這個單片機程序如何修改?lcd12864,做一個飛鳥動畫
misitek
2020-4-3 09:57
求大佬幫,lcd12864,做一個飛鳥動畫,左右移動的是候會因為lcd12864分屏的緣故,導致動畫效果分離
附件里面是代碼加原理圖,用的模塊化比較清楚
(175.54 KB, 下載次數: 54)
2020-4-3 09:52 上傳
main部分:
#include "lcd12864.h"
#define uint unsigned char
uchar code zhang[] = {0x20,0x20,0x24,0xA4,0xAC,0xB4,0xA5,0xA6,0xA4,0xB4,0xAC,0xA4,0x24,0x20,0x20,0x00,
0x20,0x20,0x20,0x2F,0x2A,0x2A,0x2A,0xFA,0x2A,0x2A,0x2A,0x2F,0x20,0x20,0x20,0x00
unsigned char code table1[][64]={/*-- ???????:D:\Desktop\????? (2)\1.bmp --*/
/*-- ??x??=128x64 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0xD0,0xE0,0xE0,0xC0,0xF0,0xF8,0xFC,0xF8,
0xF8,0xB8,0x3C,0x78,0xF0,0xFA,0xFC,0xFC,0xCC,0x1E,0x3C,0xF8,0xF0,0xE0,0xD0,0x00,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x28,0xFE,0xFE,0xFB,0x73,0x77,0x66,0x4D,0x4D,0xD9,
0x91,0x11,0x03,0x02,0x00,0x00,0x01,0x01,0x01,0x03,0x06,0x04,0x01,0x03,0x03,0x06,
0x0F,0x1E,0x18,0x3E,0x38,0x40,0xF0,0xE0,0xE0,0xC0,0x20,0x80,0x00,0x00,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x1F,0x3F,0x7F,0xF2,0xF6,0xF4,0x80,
0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x91,0xE1,0xE3,0xC3,0xC7,0x83,0x87,0x07,
0x0F,0x1F,0x1C,0x78,0xF0,0xE0,0xE0,0xC0,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x20,0x80,0xC0,0xF0,0xF0,0x60,0x70,0x70,0x30,0x30,0x70,0x70,
0xC0,0xD0,0xF0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x07,0x1F,
0x1F,0xBE,0xBE,0xF0,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x0E,0x0E,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFE,0xFC,0xF8,0xF9,0xF3,0xF7,0xE7,0xCF,0xCE,0xDE,0x9E,0xBE,0x3E,0x18,
0x1E,0x0C,0x0F,0x07,0x03,0x03,0x81,0xE1,0xE0,0xE0,0xF0,0xFC,0xFD,0xBF,0x9F,0x5F,
0x1E,0x1D,0x1F,0x1F,0x1F,0x2D,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x07,0x05,0x01,0x07,0x3F,0x1E,0x7C,0x3C,0x78,0x78,0xE0,0xE0,
0xC0,0xC0,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x07,0xDF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0x5F,0x0F,0x07,0x02,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x00,0x03,0x07,0x07,0x07,0x07,0x07,0x0F,0x8E,0x2C,0x9C,0xCC,0xEC,0xEC,0xFC,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,
0x7F,0x9F,0x1F,0x1F,0x3F,0x1F,0x0F,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x80,
0xC0,0xE0,0xF0,0xF8,0x7C,0x38,0x8E,0x4F,0x67,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0x3F,0xBF,0x7F,0x2F,0x0F,0x2F,0x3F,0x07,0x0F,0x0F,0x07,0x03,0x03,0x00,0x03,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xBA,0xFC,0xFE,0xFF,0xE7,
0xF7,0xF3,0xF9,0xFC,0x7E,0x7D,0x3E,0x1E,0x0F,0x0F,0x0F,0x07,0x02,0x04,0x01,0x00,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code table2[][64]={/*-- ???????:D:\Desktop\????? (2)\2.bmp --*/
0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x40,0x80,0x80,0xA0,0x80,0xA0,0xE0,
