單片機LCD1602顯示的定時鬧鐘程序
zhouzhikun
2020-2-29 14:52
單片機LCD1602顯示的定時鬧鐘程序
#include<reg51.h>
#include<lcd1602.h>
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit key3=P1^3;
sbit buzzer=P2^5;
sbit relay=P2^3;//buzzer & relay均為低電平工作
sbit led=P2^4;
sbit lamp=P2^5;
uchar code date[]=" H.I.T. CHINA ";
uchar code time[]=" ALARM 23:58 ";
uchar code bell[]=" ALARM : ";
uchar second=40,minute=58,hour=23,counter=0;
uchar bellminute=0,bellhour=0;
uchar buzzerflag,clockflag;//若標志為1,則工作
void ledshow()//led閃爍,標示程序開始運轉
uchar i;
for(i=0;i<=100;i++)
led=~led;
delay(5);
uchar keyscan()//鍵盤掃描
uchar keyvalue,temp;
keyvalue=0;
P1=0xff;
temp=P1;
if(~(P1&temp))
switch(temp)
case 0xfe:
keyvalue=1;
break;
case 0xfd:
keyvalue=2;
break;
case 0xfb:
keyvalue=3;
break;
case 0xf7:
keyvalue=4;
break;
default:
keyvalue=0;
break;
return keyvalue;
void clock_init()//lcd時鐘寫入初始化
uchar i,j;
for(i=0;i<16;i++)
write_data(date[i]);[/i][i]
write_com(0x80+0x40);
for(j=0;j<16;j++)
write_data(time[j]);
void timer0_init()//中斷初始化
EA=1;
ET0=1;
TMOD=0x01;
TH0=0xd8;//每10m中斷一次
TL0=0xf0;
TR0=1;
void clock_write()//時鐘實時寫入
write_sfm(0x49,hour);
write_sfm(0x4c,minute);
void key_menu()//總鍵盤掃描函數
unsigned char keyvalue_menu=0,keyvalue_change=0,i,j;
keyvalue_menu=keyscan();
if(keyvalue_menu)
if(keyvalue_menu==1)//按鍵1,走時停止,開始更改時鐘值
while(~key0);//防抖
TR0=0;
do{
keyvalue_change=keyscan();
if(keyvalue_change==1)//按下1鍵,更改小時
while(~key0);
if(hour<23)
hour++;
hour=0;
else if(keyvalue_change==2)//按下2鍵,更改分鐘
while(~key1);
if(minute<59)
minute++;
minute=0;
else if(keyvalue_change==4)//按下4鍵,更改響鈴方式
while(~key3);
buzzerflag=~buzzerflag;
if(buzzerflag)//鬧鈴運轉,3聲
buzzer=0;
delay(100);
buzzer=1;
delay(100);
buzzer=0;
delay(100);
buzzer=1;
delay(100);
buzzer=0;
delay(100);
buzzer=1;
delay(100);
else//鬧鈴關閉,1聲
buzzer=0;
delay(100);
buzzer=1;
delay(100);
}while(keyvalue_change!=3);//按下3鍵,從新開始走時
while(~key2==0);
TR0=1;//調整時間后從新開始走時
else if(keyvalue_menu==2)//按鍵2,走時繼續,顯示鬧鐘值
while(~key1);//防抖
do{
for(i=0;i<16;i++)
for(j=0;j<16;j++)
write_data(bell[j]);
write_sfm(0x49,bellhour);
write_sfm(0x4c,bellminute);
}while(keyvalue_change!=3);//未完成設置前始終顯示當前鬧鐘
while(~key2);
else if(keyvalue_menu==3)//按鍵3,走時繼續,設置鬧鐘值
while(~key2);
do{
while(~key0);
if(bellhour<23)
bellhour++;
bellhour=0;
while(~key1);
if(bellminute<59)
bellminute++;
bellminute=0;
while(~key3);
buzzer=0;
delay(100);
buzzer=1;
delay(100);
buzzer=0;
delay(100);
buzzer=1;
delay(100);
buzzer=0;
delay(100);
buzzer=1;
delay(100);
else//鬧鈴關閉,1聲
buzzer=0;
delay(100);
buzzer=1;
delay(100);
for(i=0;i<16;i++) //實時顯示修改結果
for(j=0;j<16;j++)
}while(keyvalue_change!=3);//按下3鍵,重新開始顯示走時
while(~key2);//防抖
else if(keyvalue_menu==4)//按鍵4,關閉/開啟鬧鐘
while(~key2);
clockflag=!clockflag;
if(clockflag)//鬧鐘運轉,3聲
[color=#f4a460] buzzer=0;[/color]
[color=#f4a460] delay(100);[/color]
[color=#f4a460] buzzer=1;[/color]
else//鬧鐘關閉,1聲
buzzer=0;
delay(100);
buzzer=1;
delay(100);
void alarm_clock()
if((minute==bellminute)&&(hour==bellhour)&&(clockflag))//鬧鐘打開且達到預設時間時啟動鬧鐘
if(buzzerflag)//如果鬧鈴打開
relay=0;
buzzer=0;
relay=0;
buzzer=1;
relay=1;
buzzer=1;
ledshow();//程序啟動,led閃爍
init1602();//lcd初始化
clock_init();//時鐘初始化
timer0_init();//中斷初始化
clock_write();
key_menu();
alarm_clock();
void timer0() interrupt 1
if(counter<100) //判斷時間變換問題
counter++;
counter=0;
led=~led;
if(second<59)
second++;
second=0;
if(minute<59)
minute++;
minute=0;
if(hour<23)
hour++;
hour=0;
TH0=0xd8;//重新加載中斷值
TL0=0xf0;
TR0=1;
(57.96 KB, 下載次數: 65)
2020-2-29 14:52 上傳
2-36 LCD顯示的定時鬧鐘
愛羅8
2020-10-12 23:48
程序運行出錯了~
曹大歡哎
2021-1-8 10:19
這個L1 12V的在哪里的啊,我找了一遍沒看到,博主看到回復一下我唄,我們要做設計。。
曹大歡哎
2021-1-8 10:20
那個L112V的元器件在哪里啊
