標(biāo)題: 各位大佬,小弟看了4,5天實(shí)在是不知道該怎么改這個(gè)單片機(jī)代碼 [打印本頁(yè)]
作者: 求學(xué)小弟    時(shí)間: 2020-4-13 21:06
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  _INTTOSTR
    MODULE:  main.obj (MAIN)
    SYMBOL:  _READ_DATA
    SYMBOL:  ?_READ_DATA?BYTE
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
    ADDRESS: 0D84H
    SYMBOL:  _READ_DATA
    ADDRESS: 0DAFH
    SYMBOL:  _INTTOSTR
    ADDRESS: 0DC4H
    SYMBOL:  _INTTOSTR
    ADDRESS: 0DF0H
    SYMBOL:  _INTTOSTR
    ADDRESS: 0E1CH
    SYMBOL:  _INTTOSTR
    ADDRESS: 0E48H
#include<reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
#include<stdio.h>
#include "18b20.h"
#include "1602.h"
#include "delay.h"
#include "i2c.h"
unsigned char dis0[17];      //打印數(shù)組初始化
unsigned long time_20ms=0;     //定時(shí)器計(jì)數(shù)
unsigned char sendata[22]={0};     //串口發(fā)送數(shù)組
unsigned char tempdata[4]={0};     //臨時(shí)變量數(shù)組
unsigned char Read_Data(int *SuDu,int *Send_temperature,int *Send_Volt,int *Send_Acurrent);
unsigned char ReadTempFlag=0;//定義讀時(shí)間標(biāo)志
int temp1;      //讀取溫度初始值
float temperature;    //實(shí)際溫度值
float Volt=0.0;     //檢測(cè)電壓
float Acurrent=0.0;      //檢測(cè)電流
unsigned int PluNum;   //脈沖計(jì)數(shù)
unsigned char ReadSuDu=0;  //讀取速度標(biāo)志
int SuDu;       //速度值
int Send_temperature ;    //發(fā)送上位機(jī)的溫度*10
int Send_Volt;        // 發(fā)送上位機(jī)的電壓*10
int Send_Acurrent;       // 發(fā)送上位機(jī)的電流*100
void Init_Timer0(void);  //函數(shù)聲明
void uartSendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void uartSendByte(unsigned char dat);
void IntToStr(int value, unsigned char *buf);    //int型轉(zhuǎn)字符串
void main (void)
Init_Timer0();        //定時(shí)器0初始化
UART_Init();
EX0=1;         //外部中斷0開(kāi)
IT0=1;         //邊沿觸發(fā)
    EA=1;          //全局中斷開(kāi)
LCD_Init();           //初始化液晶
DelayMs(20);          //延時(shí)有助于穩(wěn)定
LCD_Clear();
DelayMs(200);
uartSendStr("reday ok!!",10);
while (1)         //主循環(huán)
  Volt=(float)ReadADC(1)*5.0/255*5;  //計(jì)算出電壓 *5表示分壓值 八位ad轉(zhuǎn)換
  DelayMs(2);          //延時(shí)有助于穩(wěn)定
  Acurrent=(float)ReadADC(0)*5.0/255;  //計(jì)算出電流
  if(Acurrent>2.6)    //如果電流轉(zhuǎn)換后的電壓值超過(guò)2.62
  {Acurrent=(Acurrent-2.6)*2/0.185;}  //電流模塊 電壓轉(zhuǎn)換計(jì)算
  {Acurrent=0;}
  Send_temperature=temperature *10;
  Send_Volt=Volt *10;
  Send_Acurrent=Acurrent *100;
   sprintf(dis0,"S:%3dr/m T:%4.1fC",SuDu,temperature);//打印電壓電流值
   LCD_Write_String(0,0,dis0);//顯示第二行
   sprintf(dis0,"V:%3.1fv A:%3.2fA ",Volt*76,Acurrent*2);//打印電壓電流值
   LCD_Write_String(0,1,dis0);//顯示第二行
            Read_Data(&SuDu,&Send_temperature,&Send_Volt,&Send_Acurrent);
   sendata[0] = 0xFE;
   IntToStr(SuDu, tempdata);//   速度數(shù)據(jù)封包函數(shù)
   sendata[1]= tempdata[0];
   sendata[2]= tempdata[1];
   sendata[3]= tempdata[2];
   sendata[4]= tempdata[3];
   sendata[5] = 0x0A;
   IntToStr(Send_temperature, tempdata);//   溫度數(shù)據(jù)封包函數(shù)
   sendata[6]= tempdata[0];
   sendata[7]= tempdata[1];
   sendata[8]= tempdata[2];
   sendata[9]= tempdata[3];
   sendata[10] = 0x0A;
