標(biāo)題: 基于單片機(jī)的脈搏體溫檢測(cè)儀+壓力Proteus仿真程序 [打印本頁(yè)]
作者: 1879058417    時(shí)間: 2020-1-7 17:06
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #define uint            unsigned int
  5. #define uchar           unsigned char
  6. #define ulong           unsigned long         //宏定義
  7. #define LCD_DATA        P0                                 //定義P0口為L(zhǎng)CD_DATA
  8. unsigned char getdata; //獲取ADC轉(zhuǎn)換回來(lái)的值
  9. unsigned char dispbuf[4];
  10. unsigned int OverCounter = 0;
  11. unsigned char ptemp;
  12. bit OverFlg = 0;
  13. unsigned int temp,ppress = 0;
  14. float  press;
  15. char KEY_TIMES = 0;
  16. char KEY_Set_TIMES = 0;
  17. sbit LCD_RS =P2^5;
  18. sbit LCD_RW =P2^6;
  19. sbit LCD_E  =P2^7;                                                 //定義LCD控制引腳
  20. #define R24C04ADD 0xA1
  21. #define W24C04ADD 0xA0
  22. //ADC0832的引腳
  23. sbit ADCS =P2^2;  //ADC0832 chip seclect
  24. sbit ADDI =P2^4;  //ADC0832 k in
  25. sbit ADDO =P2^4;  //ADC0832 k out
  26. sbit ADCLK =P2^3;  //ADC0832 clock signal
  27. sbit KEY  =P1^7;
  28. sbit KEY_Set = P3^0;
  29. sbit KEY_ADD = P3^1;
  30. sbit KEY_DEC = P3^2;
  31. sbit speaker =P2^0;                                                 //蜂鳴器引腳定義
  32. sbit DQ=P3^7;
  33. void delay5ms(void);   //誤差 0us
  34. void LCD_WriteData(uchar LCD_1602_DATA);         /********LCD1602數(shù)據(jù)寫(xiě)入***********/
  35. void LCD_WriteCom(uchar LCD_1602_COM);                 /********LCD1602命令寫(xiě)入***********/
  36. void lcd_1602_word(uchar Adress_Com,uchar Num_Adat,uchar *Adress_Data); /*1602字符顯示函數(shù),變量依次為字符顯示首地址,顯示字符長(zhǎng)度,所顯示的字符*/
  37. void InitLcd();//液晶初始化函數(shù)
  38. unsigned int Adc0832(unsigned char channel);
  39. void LCD1602_Write_char( unsigned char *prointer );
  40. uchar Xintiao_H=110;        //脈搏上限
  41. uint wendu=0;
  42. /*****延時(shí)子程序*****/
  43. void Delay_DS18B20(int num)
  44. {
  45.   while(num--) ;
  46. }
  47. /*****初始化DS18B20*****/
  48. void Init_DS18B20(void)
  49. {
  50.   unsigned char x=0;
  51.   DQ = 1;         //DQ復(fù)位
  52.   Delay_DS18B20(8);    //稍做延時(shí)
  53.   DQ = 0;         //單片機(jī)將DQ拉低
  54.   Delay_DS18B20(80);   //精確延時(shí),大于480us
  55.   DQ = 1;         //拉高總線
  56.   Delay_DS18B20(34);
  57. }
  58. /*****讀一個(gè)字節(jié)*****/
  59. unsigned char ReadOneChar(void)
  60. {
  61.   unsigned char i=0;
  62.   unsigned char dat = 0;
  63.   for (i=8;i>0;i--)
  64.   {
  65.     DQ = 0;     // 給脈沖信號(hào)
  66.     dat>>=1;
  67.     DQ = 1;     // 給脈沖信號(hào)
  68.     if(DQ)
  69.     dat|=0x80;
  70.     Delay_DS18B20(4);
  71.   }
  72.   return(dat);
  73. }
  74. void WriteOneChar(unsigned char dat)
  75. {
  76.   unsigned char i=0;
  77.   for (i=8; i>0; i--)
  78.   {
  79.     DQ = 0;
  80.     DQ = dat&0x01;
  81.     Delay_DS18B20(5);
  82.     DQ = 1;
  83.     dat>>=1;
  84.   }
  85. }
  86. /*****讀取溫度*****/
  87. unsigned int ReadTemperature(void)
  88. {
  89.   unsigned char a=0;
  90.   unsigned char b=0;
  91.   unsigned int t=0;
  92.   float tt=0;
  93.   Init_DS18B20();
  94.   WriteOneChar(0xCC);  //跳過(guò)讀序號(hào)列號(hào)的操作
  95.   WriteOneChar(0x44);  //啟動(dòng)溫度轉(zhuǎn)換
  96.   Init_DS18B20();
  97.   WriteOneChar(0xCC);  //跳過(guò)讀序號(hào)列號(hào)的操作
  98.   WriteOneChar(0xBE);  //讀取溫度寄存器
  99.   a=ReadOneChar();     //讀低8位
  100.   b=ReadOneChar();    //讀高8位
  101.   t=b;
  102.   t<<=8;
  103.   t=t|a;
  104.   tt=t*0.0625;
  105.   t= tt*10+0.5;     //放大10倍輸出并四舍五入
  106.   return(t);
  107. }
  108. //按鍵掃描
  109. void KEY_SCAN( void )
  110. {
  111.         if( KEY == 0 )
  112.         {
  113.                   delay5ms();
