標(biāo)題: 單片機(jī)+74HC390頻率檢測計源程序+Proteus仿真 [打印本頁]
作者: 浮云般飄散    時間: 2020-4-26 18:47
單片機(jī)代碼如下
  1. #include <reg52.h>
  2. unsigned long int fre;
  3. unsigned char time;
  4. unsigned int count;
  5. unsigned int count1;
  6. sbit   LCD_RS=P1^0;          //片選信號
  7. sbit   LCD_RW=P1^1;          //讀寫信號
  8. sbit   LCD_E=P1^2;           //使能信號
  9. #define LCD_DB  P0        //數(shù)據(jù)信號
  10. unsigned char character[10]={0};//在屏幕上顯示的字符串
  11. unsigned char character_1[]={"fre= Hz"};
  12. unsigned char FLAG = 0;  //是否分頻選擇標(biāo)志
  13. void LCD_init(void);//初始化函數(shù)
  14. void LCD_write_command(unsigned char command);//寫指令函數(shù)
  15. void LCD_write_data(unsigned char dat);//寫數(shù)據(jù)函數(shù)
  16. void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat);//在某個屏幕位置上顯示一個字符,X(0-15),y(1-2)
  17. void delay_n40us(unsigned int n);//延時函數(shù)
  18. void timer_init();            //中斷初始化函數(shù)
  19. //-----------------------------延時函數(shù)---------------------------
  20. void delay_n40us(unsigned int n)                  //延時函數(shù)
  21. {
  22.         unsigned int i;
  23.         unsigned char j;
  24.         for(i=n;i>0;i--)
  25.         for(j=0;j<2;j++);
  26. }
  27. void delay_1s()
  28. {
  29.         unsigned int i,j;
  30.         for(i = 0;i<100;i++)
  31.                 for(j = 0;j<1000;j++);
  32. }
  33. //---------------------lcd1602液晶顯示函數(shù)--------------------
  34. void LCD_init(void)         //液晶初始化函數(shù)
  35. {
  36.         LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
  37.         LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
  38.         LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
  39.         LCD_write_command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
  40.         LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
  41.         LCD_write_command(0x01);//清除屏幕顯示
  42.         delay_n40us(100);//清屏延時
  43. }
  44. void LCD_write_command(unsigned char dat)  //寫命令函數(shù)
  45. {
  46.         LCD_DB=dat;
  47.         LCD_RS=0;//指令
  48.         LCD_RW=0;//寫入
  49.         LCD_E=1; //使能
  50.         LCD_E=0;
  51.         delay_n40us(1);//寫命令延時
  52. }
  53. void LCD_write_data(unsigned char dat)          //寫數(shù)據(jù)函數(shù)
  54. {
  55.         LCD_DB=dat;
  56.         LCD_RS=1;//數(shù)據(jù)
  57.         LCD_RW=0;//寫入
  58.         LCD_E=1;//使能
  59.         LCD_E=0;
  60.         delay_n40us(1);         //寫數(shù)據(jù)延時
  61. }
  62. void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat)//顯示一個字符
  63. {
  64.         unsigned char address;
  65.         if(y==1)
  66.                  address=0x80+x;         //顯示在第一排的時候的x的地址
  67.         else
  68.                  address=0xc0+x;         //顯示在第二排的時候的x的地址
  69.         LCD_write_command(address);         //輸入地址
  70.         LCD_write_data(dat);                 //輸入數(shù)據(jù)
  71. }
  72. void LCD_disp_num(unsigned char x,unsigned char y,unsigned char dat)//顯示一個數(shù)字
  73. {
  74.         unsigned char address;
  75.         if(y==1)
  76.                  address=0x80+x;         //顯示在第一排的時候的x的地址
  77.         else
  78.                  address=0xc0+x;         //顯示在第二排的時候的x的地址
  79.         LCD_write_command(address);         //輸入地址
  80.         LCD_write_data(dat+48);                 //輸入數(shù)據(jù)
  81. }
  82. void dis_num(void)
  83. {
  84.         unsigned char i=0,j=0,k=0;
  85.         LCD_write_command(0x01);//清除屏幕顯示
  86.         character[0] = fre/10000000;
  87.         character[1] = fre/1000000%10;
  88.         character[2] = fre/100000%10;
  89.         character[3] = fre/10000%10;
  90.         character[4] = fre/1000%10;
  91.         character[5] = fre/100%10;
  92.         character[6] = fre/10%10;
  93.         character[7] = fre%10;
  94.     character[8] = 'H';