     IntToStr(Send_Volt, tempdata);//   電壓數(shù)據(jù)封包函數(shù)
   sendata[11] = tempdata[0];
   sendata[12] = tempdata[1];
   sendata[13] = tempdata[2];
   sendata[14] = tempdata[3];
   sendata[15] = 0x0A;
   IntToStr(Send_Acurrent, tempdata);//   電流數(shù)據(jù)封包函數(shù)
   sendata[16] = tempdata[0];
   sendata[17] = tempdata[1];
   sendata[18] = tempdata[2];
   sendata[20]=  tempdata[3];
   sendata[21] = 0x0D;
   if(sendata[1]==0x30)    //對(duì)速度高位是否為零進(jìn)行判斷
     sendata[1]=' ';
   if(sendata[6]==0x30)    //對(duì)溫度高位是否為零進(jìn)行判斷
     sendata[6]=' ';
   if(sendata[11]==0x30)       //對(duì)電壓高位是否為零進(jìn)行判斷
     sendata[11]=' ';
   if(sendata[16]==0x30)    //對(duì)電流高位是否為零進(jìn)行判斷
     sendata[16]=' ';
   uartSendStr(sendata,22);
  if(ReadTempFlag==1)  //讀取溫度標(biāo)志
   ReadTempFlag=0;
   temp1=ReadTemperature(); //讀取溫度
   temperature=(float)temp1*0.0625;   //溫度值轉(zhuǎn)換
  if(ReadSuDu==1)     //處理速度
   ReadSuDu=0;
   SuDu=(float)PluNum*15;  //1個(gè)脈沖1圈   5s一次
   PluNum=0;       //周期脈沖清空
  DelayMs(40);          //延時(shí)有助于穩(wěn)定
                 外部中斷程序
void ISR_Key(void) interrupt 0 using 1
PluNum++;   //外部中斷清空計(jì)數(shù)
TMOD |= 0x01;   //使用方式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
TH0=(65536-20000)/256;    //重新賦值 20ms
TL0=(65536-20000)%256;
EA=1;            //總中斷打開(kāi)
ET0=1;           //定時(shí)器中斷打開(kāi)
TR0=1;           //定時(shí)器開(kāi)關(guān)打開(kāi)
void Timer0_isr(void) interrupt 1
time_20ms++;
   if(time_20ms%200==0)    //定時(shí)處理速度
  ReadSuDu=1; //讀標(biāo)志位置1
if(time_20ms%10==0)   //讀取溫度
  ReadTempFlag=1; //讀標(biāo)志位置1
    SCON  = 0x50;          // SCON: 模式 1, 8-bit UART, 使能接收
    TMOD |= 0x20;               // TMOD: timer 1, mode 2, 8-bit 重裝
    TH1   = 0xFD;               // TH1:  重裝值 9600 波特率 晶振 11.0592MHz
TL1 = TH1;
    TR1   = 1;                  // TR1:  timer 1 打開(kāi)
    EA    = 1;                  //打開(kāi)總中斷
    ES    = 1;                  //打開(kāi)串口中斷
unsigned char time_out;
time_out=0x00;
SBUF = dat;     //將數(shù)據(jù)放入SBUF中
while((!TI)&&(time_out<100))  //檢測(cè)是否發(fā)送出去
{time_out++;DelayUs2x(10);} //未發(fā)送出去 進(jìn)行短暫延時(shí)
TI = 0;      //清除ti標(biāo)志
unsigned char NUM;
NUM=0x00;
while(NUM<length) //發(fā)送長(zhǎng)度對(duì)比
  uartSendByte(*s);  //放松單字節(jié)數(shù)據(jù)
  s++;    //指針++
  NUM++;    //下一個(gè)++
void UART_SER (void) interrupt 4  //串行中斷服務(wù)程序
if(RI)                        //判斷是接收中斷產(chǎn)生
  RI=0;                      //標(biāo)志位清零
if(TI)  //如果是發(fā)送標(biāo)志位,清零
TI=0;
作者: csmyldl    時(shí)間: 2020-4-14 00:12
要修改別人的程序,先要把程序的思路理清楚,然后進(jìn)行仿真調(diào)試,不是拷貝編譯沒(méi)錯(cuò)就不知道如何進(jìn)行了
作者: 求學(xué)小弟    時(shí)間: 2020-4-14 09:07
csmyldl 發(fā)表于 2020-4-14 00:12
他總說(shuō),我讀數(shù)據(jù)的時(shí)候,有read_data函數(shù),和 inttostr函數(shù)沒(méi)有定義,可是我定義了啊,還是不對(duì)啊,還求各位大神幫幫忙
作者: devcang    時(shí)間: 2020-4-14 09:15
看好幾個(gè)提示,都是缺少函數(shù)體的,所以應(yīng)該知道如何處理了吧
作者: 求學(xué)小弟    時(shí)間: 2020-4-14 09:29
devcang 發(fā)表于 2020-4-14 09:15
多謝多謝&#128076;我試試,可是我看一個(gè)人的教程他好像并沒(méi)有對(duì)這兩個(gè)函數(shù)進(jìn)行函數(shù)體的編寫(xiě)啊
作者: man1234567    時(shí)間: 2020-4-26 12:26
這句日單片機(jī)看不懂的。