  114.                  if( KEY == 0 )
  115.                  {
  116.                    delay5ms();
  117.                    while( !KEY );
  118.                    KEY_TIMES++;
  119.                    if( KEY_TIMES > 1 )
  120.                    {
  121.                             KEY_TIMES = 0;
  122.                    }
  123.                      LCD_WriteCom( 0x80 );
  124.                      LCD1602_Write_char("                ");
  125.                          LCD_WriteCom( 0x80+0x40 );
  126.                      LCD1602_Write_char("                ");
  127.                  }
  128.         }
  129.         if( KEY_Set == 0 )
  130.         {
  131.                   delay5ms();
  132.                  if( KEY_Set == 0 )
  133.                  {
  134.                    delay5ms();
  135.                    while( !KEY_Set );
  136.                    KEY_Set_TIMES++;
  137.                    if( KEY_Set_TIMES > 1 )
  138.                    {
  139.                             KEY_Set_TIMES = 0;
  140.                    }
  141.                      LCD_WriteCom( 0x80 );
  142.                      LCD1602_Write_char("                ");
  143.                          LCD_WriteCom( 0x80+0x40 );
  144.                      LCD1602_Write_char("                ");
  145.                 }
  146.         }
  147. }
  148. //設(shè)置心率告警值
  149. void KEY_Set_Rate( void )
  150. {
  151.            if( KEY_ADD == 0 )
  152.         {
  153.                   delay5ms();
  154.                  if( KEY_ADD == 0 )
  155.                  {
  156.                    delay5ms();
  157.                    while( !KEY_ADD );
  158.                    Xintiao_H++;
  159.                    if( Xintiao_H >= 160 )
  160.                    {
  161.                             Xintiao_H = 160;
  162.                    }
  163.                  }
  164.         }
  165.         if( KEY_DEC == 0 )
  166.         {
  167.                   delay5ms();
  168.                  if( KEY_DEC == 0 )
  169.                  {
  170.                    delay5ms();
  171.                    while( !KEY_DEC );
  172.                    Xintiao_H--;
  173.                    if( Xintiao_H <= 60 )
  174.                    {
  175.                             Xintiao_H = 60;
  176.                    }
  177.                  }
  178.         }
  179. }
  180. //=====================================================================================
  181. //=====================================================================================
  182. //=====================================================================================
  183. void main()          //主函數(shù)
  184. {
  185. InitLcd();
  186.   while(1)                          //進(jìn)入循環(huán)
  187.   {
  188.           KEY_SCAN();
  189.         getdata=Adc0832(0);
  190.         temp=getdata/2-5;
  191.         if( temp >  Xintiao_H )
  192.         {
  193.                  speaker = 0;
  194.         }
  195.         else
  196.         {
  197.                 speaker = 1;
  198.         }
  199.         temp = 0;
  200.          if( KEY_Set_TIMES == 0 )
  201.          {
  202.                 if( KEY_TIMES == 1 )
  203.                 {
  204.                     getdata=Adc0832(0);
  205.                   if(14<getdata<243)                                       //當(dāng)壓力值介于15kpa到115kpa之間時(shí),遵循線性變換
  206.                          {
  207. //                                  int vary=getdata;                                                //y=(115-15)/(243-13)*X+15kpa