  95.         character[9] = 'z';
  96.         for(i = 0;i<4;i++)                 //顯示“fre=”
  97.         {
  98.                  LCD_disp_char(i+0,1,character_1[i]);
  99.         }
  100.         for(i = 0;i<10;i++)         //判斷第一個不為0的數(shù)
  101.         {
  102.                 if(character[i]!=0)
  103.                         break;
  104.         }
  105.         k = 8-i;
  106.         for(j = 0;j<k;j++)         //顯示所有的數(shù)字
  107.         {
  108.                         LCD_disp_num(4+j,1,character[i++]);
  109.         }
  110.     for(i = 5;i<7;i++)         //顯示“Hz”
  111.         {
  112.                  LCD_disp_char(j+4,1,character_1[i]);
  113.                 j++;
  114.         }
  115. }
  116. //----------------主函數(shù)--------------------
  117. void main()
  118. {
  119.         unsigned char i;
  120.         LCD_init();
  121.         timer_init();             //定時/計數(shù)器初始化
  122.         for(i = 0;i<4;i++)
  123.         {
  124.                  LCD_disp_char(i+0,1,character_1[i]);
  125.         }
  126.         while(1)
  127.         {
  128.                 dis_num();         //顯示
  129.                 delay_1s();
  130.         }
  131. }
  132. //-------------------定時/計數(shù)器初始化--------------
  133. void timer_init(void)         //定時/計數(shù)器初始化
  134. {
  135.         TMOD=0x66;                //計數(shù)器0和計數(shù)器1工作工作方式2,自動重裝初值
  136.         TH0=0;                    //計數(shù)器初值為0
  137.         TL0=0;
  138.         TR0=1;                    //計數(shù)器開始計數(shù)
  139.         ET0=1;                    //打開計數(shù)器0中斷
  140.         TH1=0;                    //計數(shù)器初值為0
  141.         TL1=0;
  142.         TR1=1;                    //計數(shù)器開始計數(shù)
  143.         ET1=1;                    //打開計數(shù)器1中斷
  144.         RCAP2H=(65536-62500)/256; //在程序初始化的時候給RCAP2L和RCAP2H賦值,
  145.         RCAP2L=(65536-62500)%256; //TH2和TL2將會在中斷產(chǎn)生時自動使TH2=RCAP2H,TL2=RCAP2L。
  146.         TH2=RCAP2H;               //12M晶振下每次中斷62.5ms(1s=1000ms=62.5ms×16)
  147.         TL2=RCAP2L;
  148.         ET2=1;                    //打開定時器2中斷
  149.         TR2=1;                    //定時器2開始計時
  150.         EA=1;                     //開總中斷
  151. }
  152. //------------------中斷函數(shù)----------------------
  153. void timer2(void) interrupt 5 //定時器2中斷(62.5ms)
  154. {
  155.         time++;
  156.         TF2=0;                    //定時器2的中斷標(biāo)志位TF2不能夠由硬件清零,所以要在中斷服務(wù)程序中將其清零
  157.         if (time==16)             //定時1s時間到
  158.         {
  159.            time=0;                //計時清0
  160.            EA=0;                  //關(guān)中斷
  161.            fre=(long)count1*256+TL1;     //count*256強(qiáng)制轉(zhuǎn)換成long型,否則將不產(chǎn)生進(jìn)位~先判斷分頻后(計數(shù)器1)
  162.            FLAG = 0;
  163.
  164.            if(fre<2000)//如果不到200KHz則讀取分頻前(計數(shù)器0)頻率(200K÷100=2000)
  165.            {
  166.                            fre = (long)count*256+TL0;
  167.                         FLAG = 1;
  168.            }
  169.                 if(!FLAG)
  170.                 {
  171.                         fre = fre *100;//100分頻
  172.                 }
  173.            TL0=0;                 //清零計數(shù)器0計數(shù)
  174.            TH0=0;
  175.            TL1=0;
  176.            TH1=0;
  177.            count=0;               //清零計數(shù)器0計數(shù)
  178.            count1=0;
  179.            EA=1;                  //開中斷
  180.         }
  181. }
  182. //--------------------------------------------------------------
  183. void timer0(void) interrupt 1 //計數(shù)器0中斷(100分頻前)
  184. {
  185.         count++;
  186. }
  187. //----------------------------------------------------------------
  188. void timer1(void) interrupt 3 //計數(shù)器1中斷(100分頻后)
  189. {
  190.         count1++;
  191. }
單片機(jī)頻率計.rar (3.91 MB, 下載次數(shù): 17)