0xE0,0xE0,0xC0,0xA0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xD0,0xE0,
0xF0,0xE0,0xF8,0x7E,0x7F,0x3F,0x3F,0x3F,0x3F,0x3F,0x7F,0x7F,0x43,0x03,0x23,0x03,
0x07,0x07,0x0F,0x0F,0x1F,0x7F,0xFE,0xFE,0xFC,0xE8,0x80,0xA0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xD0,0xF5,0xFF,
0xFF,0x7F,0x2F,0x03,0x21,0x21,0x02,0x00,0x00,0x08,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x0F,0x1F,0x3F,0x3F,0x3F,0x7F,0xFD,0xF8,0xF0,
0xF8,0xD0,0xC0,0xE0,0xF0,0xF0,0x78,0x78,0x30,0x30,0x18,0x98,0xD0,0xD0,0xD8,0x98,
0xF0,0x78,0xF8,0xF0,0xC0,0xD0,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xD0,0xFD,0xFF,0xFF,0xFF,
0xFF,0x7E,0x5A,0x20,0x61,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x20,0xE0,0x60,0x30,0xC0,0x90,0x88,0x8F,0x0F,
0x07,0x03,0x03,0x01,0x01,0x80,0x80,0xF0,0xF0,0xF8,0xFA,0xFF,0x7F,0x3F,0x3F,0x1F,
0x07,0x07,0x07,0x0F,0x07,0x07,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x01,0x17,0x27,0x9F,
0xFF,0xFD,0xF6,0xC6,0xC3,0x82,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,
0xF0,0xF0,0xF8,0xFC,0xFC,0xFE,0xFD,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFE,0xFE,0xFE,0xFC,0xFC,0xFE,0x3E,0x1F,0x0F,0x0F,0x05,0x00,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,
0xD1,0xF4,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFE,0xFE,0xF8,0xFE,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0xFF,0x7F,0x1F,0x5F,0x1F,0x3F,
0x1F,0x0F,0x0F,0x07,0x0B,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE8,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x3F,0x1F,0x0B,
0x03,0x0B,0x07,0x01,0x01,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2D,0x1F,0x1F,0xBF,
0xFF,0xFF,0xFF,0xFF,0xFF,0x5F,0x1F,0x0B,0x01,0x05,0x01,0x00,0x00,0x00,0x00,0x00,
unsigned char code table3[][64]={/*-- ???????:D:\Desktop\????? (2)\3.bmp --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x80,0xC0,0xC0,0x80,
0x00,0x40,0x80,0x80,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0x5F,0x7F,0xFF,0xFD,0xF7,
0xF7,0xEF,0xCF,0x9F,0x97,0x03,0x03,0x03,0x03,0x07,0x3F,0x7D,0x78,0x72,0xC0,0xC0,
0xC0,0xE0,0xC0,0x80,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,
0x01,0x05,0x07,0x01,0x17,0x1F,0x1F,0x0E,0xBC,0xF8,0xE8,0xC0,0x80,0x00,0x00,0x00,
0x00,0x01,0x01,0x03,0x03,0x0F,0x3F,0x7C,0xF4,0xC0,0xF0,0xC0,0x80,0x80,0x80,0xE0,
0xC0,0xE0,0xC0,0xF0,0xE0,0x70,0x60,0x38,0x30,0x18,0x18,0x10,0x10,0xD0,0xD8,0xD0,
0xB8,0x70,0xF8,0xF0,0xE0,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF4,0xFE,0xFF,0xEF,0xFB,0xF4,0xF0,0xF0,0x80,
0x00,0x00,0x7C,0xFC,0xE8,0xE0,0xE8,0xF0,0xE0,0xF1,0xF3,0xF3,0xE1,0xE1,0xE1,0xE0,
0xF0,0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0xF8,0xF8,0xFC,0xFE,0xFF,0x7F,0x0F,0x2F,0x17,
