初次發帖-單片機16X16點陣Proteus仿真+取模工具
cx301
2020-4-30 17:39
16X16點陣驅動采用常見的74HC595+74HC138直接驅動,省去了MOS管器件。資料包里有程序、Proteus仿真圖和點陣取模工具。
(777.11 KB, 下載次數: 58)
2020-4-30 17:38 上傳
GND:
+5V:
OE#:74HC138 Pin5 G2B,為H輸出H
G: 綠色數據,暫缺
CLK: 74HC595 Pin11 SCK
STCK:74HC595 Pin12 SCK
LA LB LC LD:74138 ABC G2A(Pin4)
R:74HC595 Pin14 SER 紅色數據*/
#include <reg52.h>
#include <intrins.h>
sbit LD=P0^0; //8
sbit LC=P0^1; //4
sbit LB=P0^2; //2
sbit LA=P0^3; //1 LA必須為脈沖信號,內部有過流保護電路7404
//sbit G=P0^6;
sbit OE=P0^7;
sbit RCK=P0^4; //12 ST_CP
sbit CLK=P0^5; //11 SH_CP
sbit DAT=P3^7; //14 DS
unsigned char idata disp_ram[32]={0};
unsigned char code Tab[]={//先左后右,再上至下 0亮1滅
0xE7,0xFC,0xEF,0xFC,0xC3,0xF1,0xC0,0x63,0xDC,0x7B,0x9F,0xF3,0xBF,0xF3,0x81,0xF7,
0xFC,0xE7,0xFC,0xE7,0xFE,0xE7,0xFE,0xEF,0xFE,0xCF,0x7C,0xCF,0x21,0xDF,0x83,0xDF,/*"51",0*/
0xEF,0xEF,0xF7,0xDF,0xFB,0xBF,0xC0,0x07,0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,
0xDE,0xF7,0xC0,0x07,0xFE,0xFF,0xFE,0xFF,0x00,0x01,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,/*"單",1*/
0xFF,0xFF,0xFF,0xDF,0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xF0,0x01,0xF7,0xFF,
0xF7,0xFF,0xF7,0xFF,0xF0,0x0F,0xF7,0xEF,0xF7,0xEF,0xF7,0xEF,0xEF,0xEF,0xEF,0xEF,/*"片",2*/
0xFF,0xFF,0xF7,0xFF,0xF7,0x07,0xF7,0x77,0xF7,0x77,0x81,0x77,0xF7,0x77,0xE7,0x77,
0xE3,0x77,0xD5,0x77,0xD5,0x77,0xB7,0x77,0xF7,0x76,0xF7,0x76,0xF6,0xF6,0xF6,0xF8,/*"機",3*/
0xFC,0x3F,0xF8,0x1F,0xF8,0x1F,0xF8,0x1F,0xF8,0x1F,0x9C,0x39,0xC7,0xE3,0xE3,0xC7,
0xF1,0x8F,0xF1,0x8F,0xF1,0x8F,0xF1,0x8F,0xE1,0x87,0xC3,0xC3,0x87,0xE1,0x1F,0xF8,/*"logo",4*/
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,/*顯示空白*/
/*********延時函數*********/
void Delay(unsigned int t) //t*1ms
unsigned int i,j; //0-65535
for(i=0;i<t;i++)
for(j=0;j<120;j++);
void Send_16bit(unsigned char dat_L,unsigned char dat_R,unsigned char hang)
unsigned char i;
OE=1; //關閉74HC138輸出
RCK=0;
for(i=0;i<8;i++)
CLK=0;
if(dat_L&0x80)
DAT=1;
DAT=0;
dat_L=dat_L<<1;
CLK=1;
for(i=0;i<8;i++)
CLK=0;
if(dat_R&0x80)
DAT=1;
DAT=0;
dat_R=dat_R<<1;
CLK=1;
switch(hang)
case 0:LA=0;LB=0;LC=0;LD=0;break;
case 1:LA=1;LB=0;LC=0;LD=0;break;
case 2:LA=0;LB=1;LC=0;LD=0;break;
case 3:LA=1;LB=1;LC=0;LD=0;break;
case 4:LA=0;LB=0;LC=1;LD=0;break;
case 5:LA=1;LB=0;LC=1;LD=0;break;
case 6:LA=0;LB=1;LC=1;LD=0;break;
case 7:LA=1;LB=1;LC=1;LD=0;break;
case 8:LA=0;LB=0;LC=0;LD=1;break;
case 9:LA=1;LB=0;LC=0;LD=1;break;
case 10:LA=0;LB=1;LC=0;LD=1;break;
case 11:LA=1;LB=1;LC=0;LD=1;break;
case 12:LA=0;LB=0;LC=1;LD=1;break;
case 13:LA=1;LB=0;LC=1;LD=1;break;
case 14:LA=0;LB=1;LC=1;LD=1;break;
case 15:LA=1;LB=1;LC=1;LD=1;break;
RCK=1;
OE=0;Delay(1);OE=1; //調節延時控制LED亮度
unsigned char zi; //字符控制
unsigned char h; //行數變量
unsigned char i;
{ //滾動顯示
for(zi=0;zi<(16*5);zi++) //
for(i=0;i<15;i++)
for(h=0;h<16;h++)
{Send_16bit(~Tab[h*2+2*zi],~Tab[h*2+1+2*zi],h);}//~取反
//直接切換
/*for(zi=0;zi<5;zi++)
for(i=0;i<100;i++)
for(h=0;h<16;h++)
{Send_16bit(~Tab[h*2+32*zi],~Tab[h*2+1+32*zi],h);}
16X16點陣Proteus仿真 取模工具.rar
(824.16 KB, 下載次數: 135)
2020-4-30 17:38 上傳
