帶GPS授時(shí)的,交通信號(hào)燈控制行人道閘的開(kāi)啟,關(guān)閉和報(bào)警 單片機(jī)源程序
[打印本頁(yè)]
jgsliguangzhao
時(shí)間:
2020-2-27 13:31
/****************控制卡程序如果接手動(dòng)接三根線和地****************/
//#include<reg52.h>
#include <STC12C5A60S2.H>
#include<stdlib.h>
#include <intrins.h>
#include <stdio.h>
#include <string.h>
#define S2RI 0x01 //串口2接收中斷請(qǐng)求標(biāo)志位
#define S2TI 0x02 //串口2發(fā)送中斷請(qǐng)求標(biāo)志位
#define FOSC 11059200L //System frequency
#define BAUD 9600 //UART baudrate
#define RELOAD_COUNT 0xfd //256-(11059200/9600/32/12+0.5)波特率設(shè)置,括號(hào)內(nèi)的數(shù)取整數(shù)(晶振頻率除波特率除32除12加取整數(shù))
void Delay_ms(unsigned int n);
void send_UART_one(unsigned char i);
/****************定義IO口變量****************/
sbit GREEN = P0^0;
sbit RED = P0^1;
sbit TING = P0^2;
sbit KAI = P0^3;
sbit GUAN = P0^4;
sbit LED1 = P0^5;
sbit LED2 = P0^6;
sbit CHUN = P2^5;
sbit XIA = P2^4;
sbit QIU = P2^3;
sbit DONG = P2^2;
sbit QITA = P2^1;
sbit KAIGUAN = P2^0;
sbit YK_LUO = P1^0;
sbit YK_SHENG = P1^1;
sbit YK_TING= P1^5;
sbit EN_TX_RX= P1^4;
sbit WDT_WDI= P3^2;
void IO_Init()
LED1 = 0;
KAI = 1;
GUAN=0;
//TING=0;
//sbit sf=P3^3;//485控制
uchar a,week,yhy,sj,yuefen,shi,fen,miao,ri,nian; //添加
uint yue,xiaoshi;
uchar flag=1;
void Show_Float(float fla);
void xingqi();
char xdata rev_buf[80]; //接收緩存
uchar xdata rev_start = 0; //接收開(kāi)始標(biāo)志
uchar xdata rev_stop = 0; //接收停止標(biāo)志
uchar xdata gps_flag = 0; //GPS處理標(biāo)志
uchar xdata change_page = 0; //換頁(yè)顯示標(biāo)志
uchar xdata num = 0; //
void send_UART_two(unsigned char i);//串口二發(fā)送
typedef struct{
int year; //年
int month; //月
int day; //日
int hour; //時(shí)
int minute; //分
int second; //秒
}DATE_TIME;
typedef xdata struct{
double latitude; //經(jīng)度
double longitude; //緯度
int latitude_Degree; //度
int latitude_Cent; //分
int latitude_Second; //秒
int longitude_Degree; //度
int longitude_Cent; //分
int longitude_Second; //秒
float speed; //速度
float direction; //航向
float height_ground; //水平面高度
float height_sea; //海拔高度
int satellite;
uchar NS;
uchar EW;
DATE_TIME D;
}GPS_INFO;
int GPS_RMC_Parse(char *line,GPS_INFO *GPS);
#define DelayNOP(); {_nop_();_nop_();_nop_();_nop_();};
static uchar GetComma(uchar num,char* str);
static double Get_Double_Number(char *s);
static float Get_Float_Number(char *s);
static void UTC2BTC(DATE_TIME *GPS);
// 語(yǔ)法格式:int GPS_RMC_Parse(char *line, GPS_INFO *GPS)
// 實(shí)現(xiàn)功能:把gps模塊的GPRMC信息解析為可識(shí)別的數(shù)據(jù)
// 參 數(shù):存放原始信息字符數(shù)組、存儲(chǔ)可識(shí)別數(shù)據(jù)的結(jié)構(gòu)體
// 返 回 值:
// 1: 解析GPRMC完畢
// 0: 沒(méi)有進(jìn)行解析,或數(shù)據(jù)無(wú)效
uchar ch, status, tmp;
float lati_cent_tmp, lati_second_tmp;
float long_cent_tmp, long_second_tmp;
float speed_tmp;
char *buf = line;
ch = buf[5];
status = buf[GetComma(2, buf)];
if (ch == 'C') //如果第五個(gè)字符是C,($GPRMC)
if (status == 'A') //如果數(shù)據(jù)有效,則分析