0x07,0x07,0x0F,0x07,0x07,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x8E,0xDF,0xFF,0xFF,0x7F,0x7F,0x7F,0xBF,0x93,0xFF,0xFF,
0xFF,0xEE,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x7F,0x3F,0x5F,0x0F,0x07,0x02,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xF4,0xF8,0xFD,0xFF,0x87,0x01,0x00,0x00,0x82,0xE6,0xE7,0xFF,0x7F,0x7F,
0x7F,0xFF,0xFF,0xFF,0xBF,0x1F,0x1F,0x1F,0x1F,0x2F,0x0F,0x17,0x07,0x07,0x03,0x0B,
0x05,0x04,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,
0xE0,0xE4,0xFE,0xFF,0xFF,0xF9,0xFC,0xFE,0xFE,0xFF,0xBF,0x13,0x09,0x01,0x02,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5A,0x3B,
0x7F,0x7F,0x2F,0x6F,0x4F,0x1F,0x0B,0x03,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code table4[][64]={/*-- ???????:D:\Desktop\????? (2)\4.bmp --*/
0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
0x80,0xC0,0x80,0x80,0x80,0xC0,0xC0,0xE0,0xC0,0xE0,0xC0,0xC0,0x80,0xC0,0xE0,0xE0,
0x60,0x70,0x70,0x70,0x78,0x78,0x30,0x30,0x30,0x18,0x1C,0x18,0x1E,0x3C,0x3C,0x3C,
0x1A,0x5A,0x58,0x7E,0x7C,0xBE,0xBE,0xFE,0xFC,0x7A,0x00,0x74,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
0xD0,0xD8,0xFC,0x9E,0x8F,0xA7,0xF3,0xFB,0xF9,0xFD,0xFD,0xFC,0xFC,0xFC,0xFC,0xFC,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x1F,0x0D,0x09,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xA0,0xA0,0xF0,
0xF4,0x75,0x35,0x7D,0x7D,0x3F,0x1E,0x07,0x0B,0x00,0x00,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x80,0xC0,0xE0,0xF8,0xFE,
0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x8F,0x07,
0x07,0x0F,0x0F,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x04,
0xA0,0xA0,0xE0,0x61,0x6D,0x6D,0x3D,0xDD,0x19,0x1D,0x0F,0x1B,0x0B,0x03,0x01,0x01,
0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xA0,0xC0,0xE8,0xF0,0x78,0x3C,0x1C,0x0E,0x87,0x87,0x83,0x81,0xC1,0xF1,0xFC,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xF4,
0xF0,0xE0,0x70,0x38,0x78,0x38,0x18,0x1C,0x1C,0x1C,0x1C,0x0C,0x1F,0x0F,0x03,0x07,
0x01,0x07,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xD0,0xDD,0xFF,
0x7F,0x3F,0x01,0x00,0x00,0x00,0x00,0x00,0xD0,0xE8,0xE7,0xBF,0x9F,0x1F,0x3F,0x3F,
0x1F,0x2F,0x0F,0x17,0x07,0x07,0x07,0x07,0x07,0x0F,0x07,0x03,0x07,0x07,0x03,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x80,0xE8,0xFC,0xFE,0x7F,0xEF,0xF7,0x81,
0xC8,0xFC,0xFA,0xFE,0xFA,0xFE,0xFF,0x5F,0x07,0x0B,0x03,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0x07,0x0F,0x0F,0x07,0x0F,0x07,0x07,0x01,
0x01,0x03,0x01,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code table5[][64]={/*-- ???????:D:\Desktop\????? (2)\5.bmp --*/
0xC0,0xC0,0xE0,0xF0,0xF0,0x78,0x60,0x3E,0x18,0x1E,0x1E,0x0C,0xEE,0x6E,0x6E,0x4C,
0xFE,0xFC,0xFE,0xFC,0xF8,0xF8,0xE0,0xC0,0x80,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,
