標題: 單片機煙霧傳感器程序的輸出數(shù)據(jù)不變化 [打印本頁]
作者: 孤仙1233    時間: 2020-3-12 16:49
利用ADC0809模塊轉(zhuǎn)化MQ-2數(shù)據(jù)     然后反饋回來的數(shù)據(jù)無論輸入5V還是接地  數(shù)據(jù)都一樣    求求各位大神幫忙看下   謝謝
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
void ConfigUART (unsigned int baud);
#define adc0809_data  P0  //單片機P0接模塊D0~D7引腳
sbit ST = P2^3; //單片機P2.3接模塊STR引腳, 啟動轉(zhuǎn)換信號
sbit EOC = P2^2; //單片機P2.2接模塊EOC, 轉(zhuǎn)換結(jié)束信號,高電平有效
sbit OE  = P2^1; //單片機P2.1接模塊OE,輸出允許信號,高電平有效
sbit CLK = P2^0; //單片機P2.0接CLK ,ADC0809時鐘,輸入50-800KHZ的頻率
                 //一般選用500K
     //將短接片去掉開啟位選功能,否則默認IN0為輸入引腳
sbit AA = P2^4;  //單片機P2.6接模塊A引腳
//unsigned char Disp[]="0123456789";         //使用字符串保存數(shù)字0~9所對應的ASCLL碼
unsigned char AD_DATA[2]; //保存IN0通道轉(zhuǎn)換后的數(shù)據(jù)
float a,b;
unsigned char i;
  SCON = 0x50;
  //TMOD &= 0X0F;
  TMOD |= 0x20;
  TH1 = 256 - (11059200/12/32) / baud;
  TL1 = TH1;
  ET1 = 0;
  TR1 = 1;
  ES = 1;
  //TR1 = 1;
  void time0()
   TMOD|=0x01;
   TH0=216; //利用T0中斷產(chǎn)生CLK信號
    TL0=216;
    TR0=1; //啟動定時器T0
    ET0=1;
    //ST=0;
    //OE=0;
  // EA = 1;
void UART_T (unsigned char UART_data)//定義串口發(fā)送數(shù)據(jù)變量
    SBUF = UART_data; //將接收的數(shù)據(jù)發(fā)送回去
    while(TI == 0);  //檢查發(fā)送中斷標志位
    TI = 0;       //令發(fā)送中斷標志位為0(軟件清零)
void UART_TC (unsigned char *str)
    while(*str != '\0')  //檢查是否發(fā)送完畢
            UART_T(*str);   //發(fā)送
            *str++;         //指針指向下一個字符
    *str = 0;               //發(fā)送完畢后指針歸零
char putchar(char c)
    UART_T(c);
    return c;
函數(shù)名:  delayms()
功能:    延時 ms 毫秒
void delayms(unsigned int ms)
unsigned char j;
i=100;
for(;ms;ms--)
  while(--i)
   j=10;
   while(--j);
函數(shù)名:  AD()
功能:    啟動AD轉(zhuǎn)換將值儲存于 AD_DATA[0]
void AD(void )
   ST=0;
   AA = 0;  //設置為IN0輸入
   ST=1; //啟動AD轉(zhuǎn)換
delayms(10);
   ST=0;
   while(0==EOC);//等待轉(zhuǎn)換結(jié)束
   OE=1;
   AD_DATA[0]=adc0809_data; //讀取AD數(shù)據(jù),數(shù)據(jù)范圍為0-255
   OE=0;
   delayms(20);
   ST=0;
   AA = 1; //設置為IN1輸入
delayms(10);
   ST=0;
   OE=1;
   AD_DATA[1]=adc0809_data; //讀取AD數(shù)據(jù),數(shù)據(jù)范圍為0-255
   OE=0;
   delayms(20);
/* if (adc0809_data>=251)
     adc0809_data=250;
函數(shù)名:  t0()
功能:    產(chǎn)生ADC0809CLK所需要的時鐘
/*void t0(void) interrupt 1 using 0
   CLK=~CLK;
函數(shù)名:  Conut()
功能:    將AD_DATA[0]的各位拆分以方便
void Conut(void)
/*a[0]=AD_DATA[0]/100;
  a[1]=AD_DATA[0]/10%10;
  a[2]=AD_DATA[0]%10;
b[0]=AD_DATA[1]/100;
b[1]=AD_DATA[1]/10%10;
b[2]=AD_DATA[1]%10;*/
  a = AD_DATA[0]/250;
  b = AD_DATA[1]/250;
   ST=0;
    OE=0;
    ConfigUART(9600);
   time0();
   // ConfigUART();
   //EA=1; //開總中斷
   // TMOD=0x02; //設定定時器 T0工作方式
/*   TH0=216; //利用T0中斷產(chǎn)生CLK信號
    TL0=216;
    TR0=1; //啟動定時器T0
    ET0=1;
    //ST=0;
    //OE=0;
   EA = 1;*/
      AD();
        Conut();   //計算
   printf ("shfh");
   printf ("%.2f",a);
   printf ("%.2f",b);
   delayms(10);  //100MS
函數(shù)名:  t0()
    TL0=216;
   CLK=~CLK;
void InterrupUART ()  interrupt 4
  if (RI)
     RI = 0;
  SBUF = SBUF ;
  if (TI)
      TI =0;
作者: jamiliang    時間: 2020-3-20 01:39
你得上原理圖