GPS -> NS = buf[GetComma(4, buf)];
GPS -> EW = buf[GetComma(6, buf)];
GPS->latitude = Get_Double_Number(&buf[GetComma(3, buf)]);
GPS->longitude = Get_Double_Number(&buf[GetComma( 5, buf)]);
GPS->latitude_Degree = (int)GPS->latitude / 100; //分離緯度
lati_cent_tmp = (GPS->latitude - GPS->latitude_Degree * 100);
GPS->latitude_Cent = (int)lati_cent_tmp;
lati_second_tmp = (lati_cent_tmp - GPS->latitude_Cent) * 60;
GPS->latitude_Second = (int)lati_second_tmp;
GPS->longitude_Degree = (int)GPS->longitude / 100; //分離經(jīng)度
long_cent_tmp = (GPS->longitude - GPS->longitude_Degree * 100);
GPS->longitude_Cent = (int)long_cent_tmp;
long_second_tmp = (long_cent_tmp - GPS->longitude_Cent) * 60;
GPS->longitude_Second = (int)long_second_tmp;
speed_tmp = Get_Float_Number(&buf[GetComma(7, buf)]); //速度(單位:海里/時(shí))
GPS->speed = speed_tmp * 1.85; //1海里=1.85公里
GPS->direction = Get_Float_Number(&buf[GetComma(8, buf)]); //角度
GPS->D.hour = (buf[7] - '0') * 10 + (buf[8] - '0'); //時(shí)間
GPS->D.minute = (buf[9] - '0') * 10 + (buf[10] - '0');
GPS->D.second = (buf[11] - '0') * 10 + (buf[12] - '0');
tmp = GetComma(9, buf);
GPS->D.day = (buf[tmp + 0] - '0') * 10 + (buf[tmp + 1] - '0'); //日期
GPS->D.month = (buf[tmp + 2] - '0') * 10 + (buf[tmp + 3] - '0');
GPS->D.year = (buf[tmp + 4] - '0') * 10 + (buf[tmp + 5] - '0');//+2000;
UTC2BTC(&GPS->D);
return 1;
return 0;
// 語(yǔ)法格式: static float Str_To_Float(char *buf)
// 實(shí)現(xiàn)功能: 把一個(gè)字符串轉(zhuǎn)化成浮點(diǎn)數(shù)
// 參 數(shù):字符串
// 返 回 值:轉(zhuǎn)化后單精度值
float rev = 0;
float dat;
int integer = 1;
char *str = buf;
int i;
while(*str != '\0')
switch(*str)
case '0':
dat = 0;
break;
case '1':
dat = 1;
break;
case '2':
dat = 2;
break;
case '3':
dat = 3;
break;
case '4':
dat = 4;
break;
case '5':
dat = 5;
break;
case '6':
dat = 6;
break;
case '7':
dat = 7;
break;
case '8':
dat = 8;
break;
case '9':
dat = 9;
break;
case '.':
dat = '.';
break;
if(dat == '.')
integer = 0;
i = 1;
str ++;
continue;
if( integer == 1 )
rev = rev * 10 + dat;
rev = rev + dat / (10 * i);
i = i * 10 ;
str ++;
return rev;
// 語(yǔ)法格式: static float Get_Float_Number(char *s)
// 實(shí)現(xiàn)功能: 把給定字符串第一個(gè)逗號(hào)之前的字符轉(zhuǎn)化成單精度型
// 參 數(shù):字符串
char buf[10];
uchar i;
float rev;
i=GetComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=Str_To_Float(buf);
return rev;
// 語(yǔ)法格式: static double Str_To_Double(char *buf)
// 參 數(shù):字符串
// 返 回 值:轉(zhuǎn)化后雙精度值
double rev = 0;
double dat;
int integer = 1;
char *str = buf;
int i;
while(*str != '\0')
switch(*str)
case '0':
dat = 0;
break;
case '1':
dat = 1;
break;
case '2':
dat = 2;
break;
case '3':
dat = 3;
break;
case '4':
dat = 4;
break;
case '5':
dat = 5;
break;
case '6':
dat = 6;
break;
case '7':
dat = 7;
break;
case '8':
dat = 8;
break;
case '9':
dat = 9;
break;
case '.':
dat = '.';
break;
if(dat == '.')
