arduino怎么實(shí)現(xiàn)十個(gè)燈隨機(jī)亮一個(gè)?
[打印本頁(yè)]
andnine
時(shí)間:
2020-6-19 23:25
請(qǐng)教大師們,用arduino怎么實(shí)現(xiàn)十個(gè)燈,第一次隨機(jī)亮十個(gè)中的一個(gè),第二次剩下九個(gè)里隨機(jī)亮一個(gè),第三次,剩下八個(gè)里隨機(jī)亮一個(gè),以此類(lèi)推,怎么編寫(xiě)程序啊,用不用其他元器件?
angmall
時(shí)間:
2020-6-20 01:07
我給你來(lái)個(gè)程序參考
long randNumber;
void setup() {
Serial.begin(9600);
// if analog input pin 0 is unconnected, random analog
// noise will cause the call to randomSeed() to generate
// different seed numbers each time the sketch runs.
// randomSeed() will then shuffle the random function.
randomSeed(analogRead(0));
void loop() {
// print a random number from 0 to 299
randNumber = random(300);
Serial.println(randNumber);
// print a random number from 10 to 19
randNumber = random(10, 20);
delay(50);
15411
時(shí)間:
2020-6-20 19:43
可能不是你想要的,但是你可以拿去改動(dòng)
#include <AT89X52.h>
#include <intrins.h>
#include <stdlib.h>
#define TRUE 1
#define FALSE 0
bit bT0Flg = FALSE;
//U2 595µÄÇý¶¯Òý½Å¶¨Òå
sbit sbSHCP2 = P2^0;
sbit sbDS2 = P2^1;
sbit sbSTCP2 = P2^2;
//U3 595µÄÇý¶¯Òý½Å¶¨Òå
sbit sbSHCP3 = P2^3;
sbit sbDS3 = P2^4;
sbit sbSTCP3 = P2^5;
//U4 595µÄÇý¶¯Òý½Å¶¨Òå
sbit sbSHCP4 = P2^6;
sbit sbDS4 = P2^7;
sbit sbSTCP4 = P3^0;
//U5 595µÄÇý¶¯Òý½Å¶¨Òå
sbit sbSHCP5 = P3^1;
sbit sbDS5 = P3^3;
sbit sbSTCP5 = P3^4;
//U6 595µÄÇý¶¯Òý½Å¶¨Òå
sbit sbSHCP6 = P3^5;
sbit sbDS6 = P3^6;
sbit sbSTCP6 = P3^7;
unsigned char temp2,temp3,temp4,temp5,temp6;
bdata unsigned char sw; //붨Òå
sbit sw0 = sw ^ 0;
sbit sw1 = sw ^ 1;
sbit sw2 = sw ^ 2;
sbit sw3 = sw ^ 3;
sbit sw4 = sw ^ 4;
sbit sw5 = sw ^ 5;
sbit sw6 = sw ^ 6;
sbit sw7 = sw ^ 7;
unsigned char code SEGtable[]=
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
void Delay(unsigned int x)
unsigned char i;
while(x--)
for(i=0;i<120;i++);
//595ÊäÈ뺯Êý2ºÅ
void Input5952()
unsigned char i;
for(i=0;i<8;i++)
temp2 <<= 1;
sbDS2 = CY;
sbSHCP2 = 1;
_nop_();
_nop_();
sbSHCP2 = 0;
//595Êä³öº¯Êý2ºÅ
void Output5952()
sbSTCP2 = 0;
_nop_();
sbSTCP2 = 1;
_nop_();
sbSTCP2 = 0;
//595ÊäÈ뺯Êý3ºÅ
void Input5953()
unsigned char i;
for(i=0;i<8;i++)
temp3 <<= 1;
sbDS3 = CY;
sbSHCP3 = 1;
_nop_();
_nop_();
sbSHCP3 = 0;
//595Êä³öº¯Êý3ºÅ
void Output5953()
sbSTCP3 = 0;
_nop_();
sbSTCP3 = 1;