  208.                                 temp=getdata*10/2-50;                        //測(cè)試時(shí)補(bǔ)償值為9.3
  209. //                                temp=(int)(press*10);                  //放大10倍,便于后面的計(jì)算
  210.                             if(temp != ppress)
  211.                             {
  212.                               ppress = temp;
  213.                               OverFlg = 1;
  214.                             }
  215.                                 dispbuf[3]=temp/1000;                                     //取壓力值百位
  216.                                 dispbuf[2]=(temp%1000)/100;                            //取壓力值十位
  217.                                 dispbuf[1]=((temp%1000)%100)/10;                    //取壓力值個(gè)位
  218.                                 dispbuf[0]=((temp%1000)%100)%10;                        //取壓力值十分位
  219.                                 LCD_WriteCom( 0x80 );
  220.                                 LCD1602_Write_char( "   heart rate   " );
  221.                                 LCD_WriteCom( 0x80 + 0x40 );
  222.                             LCD1602_Write_char("Rate:");
  223.                                 LCD_WriteData( 0x30 + dispbuf[3] );
  224.                                 LCD_WriteData( 0x30 + dispbuf[2] );
  225.                                 LCD_WriteData( 0x30 + dispbuf[1] );
  226.                                 LCD_WriteData( '.' );
  227.                                 LCD_WriteData( 0x30 + dispbuf[0] );
  228.                         }
  229.                 }
  230.                 if( KEY_TIMES == 0 )
  231.                 {
  232.                         lcd_1602_word(0x80,16,"  temperature  ");          //初始化顯示
  233.                         wendu=ReadTemperature();
  234.                         lcd_1602_word(0xc0,10," Temp:    ");//顯示第二行數(shù)據(jù)
  235.                         LCD_WriteCom(0x80+0x40+10);
  236.                         LCD_WriteData(wendu/100+0x30);
  237.                         LCD_WriteData(wendu%100/10+0x30);
  238.                         LCD_WriteData('.');
  239.                         LCD_WriteData(wendu%100%10+0x30);
  240.                         LCD_WriteData(0xdf);
  241.                         LCD_WriteData('C');
  242.                 }
  243.         }
  244.         else
  245.         {
  246.                 KEY_Set_Rate();
  247.                 dispbuf[3]=Xintiao_H/100;                                         //取設(shè)置壓力值百位
  248.                 dispbuf[2]=Xintiao_H%100/10;                                //取設(shè)置壓力值十位
  249.                 dispbuf[1]=Xintiao_H%10;                                            //取設(shè)置壓力值個(gè)位
  250.                 LCD_WriteCom( 0x80  );
  251.                 LCD1602_Write_char( " Set heart rate " );
  252.                 LCD_WriteCom( 0x80 + 0x40 );
  253.             LCD1602_Write_char("warning:");
  254.                 LCD_WriteData( 0x30 + dispbuf[3] );
  255.                 LCD_WriteData( 0x30 + dispbuf[2] );
  256.                 LCD_WriteData( 0x30 + dispbuf[1] );
  257.         }
  258.   }
  259. }
  260. /**Adress_Com顯示地址,Num_Adat顯示字符數(shù)量,Adress_Data顯示字符串內(nèi)容**/
  261. void lcd_1602_word(uchar Adress_Com,uchar Num_Adat,uchar *Adress_Data)
  262. {
  263. uchar a=0;
  264. uchar Data_Word;
  265. LCD_WriteCom(Adress_Com); //選中地址
  266. for(a=0;a<Num_Adat;a++)   //for循環(huán)決定顯示字符個(gè)數(shù)
  267.   {
  268.    Data_Word=*Adress_Data;          //讀取字符串?dāng)?shù)據(jù)
  269.    LCD_WriteData(Data_Word);  //顯示字符串
  270.    Adress_Data++;                          //顯示地址加一
  271.   }
  272. }
  273. /***************1602函數(shù)*******************/
