標題: 51單片機如何寫20khz pwm的頻率? [打印本頁]
作者: BilibiliGiao    時間: 2020-5-31 21:17
//20kHz PWM 可調,步進2%。帶顯示,樓主小菜菜上課溜號了頻率不會寫,下面代碼應該是1khz的,該怎么改呢???還請諸位不吝賜教,先行謝過了
  1. /* Main.c file generated by New Project wizard
  2. *
  3. * Created:   周六 5月 30 2020
  4. * Processor: AT89C51
  5. * Compiler:  Keil for 8051
  6. */
  7. #include<reg51.h>
  8. #define uint unsigned int
  9. #define uchar unsigned char
  10. unsigned char num1;
  11. unsigned char dis;
  12. unsigned char code nondis[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//0-9
  13. uchar time;
  14. double count=70; //定義占空比,并初始占空比為70%
  15. sbit PWM=P0^0; //P0^0口輸出PWM
  16. sbit key_add=P3^4; //加的按鍵
  17. sbit key_dec=P3^5; //減的按鍵
  18. void delayxms(uint z); //延時
  19. void Motor_add(); //增加占空比
  20. void Motor_dec(); //減少占空比
  21. void timer0_init(); //定時器0初始化
  22. //顯示函數
  23.         void display()
  24.         {
  25.
  26.
  27.         unsigned char gewei,shiwei,baiwei;
  28.         baiwei=num1/100;
  29.         gewei=num1%10;
  30.         shiwei=(num1/10)%10;
  31.         P2=nondis[gewei];//個位
  32.         P0=0x80;
  33.         delayxms(1);
  34.         P2=0xff;
  35.         P2=nondis[shiwei];//十位
  36.         P0=0x40;
  37.         delayxms(1);
  38.         P2=0xff;
  39.         P2=nondis[baiwei];//百位
  40.         P0=0x20;
  41.         delayxms(1);
  42.         P2=0xff;
  43.
  44.         }
  45. void main()
  46. {
  47. timer0_init();
  48. delayxms(5);
  49. while(1)
  50. {
  51. Motor_add();
  52. Motor_dec();
  53. num1 = count;
  54. display();//顯示函數
  55. }
  56. }
  57. //延時xms程序
  58. void delayxms(uint z) //延時xms程序
  59. {
  60. uint x,y;
  61. for(y=z;x>0;x--)
  62. for(y=110;y>0;y--);
  63. }
  64. //加
  65. void Motor_add()
  66. {
  67. if(key_add==0)
  68. {
  69. delayxms(2); //此處時間不能太長,否者會的中斷產生沖突
  70. if(key_add==0)
  71. {
  72. count+=2; //每按一次加速按鍵占空比加2
  73. if(count>=98) //限定占空比上限
  74. {
  75. count=98;
  76. }
  77. }
  78. while(!key_add);
  79. }
  80. }
  81. //減
  82. void Motor_dec()
  83. {
  84. if(key_dec==0)
  85. {
  86. delayxms(2);//此處時間不能太長
  87. if(key_dec==0)
  88. {
  89. count-=2; //每按一次減速按鍵占空比減2
  90. if(count<=25) //限定占空比下限
  91. {
  92. count=25;
  93. }
  94. }
  95. while(!key_dec);
  96. }
  97. }
  98. /***********定時器0初始化***********/
  99. void timer0_init()
  100. {
  101. TMOD=0x01; //定時器0工作于方式1
  102. TH0=(65536-10)/256;
  103. TL0=(65536-10)%256;
  104. TR0=1;
  105. ET0=1;
  106. EA=1;
  107. }
  108. /**************定時0中斷處理******************/
  109. void timer0_int() interrupt 1
  110. {
  111. TR0=0; //設置定時器初值期間,關閉定時器
  112. TH0=(65536-10)/256;
  113. TL0=(65536-10)%256;
  114. TR0=1;
  115. time++;
  116. if(time<count) //count為占空比
  117. {
  118. PWM=1; //輸出高電平
  119. }
  120. else
  121. PWM=0;
  122. if(time>=100)//20khz
  123. {
  124. time=0;
  125. }
  126. }
仿真圖哥哥們
仿真圖哥哥們
作者: wulin    時間: 2020-6-1 07:28
這個程序根本不可能產生1KHz PWM,更不可能改成20KHz PWM 可調。樓主仔細看看仿真波形就明白。
作者: BilibiliGiao    時間: 2020-6-1 09:27
wulin 發表于 2020-6-1 07:28
啊這,要求是占空比可調,頻率20khz,占空比開始是70%圖片中的是調到50%的。定時了1ms,然后time加100次啊