0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0xC0,0x00,0xC0,
0x80,0xE0,0xE0,0xF0,0x60,0x68,0x60,0x3C,0x38,0x18,0x18,0x0E,0x08,0x0F,0x04,0x06,
0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x1D,0x1F,0x1F,0x1F,0x0F,
0x0F,0x0F,0x0F,0x07,0x07,0x07,0x07,0x03,0x07,0x07,0x07,0x03,0x03,0x07,0x07,0x07,
0x0F,0x0F,0x0B,0x1E,0x1F,0x1F,0x3E,0x3E,0x38,0x38,0x38,0x38,0x78,0xF0,0xF8,0xD0,
0x80,0x80,0xC0,0x80,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0x70,0x3C,0x1E,0x0F,0x0F,0x07,0x47,0x03,0x01,
0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x80,0xC0,0xC0,0xE0,0xE0,0xE0,0xF0,0x70,0x70,0x30,0x30,0x38,0x38,0x38,0x78,0x38,
0x38,0x38,0x38,0x38,0x78,0x78,0x38,0x30,0x30,0x70,0x30,0x70,0x70,0xF0,0x70,0x70,
0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0x30,0xB0,0x78,0x78,0x7C,0x7D,0x7D,0x3D,
0x1F,0x3F,0x1F,0x0F,0x17,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x68,
0xFA,0xFC,0xFD,0xFF,0x7F,0x25,0x04,0x80,0x80,0xC0,0xE0,0x70,0x36,0xFE,0x7E,0xFC,
0x5C,0x1C,0x1C,0x3C,0x1C,0x1C,0x0C,0x1C,0x0C,0x04,0x0E,0x1E,0x0E,0x0F,0x0F,0x1F,
0x1F,0x1F,0x0F,0x07,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE8,0xF0,0xFD,0xFF,
0xFF,0xFF,0xFF,0xFC,0x7E,0x3E,0x0F,0x0F,0x05,0x01,0x03,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x16,0x0F,0x17,0x17,0x17,
0x07,0x1F,0x03,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code table6[][64]={/*-- ???????:D:\Desktop\????? (2)\6.bmp --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x80,0xC0,0xC0,0x80,0x80,
0xE0,0xF0,0xF0,0x78,0x30,0x3C,0x1E,0x0F,0x0F,0x67,0xE7,0xF7,0xF7,0xF6,0xF7,0xEF,
0xDC,0xFC,0xFA,0xE0,0xE8,0xD0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0xC0,0xC0,0xC0,0xE0,0xF0,0x60,0x70,
0x78,0x3C,0x38,0x18,0x1C,0x0E,0x0C,0x0E,0x04,0x03,0x03,0x03,0x03,0x03,0x01,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x3C,0x3F,0x3F,0x7F,0x7F,0x71,
0x71,0x71,0x71,0x61,0x71,0x62,0x60,0xE0,0xE0,0xC0,0xE0,0xC0,0xC0,0x00,0x40,0x80,
0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,
0x80,0x80,0xC0,0x80,0xE0,0xF0,0x60,0xE0,0xF0,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xA0,
0xC0,0xE8,0xF0,0x78,0x3C,0x1C,0x0E,0x0F,0x07,0x03,0x03,0x61,0xE1,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x03,0x03,0x03,0x03,0x07,
0x07,0x07,0x07,0x07,0x06,0x07,0x06,0x26,0x26,0x26,0x37,0x36,0x77,0x77,0x73,0x73,
0x7B,0x79,0x79,0x7D,0x7E,0x7E,0xFF,0x67,0x73,0x59,0xB0,0xF8,0xF0,0xB0,0xB0,0xF0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF2,0xFF,0x7F,
0x3F,0x0D,0x8C,0xC0,0xC0,0xE0,0xF0,0xF0,0x78,0x3C,0x3C,0x06,0x16,0x07,0x06,0x1E,
0x3E,0x1C,0x3C,0x34,0x78,0x78,0x78,0x78,0x70,0x70,0x70,0x70,0x70,0xF0,0x60,0x60,
0x60,0x70,0xF0,0xE0,0xE0,0xE0,0xC0,0xC0,0xC0,0xE0,0x60,0xE0,0xC0,0xC0,0xC0,0xE0,
