51單片機對編碼器的讀寫和串口通信功能的代碼及上位機讀取數據
初學者12
2020-4-27 11:41
寫單片機對編碼器的讀寫程序和串口通信功能的代碼,以及上位機讀取串口助手保存的TXT文件后繪制出圖形實物的代碼,最后把這幾個代碼整個到一個程序中,請問該怎么尋找代碼呀,師傅說有例程,但是我自己也沒有很清晰的找到,找到的幾個代碼都很長,而且不全,整合的話是不是也要修改來著比如在瀏覽器找到的單片機讀取編碼器的程序
org 00h
jmp main
org 0bh
jmp inic
mov 30h,#0
mov 31h,#0
mov 32h,#0
mov 33h,#0
mov 34h,#0
mov 35h,#0
mov 36h,#0
mov 37h,#0
mov 40h,#0
mov 41h,#0
mov 42h,#0
mov 43h,#0
mov 44h,#0
mov 45h,#0
mov 46h,#0
mov r0,#0
main:acall inib
maib:acall cnco
acall disp
jmp maib
inib:
mov tmod,#01h
mov ie,#82h
mov tl0,low(65536-10)
mov th0,high(65536-10)
setb tr0
ret
inic:
push psw
mov 48h,a
mov a,p1 ;讀取譯碼器信號
anl a,#03h
mov 44h,a
mov 45h,#10
djnz 45h,$ ;延時
mov a,p1 ;再次讀取譯碼器信號
anl a,#03h
cjne a,44h,m5 ;兩次不等跳出中斷
cjne a,46h,m1 ;不相等跳到信號分析子程序,相等跳出中斷
mov 46h,a
jmp m5
m1 :
mov 46h,a
cjne r0,#1eh,m2 ;信號相等調用加計數
acall jia
jmp m3 ;注意跳躍地址,跳躍錯誤 ,計數器將計數錯誤
m2 :cjne r0,#2dh,m3 ;信號相等調用減計數
acall jian
m3 :
mov a,46h
cjne a,#00h,m4
mov r0,#00h
m4 :
mov a,r0
rl a
rl a
orl a,46h ;或指令
mov r0,a
m5 :
mov a,48h
pop psw
reti
jia :
inc 40h ;加計數
mov a,40h
cjne a,#100,d1 ;個位十位
mov 40h,#0
inc 41h
cjne a,#100,d1 ;百位千位
mov 41h,#0
inc 42h
mov a,42h
cjne a,#100,d1 ;萬位十萬位
mov 42h,#0
inc 43h
mov a,43h
cjne a,#100,d1 ;百萬千萬位
mov 43h,#0
d1 :ret
jian:
mov a,40h ;減計數
cjne a,#0,d2
mov 40h,#99
mov a,41h
cjne a,#0,d3
mov 41h,#99
mov a,42h
cjne a,#0,d4
mov 42h,#99
mov a,43h
cjne a,#0,d5
mov 43h,#99
jmp d10
d2 :dec 40h
jmp d10
d3 :dec 41h
jmp d10
d4 :dec 42h
jmp d10
d5 :dec 43h
d10 :ret
cnco :mov a,40h ;顯示代碼換算
mov b,#10
div ab
mov 30h,b
mov 31h,a
mov a,41h
mov b,#10
div ab
mov 32h,b
mov 33h,a
mov a,42h
mov b,#10
div ab
mov 34h,b
mov 35h,a
mov a,43h
mov b,#10
div ab
mov 36h,b
mov 37h,a
mov a,37h ;等于零不顯示
cjne a,#0,m0
mov 37h,#17
mov a,36h
cjne a,#0,m0
mov 36h,#17
mov a,35h
cjne a,#0,m0
mov 35h,#17
mov a,34h
cjne a,#0,m0
mov 34h,#17
mov a,33h
cjne a,#0,m0
mov 33h,#17
mov a,32h
cjne a,#0,m0
mov 32h,#17
mov a,31h
cjne a,#0,m0
mov 31h,#17
m0 :ret
disp :clr p2.2 ;第一位(個位) 掃描顯示子程序
clr p2.3
clr p2.4
mov a,30h
acall dispa
mov p0,#
00h
setb p2.2 ;第二位(十位)
clr p2.3
clr p2.4
mov a,31h
acall dispa
mov p0,#00h
clr p2.2 ;第三位(百位)
setb p2.3
clr p2.4
mov a,32h
acall dispa
mov p0,#00h
setb p2.2 ;第四位(千位)
setb p2.3
clr p2.4
mov a,33h
acall dispa
mov p0,#00h
clr p2.2 ;第五位(萬位)
clr p2.3
setb p2.4
mov a,34h
acall dispa
mov p0,#00h
setb p2.2 ;第六位(十萬位)
clr p2.3
setb p2.4
mov a,35h
acall dispa
mov p0,#00h
clr p2.2 ;第七位(百萬位)
setb p2.3
setb p2.4
mov a,36h
acall dispa
mov p0,#00h
setb p2.2 ;第八位(千萬位)
setb p2.3
setb p2.4
mov a,37h
acall dispa
mov p0,#00h
ret
dispa:mov dptr,#dat ;取表子程序
movc a,@a+dptr
mov p0,a
delay:mov r6,#5 ;顯示延時
de1 :mov r7,#10
de2 :dec r7
cjne r7,#0,de2
djnz r6,de1
ret
dat :DB 03FH,006H,05BH,04FH,066H,06DH,07DH,007H,07FH,06FH,077H,07CH,039H,05EH,079H,071H,40h,00h
end
