請問 MDK 編譯 Error: L6200E:兩個錯誤怎么修改
czhaii
2020-2-9 17:03
*** Using Compiler 'V5.06 update 3 (build 300)', folder: 'D:\Program File\ARM\ARMCC\Bin'
Rebuild target 'Target 1'
assembling startup_stm32f10x_hd.s...
compiling delay.c...
compiling FreeRTOS.c...
compiling usart.c...
compiling sys.c...
compiling key.c...
compiling croutine.c...
compiling led.c...
compiling event_groups.c...
compiling list.c...
compiling queue.c...
compiling stream_buffer.c...
compiling timers.c...
compiling tasks.c...
compiling LCD.c...
compiling port.c...
compiling heap_4.c...
linking...
..\OBJ\FreeRTOS.axf: Error: L6200E: Symbol __ARM_use_no_argv multiply defined (by freertos_1.o and freertos.o).
..\OBJ\FreeRTOS.axf: Error: L6200E: Symbol main multiply defined (by freertos_1.o and freertos.o).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 2 error messages.
"..\OBJ\FreeRTOS.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:02
(263.26 KB, 下載次數: 52)
2020-2-9 17:03 上傳
移植FreeRTOS到STM32F103開發板,出現這兩個錯誤,光標不得定位錯誤行。
請問怎么解決?謝謝
banalsheep
2020-2-9 18:30
為什么有兩個FreeRTOS.c?看錯誤信息應該是有2個模塊重復定義了某1個或多個符號(函數等)
czhaii
2020-2-12 15:47
謝謝,重新移植了一個
