí)鐘.zip (252.44 KB, 下載次數(shù): 17)
作者: zcs023017    時(shí)間: 2020-8-3 10:51
wulin 發(fā)表于 2020-8-2 15:25
給你改好了
謝啦。
作者: zcs023017    時(shí)間: 2020-8-3 10:53
xianfajushi 發(fā)表于 2020-8-2 06:48
自己都看不下去了。。。
所以換成設(shè)置6個(gè)按鍵的了;那樣就行了;
這個(gè)還不太會(huì)寫;;還是要參考別人的代碼仿寫一下
作者: k9702    時(shí)間: 2020-8-3 11:00
樓主你寫代碼要習(xí)慣寫注釋啊,這樣不論是發(fā)出來(lái)分享還是自己查錯(cuò)的時(shí)候都容易讓人讀懂
作者: zcs023017    時(shí)間: 2020-8-3 11:03
給你改好了
謝謝大佬。。。。。
作者: zcs023017    時(shí)間: 2020-8-3 11:04
k9702 發(fā)表于 2020-8-3 11:00
菜鳥剛起步。。。。
多謝指點(diǎn)哈。下次寫上注釋;
作者: bbxyliyang    時(shí)間: 2020-8-4 14:51
1 、此款電子時(shí)鐘,時(shí)間可以設(shè)置,有4個(gè)按鍵,一個(gè)功能按鍵,一個(gè)加,一個(gè)減,一個(gè)確定按鍵。
2、按下功能按鍵一下,時(shí)鐘走時(shí)停止,時(shí)兩位數(shù)碼管閃爍,代表此時(shí)再調(diào)時(shí)狀態(tài),這個(gè)時(shí)候加減按鍵就可以調(diào)整時(shí)鐘,再次按下功能按鍵,就可以調(diào)整分鐘,再按一下功能按鍵就可以設(shè)置秒。設(shè)置好時(shí)間后我們按確定按鍵,時(shí)鐘開始走時(shí)。
3、這個(gè)程序?qū)⒑芎玫慕虝?huì)我們?cè)趺醋寯?shù)碼管閃爍顯示。
#include <REG51.H>
typedef unsigned int UINT;
typedef unsigned char UCHAR ;
sbit key1=P3^3;
sbit key2=P3^4;
sbit key3=P3^5;
sbit key6=P3^6;
sbit LE1 = P3^1;  //定義位控口
sbit LE2 = P3^2;  //定義段控口
UCHAR MODE ;
UCHAR page ;
signed char  HH = 0;  //小時(shí)初始值
signed char  MM = 0;  //分鐘初始值
signed char SS = 0;  //秒初始值
UINT u1_10ms  = 0; //10ms計(jì)數(shù)
UINT u2_10ms  = 0;
bit T_CYCLE = 0;
extern void T0_Init(void); //初始化定時(shí)器,函數(shù)定義在timer.c
UCHAR code NUM[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
void delay(UINT t) //延時(shí)t時(shí)鐘周期
while (t--) ;
void H_Increase(void) //小時(shí)增1
IF(HH<23) HH++;
  HH = 0;
void M_Increase(void)  //分鐘增1
if(MM<59) MM++;
  MM = 0;
void S_Increase(void)  //秒增1
if(SS<59) SS++;
  SS = 0;
void H(void) //小時(shí)增1
if(HH>0) HH--;
  HH =23;
void M(void)  //分鐘增1
if(MM>0) MM--;
  MM = 59;
void S(void)  //秒增1
if(SS>0) SS--;
  SS = 59;
void display(UCHAR SEG,UCHAR Digi) //顯示一位數(shù)碼管,SEG = 0-9數(shù)字,Digi = 第0-6位
LE2 = 1;
P0 = (0x01<<Digi) ;
LE2 = 0;
P0 = 0x00;
LE1 = 1;
P0 = NUM[SEG];
if (Digi==1||Digi==4) P1&= 0x7f ;  //顯示分隔符
delay(50);
P0 = 0xff;
LE1 = 0;
void key()
if(key1==0)
  delay(2);
  if(key1==0)
   while(!key1);
        TR0=0;
       if(MODE == 3) MODE = 1;
   else MODE ++;
  if(key2==0)
  delay(2);
  if(key2==0)
   while(!key2);
     if(MODE == 1) H_Increase() ;
    if(MODE == 2) M_Increase() ;
     if(MODE == 3) S_Increase() ;
if(key3==0)
  delay(2);
  if(key3==0)
   while(!key3);
           if(MODE == 1) H() ;
    if(MODE == 2) M() ;
     if(MODE == 3) S() ;
   if(key6==0)
  delay(2);
  if(key6==0)
   while(!key6);
         TR0=1;
   MODE=0;
void main(void)
    P1 = 0xff;
    LE1 = 0;
    LE2 = 0;
T0_Init();
     key();
  if(MODE != 1 || T_CYCLE)
   display(HH/10,0);  //顯示小時(shí)十位數(shù)
   display(HH%10,1);  //顯示小時(shí)個(gè)位數(shù)
      display(10,2);
  if(MODE != 2  || T_CYCLE)
   display(MM/10,3);  //顯示分鐘十位數(shù)
   display(MM%10,4);  //顯示分鐘個(gè)位數(shù)
   display(10,5);  //顯示小時(shí)個(gè)位數(shù)
   if(MODE != 3  || T_CYCLE)
  display(SS/10,6);  //顯示秒十位數(shù)
  display(SS%10,7);  //顯示秒個(gè)位數(shù)
extern void key_Process(void);
extern void S_Increase(void);
void T0_Init(void)
TMOD = 0x11;
//定時(shí)器賦初始值,定時(shí)時(shí)間為10ms。
TH0 = 0xd8;
TL0 = 0xf0;
TH1 = 0xd8;
TL1= 0xf0;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
EA=1;
void T0_INTSrv(void) interrupt 1
//定時(shí)器重新開始計(jì)時(shí)。
TH0 = 0xd8;
TL0 = 0xf0;
u1_10ms ++;
if (u1_10ms>99) // 1000 ms = 1 second
  u1_10ms = 0;
  SS++;
  if(SS==60)
   SS=0;
   MM++;
   if(MM==60)
    MM=0;
    HH++;
    if(HH==24)
    HH=0;
void T1_INTSrv(void) interrupt 3
TH0 = 0xd8;
TL0 = 0xf0;
u2_10ms ++;
if (u2_10ms%10==0) // 100 ms
  T_CYCLE = ! T_CYCLE; //閃爍循環(huán)
