標題: 基于STM32F103C8T6超聲波測距HC-SR04源碼及接線(已調) [打印本頁]
作者: Yimning    時間: 2020-5-30 09:07
使用KEIL 5 打開
解壓文件后彈窗點擊選擇  Cancel
否則編譯會出現錯誤
如果第一次彈窗沒有點擊取消,則重新解壓。
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "led.h"
#include "key.h"
大海電子專營各種電子模塊,歡迎光臨
硬件連接
串口1:RX PA10  TX PA9
超聲波:Trig PB11    ECHG PB10
備注:以下代碼非原創,只是經過修改適配成STM32F103C8T6
若侵權,請告知。
//超聲波硬件接口定義
#define HCSR04_PORT     GPIOB
#define HCSR04_CLK      RCC_APB2Periph_GPIOB
#define HCSR04_TRIG     GPIO_Pin_15
#define HCSR04_ECHO     GPIO_Pin_14
//超聲波計數
u16 msHcCount = 0;
//定時器4設置
void hcsr04_NVIC()
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//IO口初始化 及其他初始化
void Hcsr04Init()
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
    GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
    GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
    GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
    TIM_DeInit(TIM2);
    TIM_TimeBaseStructure.TIM_Period = (1000-1);
    TIM_TimeBaseStructure.TIM_Prescaler =(72-1);
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    TIM_ClearFlag(TIM4, TIM_FLAG_Update);
    TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
    hcsr04_NVIC();
    TIM_Cmd(TIM4,DISABLE);
//打開定時器4
static void OpenTimerForHc()
   TIM_SetCounter(TIM4,0);
   msHcCount = 0;
   TIM_Cmd(TIM4, ENABLE);
//關閉定時器4
static void CloseTimerForHc()
   TIM_Cmd(TIM4, DISABLE);
//定時器4終中斷
void TIM4_IRQHandler(void)
   if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
       TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
       msHcCount++;
//獲取定時器4計數器值
u32 GetEchoTimer(void)
   u32 t = 0;
   t = msHcCount*1000;
   t += TIM_GetCounter(TIM4);
   TIM4->CNT = 0;
   delay_ms(50);
   return t;
//通過定時器4計數器值推算距離
float Hcsr04GetLength(void )
   u32 t = 0;
   int i = 0;
   float lengthTemp = 0;
   float sum = 0;
   while(i!=5)
      TRIG_Send = 1;
      delay_us(20);
      TRIG_Send = 0;
      while(ECHO_Reci == 0);
      OpenTimerForHc();
      i = i + 1;
      while(ECHO_Reci == 1);
      CloseTimerForHc();
      t = GetEchoTimer();
      lengthTemp = ((float)t/58.0);//cm
      sum = lengthTemp + sum ;
    lengthTemp = sum/5.0;
    return lengthTemp;
//測試主函數
int main(void)
         float length;
         delay_init();                     //延時函數初始化
         NVIC_Configuration();          //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
         uart_init(9600);                 //串口初始化為9600
         Hcsr04Init();
         printf("串口測試\r\n");
   Hcsr04Init();
   printf("超聲波初始化成功!\n");
     length = Hcsr04GetLength();
     printf("距離為:%.3fcm\n",length);
                 delay_ms(1000);
基于STM32F103C8T6超聲波測距源碼及接線(已調).7z
1.15 MB, 下載次數: 400, 下載積分: 黑幣 -5
作者: 15236966302    時間: 2023-1-1 14:48
貼主你好,我想請問一下,為什么時不時會出現一些不穩定的情況,經常顯示距離有1233cm,是我的模塊壞了嗎
作者: 15236966302    時間: 2023-1-1 14:51
你好,我想請問一下貼主,為什么會出現這種情況呢?是我的模塊壞了的原因嗎
作者: cr8526    時間: 2023-1-9 15:29
我的手在超聲波測距頭前上下移動,怎么我的只顯示2個距離
作者: cr8526    時間: 2023-1-11 15:57
15236966302 發表于 2023-1-1 14:51
模塊沒問題 的,我把障礙物貼住超聲波的頭也是這樣的顯示
作者: cr8526    時間: 2023-1-12 18:22
cr8526 發表于 2023-1-9 15:29
我找到原因了,我接 了3.3V就這樣的故障。接了5V以后就正常顯示了。
作者: 做夢的孩子    時間: 2023-4-4 16:47
大佬,為什么我的串口助手沒有顯示距離
作者: zcl777    時間: 2023-12-27 22:26
頂起來,好貼,向大佬學習
