想得到一段簡(jiǎn)潔的單片機(jī)代碼
[打印本頁(yè)]
No.23
時(shí)間:
2020-5-7 21:25
功能八個(gè)led燈并排,編號(hào)1,2,3,4,5,6,7,8,先是同時(shí)亮起(1,8)兩個(gè)燈,再依次點(diǎn)亮(2,6)(3,7)(4,5)(3,7)(2,6)(1,8),然后一直循環(huán)進(jìn)行。
#include "reg52.h"
#include "intrins.h"
typedef unsigned char u8;
typedef unsigned int u16;
#define led P2
void delay(u16 i)
while(i--);
led=0x7e; //亮1,8
delay(50000);
led=0xbd; //亮2,7
delay(50000);
led=0xdb; //亮3,6
delay(50000);
led=0xe7; //亮4,5
delay(50000);
led=0xdb;//亮3,6
delay(50000);
led=0xbd; //亮2,7
delay(50000);
cjjdemon
時(shí)間:
2020-5-7 22:07
#include "reg52.h"
#deinfe uchar unsigned char
#define led P2
uchar table[6]={0x7e,0xbd,0xdb,0xe7,0xdb,0xbd};
uchar flag=0;
void delay(uint i)
while(i--);
flag++;
if(flag>=5)
flag=0;
led=table[flag];
delay(50000);
其實(shí)也沒(méi)簡(jiǎn)潔多少,建議不要用delay,用定時(shí)器更好,節(jié)省MCU計(jì)算資源。
xxpp2011
時(shí)間:
2020-5-7 22:10
本帖最后由 xxpp2011 于 2020-5-7 22:39 編輯
unsigned char i=0;
switch(i%6)
case 0: led=0x7e;break; //亮1,8
case 1: led=0xbd;break; //亮2,7
case 2: led=0xdb;break; //亮3,6
case 3: led=0xe7;break; //亮4,5
case 4: led=0xdb;break; //亮3,6
case 5: led=0xbd;break; //亮2,7
i++;
delay(50000);
xianfajushi
時(shí)間:
2020-5-7 22:33
https://blog.csdn.net/xianfajushi/article/details/89220130
man1234567
時(shí)間:
2020-5-8 11:38
#include "reg52.h"
#define led P2
u8 code PP[]={0x7e,0xbd,0xdb,0xe7,0xdb,0xbd};//加的
void delay(u16 i)
while(i--);
u8 i; //加的
for(i=0;i<6;i++){led=PP[i];delay(50000);}//無(wú)需while(1)
出來(lái)逛逛
時(shí)間:
2020-5-8 16:20
本帖最后由 出來(lái)逛逛 于 2020-5-8 16:41 編輯
int i=0;
led=~(1<<(7-i)|1<<i);
i++;
delay(50000);
if(i==3){i++;}
if(i==7){i=0;}
出來(lái)逛逛
時(shí)間:
2020-5-8 16:32
int i=0;
i++;
delay(50000);
if(i==3){i++;}
if(i==7){i=0;}
我姓劉
時(shí)間:
2020-5-8 22:48
int i=0;
i++;
delay(50000);
if(i==3){i++;}
if(i==7){i=0;}
f556
時(shí)間:
2020-5-9 14:39
出來(lái)逛逛 發(fā)表于 2020-5-8 16:20
int i=0;
這是最簡(jiǎn)潔的方式,前些天想過(guò)一下用移位,沒(méi)往下考慮。