0xE0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x60,0xE0,0xE0,0xC0,0xC0,0x60,
0x60,0x60,0x60,0x60,0x60,0x60,0x70,0xF0,0x70,0x70,0x70,0x70,0x70,0x78,0x18,0x58,
0x3A,0x1E,0x06,0x1E,0x0E,0x06,0x0F,0x03,0x07,0x03,0x07,0x07,0x03,0x03,0x03,0x03,
0x00,0x00,0x00,0x00,0x00,0x00,0x68,0x00,0x74,0x7D,0xFD,0xFF,0x73,0xF9,0x7C,0x3C,
0x3E,0x0F,0x07,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x01,0x01,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x01,0x00,0x01,0x00,0x00,0x00,0x00,
uchar flag = 0,left_right = 0;
sbit way = P3^4;
sbit dir = P3^5;
void initial_int0()//中斷初始化
IT0 = 1;
EX0 = 1;
EA = 1;
//void change(uchar x,uchar num)//左右或上下方向變化
//if(x == 0)
// num = num + 5;//右,上
//else if(x == 1)
// num = num + 5;//左,下
uchar lie = 0,hang = 0;
InitLCD();
initial_int0();
if(flag == 0)
if(left_right == 0)//右飛
Set_column(lie);
display_BMP(table1,lie);
display_BMP(table2,lie);
display_BMP(table3,lie);
display_BMP(table4,lie);
display_BMP(table5,lie);
display_BMP(table6,lie);
lie = lie +5;
if(lie > 127)
lie = 0;
else//左飛
if(lie < 5)
lie = 127;
Set_column(lie);
lie = lie - 5;
else if(flag == 1)
if(left_right == 0)//上飛
line_start(0,hang);
hang = hang + 5;
if(hang > 63)
hang = 0;
else//下飛
if(hang < 5)
hang = 63;
line_start(0,hang);
hang = hang - 5;
void int0_serv() interrupt 0
if(way == 0)
flag = !flag;
ClearScreen(0);
else if(dir == 0)
left_right = !left_right;
lcd12864.h部分
#ifndef __LCD12864_H__
#define __LCD12864_H__
#include <reg52.h>
#include <intrins.h>
#define LCD_databus P0 //LCD12864的8位數據口
sbit RS=P2^0; //RS為0---命令;1----數據
sbit RW=P2^1; //RW為1---寫;0---讀
sbit EN=P2^2; //使能端
sbit CS1=P2^4; //片選1低電平有效,控制左半屏
sbit CS2=P2^3; //片選1低電平有效,控制右半屏
void delay(unsigned int i);
void Read_busy();
void write_LCD_command(unsigned char value);
void write_LCD_data(unsigned char value);
void Set_page(unsigned char page);
void Set_line(unsigned char startline);
void Set_column(unsigned char column);
void SetOnOff(unsigned char onoff);
void SelectScreen(unsigned char screen);
void ClearScreen(unsigned char screen);
void InitLCD();
void Display(unsigned char ss,unsigned char page,unsigned char column,unsigned char *p);
void display_BMP(unsigned char a[][64],unsigned char column);//顯示圖形的左邊部分
void line_start(unsigned char screen,unsigned char startline);//選屏幕,從哪行開始
#endif
lcd12864.c中的display_BMP部分:
void display_BMP(unsigned char a[][64],unsigned char column)//顯示圖形
unsigned char i,j;
for(j=0;j<8;j++)
SelectScreen(1);
Set_page(j);
Set_column(column);
for(i=0;i<64;i++)
write_LCD_data(a[2*j][i]);//每隔一行取一次數組中的數據
SelectScreen(2);
Set_page(j);
Set_column(column);
for(i=0;i<64;i++)
write_LCD_data(a[2*j+1][i]);//每隔一行取一次數組中的數據
詳情代碼見附件
lc12864.zip
(80.88 KB, 下載次數: 10)
2020-4-3 09:49 上傳
