關于51單片機中main如何調用子程序問題
臉盲啊
2020-5-13 21:43
自己寫的一個利用GSM模塊上傳數據到服務器,發送短信的程序
上傳數據到服務器部分不會寫主函數了,就是如何在main中調用void GPRSInit();void send_GPRSdata();這兩部分
#include "reg52.h"
#include "type.h"
#include <string.h>
#include <stdio.h>
#define DEVID "" //設備id
#define APIKEY "" //設備apikey
bit flag;
uchar model=0; //模式
uchar temp1H=35; //上限值
uchar temp2H=35; //上限值
uchar temp3H=35; //上限值
uchar hum1H=70; //上限值
uchar hum2H=70; //上限值
uchar hum3H=70; //上限值
uchar temp_L=10;
uchar date[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char temp1=0,temp2=0,temp3=0,hum1=0,hum2=0,hum3=0;
#define SEND_MESSA_TO_YOUR "at+cmgs=\"1840**2397\"\r\n" //填入你手上的手機號碼 不是板子的
#include "LCD1602.H"
sbit set=P1^6;
sbit add=P3^5;
sbit min=P3^4;
sbit beep=P3^6;
sbit led1=P1^2;
sbit led2=P1^1;
/***********模擬開關*********************/
sbit CS_4052=P1^0;
sbit B_4052=P1^1;
sbit A_4052=P1^2;
uchar fen=0; //定時發送短信計時
bit sendFlag=0; //發送短信標志
void delay1ms(unsigned int ms)//延時1毫秒(不夠精確的)
{unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<100;j++);
void Uart_Send(uchar dat) //發送一字節
SBUF=dat;
while(!TI);
TI=0;
//發送一串字符到串口
void Uart_Sends(char* data_at)
unsigned char cnt=0;
while(*(data_at+cnt)) //判斷一串數據是否結束
Uart_Send(*(data_at+cnt));
cnt++;
void select(uchar num)
if(num==1) //上位機串口使能
CS_4052=0;
B_4052=0;
A_4052=0;
else if(num==2) //CC2530串口使能
CS_4052=0;
B_4052=0;
A_4052=1;
//發送短信函數
void Send_SMS(void)
uchar yy=1;
select(1); //GSM模塊串口使能
delay1ms(100);
Uart_Sends("AT+CMGF=1\r");//設置中文方式發送
delay1ms(800);
delay1ms(1000);
Uart_Sends(SEND_MESSA_TO_YOUR);
delay1ms(1000);
switch (yy)
case 1 : Uart_Sends("wendu1=");
Uart_Send(temp1/10+0x30);
Uart_Send(temp1%10+0x30);
Uart_Sends(",wendu2=");
Uart_Send(temp2/10+0x30);
Uart_Send(temp2%10+0x30);
Uart_Sends(",wendu3=");
Uart_Send(temp3/10+0x30);
Uart_Send(temp3%10+0x30);
Uart_Sends("\r\nshidu1=");
Uart_Send(hum1/10+0x30);
Uart_Send(hum1%10+0x30);
Uart_Sends(",shidu2=");
Uart_Send(hum2/10+0x30);
Uart_Send(hum2%10+0x30);
Uart_Sends(",shidu3=");
Uart_Send(hum3/10+0x30);
Uart_Send(hum3%10+0x30);
Uart_Sends("\r\n");
if(temp1>temp1H)
Uart_Sends("wendu1 Warning!!!\r\n");
if(temp2>temp2H)
Uart_Sends("wendu2 Warning!!!\r\n");
if(temp3>temp3H)
Uart_Sends("wendu3 Warning!!!\r\n");
if(hum1>hum1H)
Uart_Sends("hum1 Warning!!!\r\n");
if(hum2>hum2H)
Uart_Sends("hum2 Warning!!!\r\n");
if(hum3>hum3H)
Uart_Sends("hum3 Warning!!!\r\n");
break; //煙霧報警
Uart_Send(0x1a);//以0x1a來結束,表示內容結束,發送短信
void GPRSInit()
select(1); //打開GSM串口
Uart_Sends("AT+CIPCLOSE=1\r\n");
delay1ms(1000);
Uart_Sends("AT+CGCLASS=\"B\"\r\n");
delay1ms(1000);
Uart_Sends("AT+CGDCONT=1,\"IP\",\"CMNET\"\r\n");
delay1ms(1000);
Uart_Sends("AT+CGATT=1\r\n");
delay1ms(1000);
Uart_Sends("AT+CIPCSGP=1,\"CMNET\"\r\n");
delay1ms(1000);
Uart_Sends("AT+CLPORT=\"TCP\",\"2000\"\r\n"); //發送指令指定本地端口
delay1ms(1000);
Uart_Sends("AT+CIPSTART=\"TCP\",\"183.230.40.33\",\"80\"\r\n");
delay1ms(3000);
char xdata text[28];
char xdata buf1[60];
select(1); //打開GPRS串口
//ES=0; //關閉串口接收中斷
Uart_Sends("AT+CIPSEND\r\n");
delay1ms(1000);
memset(buf1, 0, sizeof(buf1));
sprintf(buf1,"POST /devices/%s/datapoints?type=3 HTTP/1.1\r\n",DEVID);
Uart_Sends(buf1);//向服務器發送數據
delay1ms(1000);
memset(buf1, 0, sizeof(buf1));//初始化
sprintf(buf1,"api-key:%s\r\n",APIKEY);
delay1ms(1000);
Uart_Sends("Host:api.heclouds點com\r\n");
delay1ms(1000);
memset(text, 0, sizeof(text));
strcpy(buf1, "{");