  274. void LCD_WriteData(uchar LCD_1602_DATA)         /********LCD1602數(shù)據(jù)寫(xiě)入***********/
  275. {
  276. delay5ms();  //操作前短暫延時(shí),保證信號(hào)穩(wěn)定
  277. LCD_E=0;
  278. LCD_RS=1;
  279. LCD_RW=0;
  280. _nop_();
  281. LCD_E=1;
  282. LCD_DATA=LCD_1602_DATA;
  283. LCD_E=0;
  284. LCD_RS=0;
  285. }
  286. /********LCD1602命令寫(xiě)入***********/
  287. void LCD_WriteCom(uchar LCD_1602_COM)
  288. {
  289. delay5ms();//操作前短暫延時(shí),保證信號(hào)穩(wěn)定
  290. LCD_E=0;
  291. LCD_RS=0;
  292. LCD_RW=0;
  293. _nop_();
  294. LCD_E=1;
  295. LCD_DATA=LCD_1602_COM;
  296. LCD_E=0;
  297. LCD_RS=0;
  298. }
  299. void InitLcd()                   //初始化液晶函數(shù)
  300. {
  301. delay5ms();
  302. delay5ms();
  303. LCD_WriteCom(0x38); //display mode
  304. LCD_WriteCom(0x38); //display mode
  305. LCD_WriteCom(0x38); //display mode
  306. LCD_WriteCom(0x06); //顯示光標(biāo)移動(dòng)位置
  307. LCD_WriteCom(0x0c); //顯示開(kāi)及光標(biāo)設(shè)置
  308. LCD_WriteCom(0x01); //顯示清屏
  309. delay5ms();
  310. delay5ms();
  311. }
  312. void delay5ms(void)   //5ms延時(shí)函數(shù)
  313. {
  314.     unsigned char a,b;
  315.     for(b=185;b>0;b--)
  316.         for(a=12;a>0;a--);
  317. }
  318. /*=========================================
  319. //LCD1602寫(xiě)字符串
  320. =========================================*/
  321. void LCD1602_Write_char( unsigned char *prointer )                                   //1602 字符串    處理
  322. {
  323.     while( *prointer != '\0' )
  324.     {
  325.         LCD_WriteData( *prointer );
  326.         prointer++;
  327.     }
  328. }
  329. /************
  330. 讀ADC0832函數(shù)
  331. ************/
  332. //采集并返回
  333. unsigned int Adc0832(unsigned char channel)     //AD轉(zhuǎn)換,返回結(jié)果
  334. {
  335.     unsigned char i=0;
  336.     unsigned char j;
  337.     unsigned int dat=0;
  338.     unsigned char ndat=0;
  339.     if(channel==0)channel=2;
  340.     if(channel==1)channel=3;
  341.     ADDI=1;
  342.     _nop_();
  343.     _nop_();
  344.     ADCS=0;//拉低CS端
  345.     _nop_();
  346.     _nop_();
  347.     ADCLK=1;//拉高CLK端
  348.     _nop_();
  349.     _nop_();
  350.     ADCLK=0;//拉低CLK端,形成下降沿1
  351.     _nop_();
  352.     _nop_();
  353.     ADCLK=1;//拉高CLK端
  354.     ADDI=channel&0x1;
  355.     _nop_();
  356.     _nop_();
  357.     ADCLK=0;//拉低CLK端,形成下降沿2
  358.     _nop_();
  359.     _nop_();
  360.     ADCLK=1;//拉高CLK端
  361.     ADDI=(channel>>1)&0x1;
  362.     _nop_();
  363.     _nop_();
  364.     ADCLK=0;//拉低CLK端,形成下降沿3
  365.     ADDI=1;//控制命令結(jié)束
  366.     _nop_();
  367.     _nop_();
  368.     dat=0;
  369.     for(i=0;i<8;i++)
  370.     {
  371.         dat|=ADDO;//收數(shù)據(jù)
  372.         ADCLK=1;
  373.         _nop_();
  374.         _nop_();
  375.         ADCLK=0;//形成一次時(shí)鐘脈沖
  376.         _nop_();
  377.         _nop_();
  378.         dat<<=1;
  379.         if(i==7)dat|=ADDO;
  380.     }
  381.     for(i=0;i<8;i++)
  382.     {
  383.         j=0;
  384.         j=j|ADDO;//收數(shù)據(jù)
  385.         ADCLK=1;
  386.         _nop_();
  387.         _nop_();
  388.         ADCLK=0;//形成一次時(shí)鐘脈沖
  389.         _nop_();
  390.         _nop_();
  391.         j=j<<7;
  392.         ndat=ndat|j;
  393.         if(i<7)ndat>>=1;
  394.     }
  395.     ADCS=1;//拉低CS端
  396.     ADCLK=0;//拉低CLK端
  397.     ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
  398.     dat<<=8;
  399.     dat|=ndat;
  400.     return(dat);            //return ad k
  401. }
基于單片機(jī)的電子血壓計(jì)設(shè)計(jì).zip (1.03 MB, 下載次數(shù): 163)
作者: ywc3000    時(shí)間: 2020-3-20 22:18
下來(lái),看看,下來(lái),看看,
作者: Realiu    時(shí)間: 2020-6-11 16:54
感謝樓主分享