integer = 0;
i = 1;
str ++;
continue;
if( integer == 1 )
i = i * 10 ;
str ++;
return rev;
// 語(yǔ)法格式: static double Get_Double_Number(char *s)
// 實(shí)現(xiàn)功能:把給定字符串第一個(gè)逗號(hào)之前的字符轉(zhuǎn)化成雙精度型
// 參 數(shù):字符串
char buf[10];
uchar i;
double rev;
i=GetComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=Str_To_Double(buf);
return rev;
// 語(yǔ)法格式:static uchar GetComma(uchar num,char *str)
// 實(shí)現(xiàn)功能:計(jì)算字符串中各個(gè)逗號(hào)的位置
// 參 數(shù):查找的逗號(hào)是第幾個(gè)的個(gè)數(shù),需要查找的字符串
// 返 回 值:0
uchar i,j = 0;
int len=strlen(str);
for(i = 0;i < len;i ++)
if(str[i] == ',')
j++;
if(j == num)
return i + 1;
return 0;
// 語(yǔ)法格式:void UTC2BTC(DATE_TIME *GPS)
// 實(shí)現(xiàn)功能:轉(zhuǎn)化時(shí)間為北京時(shí)區(qū)的時(shí)間
// 參 數(shù):存放時(shí)間的結(jié)構(gòu)體
// 返 回 值:無(wú)
GPS->second ++;
fen=((GPS->minute/10)<<4)+(GPS->minute%10); //添加
miao=((GPS->second/10)<<4)+(GPS->second%10); //添加
if(GPS->second > 59)
GPS->second = 0;
GPS->minute ++;
if(GPS->minute > 59)
GPS->minute = 0;
GPS->hour ++;
GPS->hour = GPS->hour + 8;
xiaoshi=GPS->hour;
shi=((GPS->hour/10)<<4)+(GPS->hour%10); //添加
ri=((GPS->day/10)<<4)+(GPS->day%10); //添加
if(GPS->hour > 23)
GPS->hour -= 24;
GPS->day += 1;
if(GPS->month == 2 ||GPS->month == 4 ||GPS->month == 6 ||GPS->month == 9 ||GPS->month == 11 )
if(GPS->day > 30)
GPS->day = 1;
GPS->month++;
if(GPS->day > 31)
GPS->day = 1;
GPS->month ++;
if(GPS->year % 4 == 0 )
if(GPS->day > 29 && GPS->month == 2)
GPS->day = 1;
GPS->month ++;
if(GPS->day > 28 &&GPS->month == 2)
GPS->day = 1;
GPS->month ++;
if(GPS->month > 12)
GPS->month -= 12;
GPS->year ++;
yue=GPS->month;
yuefen=((GPS->month/10)<<4)+(GPS->month%10); //添加
nian=((GPS->year/10)<<4)+(GPS->year%10); //添加
// sj=0x14;//世紀(jì)
if(GPS->month==0x01)
yue=0x0d;
GPS->year--;
if(GPS->month==0x02)
yue=0x0e;
GPS->year--;
// week=(70+GPS->year+(GPS->year/4)+((26*(yue+1))/10)+GPS->day+(sj/4)-1-(2*sj))%7;
xingqi();
week=(GPS->year+(GPS->year/4)+yhy+GPS->day+6)%7;
GPS->year++;
GPS->year++;
if(week==0x00)
week=0x07;
send_UART_one(0xeb);
send_UART_one(miao); //修改后
send_UART_one(fen); //修改后
send_UART_one(shi); //修改后
send_UART_one(ri); //修改后
send_UART_one(yuefen); //修改后
send_UART_one(week);
send_UART_one(nian); //修改后
send_UART_one(0xec);
//EB 49 43 09 07 11 03 18 EC
GPS_INFO GPS; //GPS信息結(jié)構(gòu)體
void xingqi()
yhy=(26*(yue+1))/10;
/*void send_UART_two(unsigned char i)
unsigned char temp = 0;
IE2=0x00; //關(guān)串口2中斷,es2=0
S2CON=S2CON & 0xFD; //B'11111101,清零串口2發(fā)送完成中斷請(qǐng)求標(biāo)志
S2BUF=i;
do
temp=S2CON;
temp=temp & 0x02;
}while(temp==0);
IE2=0x01; //允許串口2中斷,ES2=1
void send_UART_one(unsigned char i) //外加+++
ES=0x00; //關(guān)串口1中斷,es=0
TI=0; //B'11111101,清零串口1發(fā)送完成中斷請(qǐng)求標(biāo)志
SBUF=i;
while(TI==0);
ES=0x01; //允許串口1中斷,ES=1
串口初始化
void Uart_Init(void)
TMOD=0x21;
TH0=0x3c;
TL0=0xb0;
ET0=1;//定時(shí)/計(jì)數(shù)器T0中斷允許位
TR0=1;//啟動(dòng)定時(shí)/計(jì)數(shù)器工
EX1=0;//開(kāi)外部中斷1 判斷程序運(yùn)行需關(guān)閉外部中斷
IT1=1;//跳變沿方式
SCON=0x50; //0101,0000 8位可變波特率,無(wú)奇偶校驗(yàn)位
S2CON=0x50; //0101,0000 8位可變波特率,無(wú)奇偶校驗(yàn)位,允許接收
BRT=RELOAD_COUNT; //設(shè)置獨(dú)立波特率發(fā)生器的重載初值
AUXR=0x11; // T0x12,T1x12,UART_M0x6,BRTR,S2SMOD,BRTx12,EXTRAM,S1BRS
ES=1; //允許串口中斷
EA=1;//CPU中斷總允許
//sf=1;
/*************道閘關(guān)閉函數(shù)******************/
void hong_led()
if((RED==1)&&(GREEN==0)&&(flag==1))
KAI=0;
GUAN=1;
TING=1;
Delay_ms(1000);
WDT_WDI=~WDT_WDI;
GUAN=0;
KAI=0;
flag=0;
//TING=1;
admin
時(shí)間:
2020-2-28 01:18
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
