標題: 這個C語言轉換程序看不明白。有大佬能說明一下都是干什么的,什么作用么? [打印本頁]
作者: liuze1670    時間: 2020-5-24 13:43
uint adc0832(unsigned char CH)
  uchar i,test,adval;
  adval = 0x00;
  test = 0x00;
  Clk = 0;
  DATI = 1;
  _nop_();   _nop_();
  CS = 0;
  _nop_();
  Clk = 1;
  _nop_();  _nop_();
if(CH == 0x00)
       Clk = 0;
       DATI = 1;
       _nop_();
       Clk = 1;
       _nop_();  _nop_();
       Clk = 0;
       DATI = 0;
       _nop_();  _nop_();
       Clk = 1;
       _nop_();
       Clk = 0;
       DATI = 1;
        _nop_();  _nop_();
       Clk = 1;
        _nop_();  _nop_();
       Clk = 0;
       DATI = 1;
      _nop_();
      Clk = 1;
      _nop_();
      Clk = 0;   _nop_();
      DATI = 1;
   for( i = 0;i < 8;i++ )
       _nop_();
       adval <<= 1;
       Clk = 1;
       _nop_();  _nop_();
       Clk = 0;           _nop_();
       if (DATO)
          adval |= 0x01;
          adval |= 0x00;
  for (i = 0; i < 8; i++)
           test >>= 1;
           if (DATO)
              test |= 0x80;
              test |= 0x00;
          _nop_();
          Clk = 1;
          _nop_();  _nop_();
          Clk = 0;   _nop_();
  if (adval == test)
     dat = test;
     _nop_();  _nop_();
     CS = 1;
     DATO = 1;
     Clk = 1;
     return dat;
作者: benclee    時間: 2020-5-24 22:37
  uchar i,test,adval;
  adval = 0x00;
  test = 0x00;
  Clk = 0;
  DATI = 1;
  CS = 0;
  Clk = 1;
if(CH == 0x00) //選擇通道
       Clk = 0;//這段是選通道0
       DATI = 1;
       Clk = 1;
       Clk = 0;
       DATI = 0;
        Clk = 1;
       Clk = 0;//這段是選擇通道1
       DATI = 1;
       Clk = 1;
       Clk = 0;
       DATI = 1;
      Clk = 1;
      Clk = 0;
      DATI = 1;
   for( i = 0;i < 8;i++ )   //讀取8位數據高位在前
        adval <<= 1;
       Clk = 1;
       Clk = 0;
       if (DATO)
          adval |= 0x01;
          adval |= 0x00;
  for (i = 0; i < 8; i++)  //讀取8位數據低位在前,也就是上面一段反這讀取。
           test >>= 1;
           if (DATO)
              test |= 0x80;
              test |= 0x00;
           Clk = 1;
          Clk = 0;
  if (adval == test)     //進行校驗,如果相同則數據正確,
     dat = test;
      CS = 1;
     DATO = 1;
     Clk = 1;
     return dat;