_nop_();
sbSTCP3 = 0;
//595ÊäÈ뺯Êý4ºÅ
void Input5954()
unsigned char i;
for(i=0;i<8;i++)
temp4 <<= 1;
sbDS4 = CY;
sbSHCP4 = 1;
_nop_();
_nop_();
sbSHCP4 = 0;
//595Êä³öº¯Êý4ºÅ
void Output5954()
sbSTCP4 = 0;
_nop_();
sbSTCP4 = 1;
_nop_();
sbSTCP4 = 0;
//595ÊäÈ뺯Êý5ºÅ
void Input5955()
unsigned char i;
for(i=0;i<8;i++)
temp5 <<= 1;
sbDS5 = CY;
sbSHCP5 = 1;
_nop_();
_nop_();
sbSHCP5 = 0;
//595Êä³öº¯Êý5ºÅ
void Output5955()
sbSTCP5 = 0;
_nop_();
sbSTCP5 = 1;
_nop_();
sbSTCP5 = 0;
//595ÊäÈ뺯Êý6ºÅ
void Input5956()
unsigned char i;
for(i=0;i<8;i++)
temp6 <<= 1;
sbDS6 = CY;
sbSHCP6 = 1;
_nop_();
_nop_();
sbSHCP6 = 0;
//595Êä³öº¯Êý6ºÅ
void Output5956()
sbSTCP6 = 0;
_nop_();
sbSTCP6 = 1;
_nop_();
sbSTCP6 = 0;
void initrand(void)
unsigned char counter=0;
P1 = 0xff;
sw = P1;
counter = 0; //ͳ¼Æ¿ª¹Ø±ÕºÏµÄÊýÂë
if(sw0 == 1)
counter++;
if(sw1 == 1)
counter++;
if(sw2 == 1)
counter++;
if(sw3 == 1)
counter++;
if(sw4 == 1)
counter++;
if(sw5 == 1)
counter++;
if(sw6 == 1)
counter++;
if(sw7 == 1)
counter++;
srand(counter); //³õʼ»¯ÖÖ×Ó
void Timer0Init(void) //¶¨Ê±Æ÷0³õʼ»¯º¯Êý
TMOD = 0x01; //ÉèÖÃT1¹¤×÷·½Ê½
TH0 = 0x00;
TL0 = 0x0C; //100ms¶¨Ê±
ET0 = 1; //¿ªÆô¶¨Ê±Æ÷0ÖжÏ
// TR0 = 1; //Æô¶¯¶¨Ê±Æ÷
void Timer0Deal(void) interrupt 1 using 1 //¶¨Ê±Æ÷0Öжϴ¦Àíº¯Êý
ET0 = 0; //Ê×ÏȹرÕÖжÏ
TH0 = 0x00; //È»ºóÖØÐÂ×°ÈëÔ¤ÖÆÖµ
TL0 = 0x0C;
ET0 = 1; //´ò¿ªT0ÖжÏ
bT0Flg = TRUE; //¶¨Ê±Æ÷Öжϱê־λ
EX_INT0() interrupt 0 using 1 //ÍⲿÖжÏ0·þÎñº¯Êý
if(TR0 == 1) //Åжϵ±Ç°¶¨Ê±¼ÆÊýÆ÷µÄ״̬
TR0 = 0;
TR0 = 1;
initrand(); //³õʼ»¯ÖÖ×Ó
unsigned int randdata = 0;
unsigned char wdata,qdata,baidata,sdata,gdata;
Timer0Init(); //³õʼ»¯Ê±ÖÓ
IT0 = 1; //ÉèÖÃÍⲿÖжÏ0´¥·¢·½Ê½ÎªµÍÂö³å
EX0 = 1; //ʹÄÜÍⲿÖжÏ0
EA = 1; //´ò¿ª´®¿ÚÖжϱêÖ¾
while(bT0Flg==FALSE); //µÈ´ýÑÓʱ±ê־λ
bT0Flg=FALSE;
randdata = 2 * rand(); //»ñµÃËæ»úÊý
wdata = randdata/10000; //Êä³öÍòλ
temp2 = SEGtable[wdata];
Input5952();
Output5952();
qdata = randdata%10000/1000; //Êä³öǧλ
temp3 = SEGtable[qdata];
Input5953();
Output5953();
baidata = randdata%1000/100; //Êä³ö°Ùλ
temp4 = SEGtable[baidata];
Input5954();
Output5954();
sdata = randdata%100/10; //Êä³ö10λ
temp5 = SEGtable[sdata];
Input5955();
Output5955();
gdata = randdata%10; //Êä³ö¸öλ
temp6 = SEGtable[gdata];
Input5956();
Output5956();
