標題: STM32F103C8T6+HX711壓力傳感器串口輸出數據程序 [打印本頁]
作者: 李時珍的皮123    時間: 2020-4-7 22:37
        main.c
#include "stm32f10x.h"
#include "delay.h"
#include "HX711.h"
#include "usart.h"
int main(void)
        Init_HX711pin();
        delay_init();
        NVIC_Configuration();          //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
        uart_init(9600);         //串口初始化為9600
        Get_Maopi();                                //稱毛皮重量
        delay_ms(1000);
        delay_ms(1000);
        Get_Maopi();                                //重新獲取毛皮重量
                Get_Weight();
                printf("凈重量 = %d g\r\n",Weight_Shiwu); //打印
                delay_ms(1000);
HX711.h
#ifndef __HX711_H
#define __HX711_H
#include "sys.h"
//壓力傳感器接口定義
#define HX711_SCK PBout(0)// PB0
#define HX711_DOUT PBin(1)// PB1
extern void Init_HX711pin(void);
extern u32 HX711_Read(void);
extern void Get_Maopi(void);
extern void Get_Weight(void);
extern u32 HX711_Buffer;
extern u32 Weight_Maopi;
extern s32 Weight_Shiwu;
extern u8 Flag_Error;
#endif
HX711.c
#include "HX711.h"
#include "delay.h"
u32 HX711_Buffer;
u32 Weight_Maopi;
s32 Weight_Shiwu;
u8 Flag_Error = 0;
//校準參數
//因為不同的傳感器特性曲線不是很一致,因此,每一個傳感器需要矯正這里這個參數才能使測量值很準確。
//當發現測試出來的重量偏大時,增加該數值。
//如果測試出來的重量偏小時,減小改數值。
//該值可以為小數
#define GapValue 106.5
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能PF端口時鐘
        //HX711_SCK
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                                 // 端口配置
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據設定參數初始化GPIOB
        //HX711_DOUT
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//輸入上拉
        GPIO_SetBits(GPIOB,GPIO_Pin_0);                                        //初始化設置為0
//讀取HX711
u32 HX711_Read(void)        //增益128
        unsigned long count;
        unsigned char i;
          HX711_DOUT=1;
        delay_us(1);
          HX711_SCK=0;
          count=0;
          while(HX711_DOUT);
          for(i=0;i<24;i++)
                  HX711_SCK=1;
                  count=count<<1;
                delay_us(1);
                HX711_SCK=0;
                  if(HX711_DOUT)
                        count++;
                delay_us(1);
         HX711_SCK=1;
    count=count^0x800000;//第25個脈沖下降沿來時,轉換數據
        delay_us(1);
        HX711_SCK=0;
        return(count);
//獲取毛皮重量
        Weight_Maopi = HX711_Read();
//稱重
        HX711_Buffer = HX711_Read();
        if(HX711_Buffer > Weight_Maopi)
                Weight_Shiwu = HX711_Buffer;
                Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實物的AD采樣數值。
                Weight_Shiwu = (s32)((float)Weight_Shiwu/GapValue);         //計算實物的實際重量
        //因為不同的傳感器特性曲線不一樣,因此,每一個傳感器需要矯正這里的GapValue這個除數。
全部資料51hei下載地址:
STM32驅動程序-HX711.7z (543.66 KB, 下載次數: 155)
作者: hominidclint    時間: 2020-4-9 20:54
正在學習STM32,感謝分享