sprintf(text, "\"Temperature1\":%d,",temp1);
strcat(buf1, text);
sprintf(text, "\"Humidity1\":%d,",hum1);
strcat(buf1, text);
sprintf(text, "\"Temperature2\":%d,",temp2);
strcat(buf1, text);
sprintf(text, "\"Humidity2\":%d,",hum2);
strcat(buf1, text);
sprintf(text, "\"Temperature3\":%d,",temp3);
strcat(buf1, text);
sprintf(text, "\"Humidity3\":%d",hum3);
strcat(buf1, text);//字符串buf1尾加text的內容
strcat(buf1, "}");
sprintf(text,"Content-Length:%d\r\n",strlen(buf1));
Uart_Sends(text);
delay1ms(1000);
Uart_Sends("\r\n");
delay1ms(1000);
Uart_Sends(buf1);
delay1ms(100);
Uart_Send(0x1a);
delay1ms(1000);
void key()
uchar i=0;
if(!set) //檢測設置按鍵
while(!set);
model++;
if(model==7)
model=0;
if(model==1)//設置模式顯示
WRITE_LCD1602_COM(0x80);
for(i=0;i<16;i++)
WRITE_LCD1602_DAT(DIS_TAB3[i]);
WRITE_LCD1602_COM(0x80+0x40);
for(i=0;i<16;i++)
WRITE_LCD1602_DAT(DIS_TAB4[i]);
WRITE_LCD1602_COM(0x80+0x40+9);
else if(model==0)//正常模式顯示
for(i=0;i<16;i++)
WRITE_LCD1602_DAT(DIS_TAB1[i]);
for(i=0;i<16;i++)
WRITE_LCD1602_DAT(DIS_TAB2[i]);
else if(!add)
while(!add);
switch(model)
case 1: if(temp1H<90) temp1H++; break;
case 2: if(temp2H<90) temp2H++; break;
case 3: if(temp3H<90) temp3H++; break;
case 4: if(hum1H<90) hum1H++; break;
case 5: if(hum2H<90) hum2H++; break;
case 6: if(hum3H<90) hum3H++; break;
default:break;
else if(!min)
while(!min);
switch(model)
case 1: if(temp1H>0) temp1H--; break;
case 2: if(temp2H>0) temp2H--; break;
case 3: if(temp3H>0) temp3H--; break;
case 4: if(hum1H>0) hum1H--; break;
case 5: if(hum2H>0) hum2H--; break;
case 6: if(hum3H>0) hum3H--; break;
default:break;
void beeps()
static uchar count;
count++;
if(count<20)
beep=0;
else if(count<40)
beep=1;
count=0;
void control()//報警檢測控制
static uchar flagsend=0;
if((temp1>temp1H)||(temp2>temp2H)||(temp3>temp3H)||
(hum1>hum1H)||(hum2>hum2H)||(hum3>hum3H)) //溫度控制
beeps(); // 蜂鳴器報警
if(flagsend==0)
flagsend=1;
Send_SMS();
flagsend=0;
beep=1;// 關閉蜂鳴器報警
void rec_cc2530data()
select(2); //選通 cc2530 串口
ES=1; //串口接收中斷
if(date[0]==0x55)
date[0]=0;
if((date[1]==1)&&(date[2]+date[3]==date[4])) //第一路 數據
date[1]=0;
temp1=date[2];
hum1=date[3];
if((date[1]==2)&&(date[2]+date[3]==date[4])) //第二路
date[1]=0;
temp2=date[2];
hum2=date[3];
if((date[1]==3)&&(date[2]+date[3]==date[4])) //第三路
date[1]=0;
temp3=date[2];
hum3=date[3];
void Timer0Init(void) //50毫秒@11.0592MHz
TMOD &= 0xF0; //設置定時器模式
TMOD |= 0x01; //設置定時器模式
TL0 = 0x00; //設置定時初值
TH0 = 0x4C; //設置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0=1;
init_1602();
TMOD=0x20; // T1定時方式2
SCON=0x40;//串行工作 方式1
PCON=0x00; //不加倍
TH1=TL1=0xfd; //定時器1賦初值 保證波特率9600
TR1=1; //開定時器1
REN=1; //允許串口接收
ES=1; //打開串口中斷
EA=1; //開總中斷
Timer0Init();
//GPRSInit();
control(); //控制
key(); //按鍵功能
GPRSInit();
send_GPRSdata();
if(sendFlag==0)
sendFlag=1; //代表已經發過一次,不在發了
Send_SMS(); //發送短信
rec_cc2530data();
delay1ms(50);
display();
delay1ms(50);
void serial()interrupt 4 //串口中斷服務函數
static uchar j;
if(!RI);
RI=0; //清楚接收完畢標志
date[j]=SBUF;
if(date[0]==0x55) //判斷接收到的第一位為傳感器所發數據
j++;
j=0;
if(j==5) //接收傳感器所發數據字節
j=0;
void timer0() interrupt 1 //50ms
static uchar count=0,miao=0;
count++;
if(count>20)
count=0;
miao++;
if(miao>60)
miao=0;
fen++;
if(fen>=1)
fen=0;
sendFlag=0;
man1234567
2020-5-14 13:48
目測都已經寫在主函數main中了
臉盲啊
2020-5-18 23:01
man1234567 發表于 2020-5-14 13:48
目測都已經寫在主函數main中了
但是GPRSInit();send_GPRSdata();這兩個沒反應
張然Adolf
2020-5-19 13:03
我和問題不一樣,但看看類似的程序,看看范例就可以了,看懂了,可以自己改
