標(biāo)題: 基于51單片機(jī)的數(shù)字溫度計(jì),上下限,蜂鳴器報(bào)警程序 [打印本頁(yè)]
作者: 半夏琉璃    時(shí)間: 2020-1-4 10:24
  1. #include <reg52.h>
  2. #define key P2
  3. #define LCD1602_DB  P0
  4. sbit LCD1602_RS = P1^0;
  5. sbit LCD1602_RW = P1^1;
  6. sbit ADDR2 = P1^2;
  7. sbit ADDR3 = P1^3;//
  8. sbit ENLED = P1^4;//p1.4和p1.3是138使能端
  9. static unsigned char D=0;
  10. static unsigned char G=50;
  11.        sbitbuzz=P1^6;
  12. bit flag1s = 0;          //1s定時(shí)標(biāo)志
  13. unsigned char T0RH = 0;  //T0重載值的高字節(jié)
  14. unsigned char T0RL = 0;  //T0重載值的低字節(jié)
  15. extern void delay_ms(unsigned int ms);
  16. extern void DelayX10us(unsigned char t);
  17. void ConfigTimer0(unsigned int ms);
  18. unsigned char IntToString(unsigned char*str, int dat);
  19. extern bit Start18B20();
  20. extern bit Get18B20Temp(int *temp);
  21. extern void InitLcd1602();
  22. extern void LcdShowStr(unsigned char x,unsigned char y, unsigned char *str);
  23. unsigned char code table0[]="D=";
  24. unsigned char code table1[]="G=";
  25. unsigned char code table2[]="TEMPIS:";
  26. unsigned char codetable3[]="DS18B20  ERR0R!";
  27. unsigned char codetable4[]="PLEASE   CHECK!";
  28. unsigned char code table5[]="'C";
  29. unsigned char code table7[]="Wlecometo you!!";
  30. unsigned char code table8[]=" I am YYY_Temp!";
  31. void main()
  32. {
  33.    bit res;
  34.    int temp;        //讀取到的當(dāng)前溫度值
  35.    int intT, decT;  //溫度值的整數(shù)和小數(shù)部分
  36.    unsigned char len;
  37.    unsigned char str[12];
  38.    InitLcd1602();
  39.    LcdShowStr(0, 0, table7);
  40.    LcdShowStr(0, 1, table8);//5初始化顯示5s
  41.         delay_ms(5000);
  42.            EX0=1;
  43.            IT0=1;
  44.    EA = 1;            //開(kāi)總中斷
  45.
  46.    ConfigTimer0(10);  //T0定時(shí)10ms
  47.
  48.    Start18B20();      //啟動(dòng)DS18B20
  49.         delay_ms(5000);
  50.    while (1)
  51.     {
  52.        if (flag1s)  //每5秒更新一次溫度
  53.        {
  54.            flag1s = 0;
  55.            res = Get18B20Temp(&temp);  //讀取當(dāng)前溫度
  56.            if (res)                    //讀取成功時(shí),刷新當(dāng)前溫度顯示
  57.            {
  58.                                                    intT = temp >> 4;             //分離出溫度值整數(shù)部分
  59.                 decT = temp & 0xF;            //分離出溫度值小數(shù)部分
  60.                 len = IntToString(str, intT);//整數(shù)部分轉(zhuǎn)換為字符串
  61.                 str[len++] = '.';             //添加小數(shù)點(diǎn)
  62.                 decT = (decT*10) / 16;        //二進(jìn)制的小數(shù)部分轉(zhuǎn)換為1位十進(jìn)制位
  63.                 str[len++] = decT + '0';      //十進(jìn)制小數(shù)位再轉(zhuǎn)換為ASCII字符
  64.                 while (len < 6)               //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
  65.                 {
  66.                     str[len++] = ' ';
  67.                 }
  68.                 str[len] = '\0';              //添加字符串結(jié)束符
  69.                 LcdShowStr(8, 1, str);        //顯示到液晶屏
  70.
  71.                                                         len= IntToString(str, D); //整數(shù)部分轉(zhuǎn)換為字符串
  72.                 while (len < 6)               //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
  73.                 {
  74.                     str[len++] = ' ';
  75.                 }
  76.                 str[len] = '\0';              //添加字符串結(jié)束符
  77.                 LcdShowStr(2, 0, str);
  78.
  79.                 len = IntToString(str, G); //整數(shù)部分轉(zhuǎn)換為字符串
  80.                 while (len < 6)               //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
  81.                 {
  82.                     str[len++] = ' ';
  83.                 }
  84.                 str[len] = '\0';              //添加字符串結(jié)束符
  85.                 LcdShowStr(10, 0, str);
  86.
  87.                                                         LcdShowStr(0,0, table0);
  88.                                                         LcdShowStr(8,0, table1);
  89.                                                         LcdShowStr(0,1, table2);
  90.                                                         LcdShowStr(13,1, table5);
  91.            }
  92.            else                        //讀取失敗時(shí),提示錯(cuò)誤信息
  93.            {
  94.                 LcdShowStr(0, 0, table3);
  95.                                                    LcdShowStr(0, 1, table4);
  96.            }
  97.            Start18B20();               //重新啟動(dòng)下一次轉(zhuǎn)換
  98.        }
  99.                             //鍵盤(pán)設(shè)置上下限,0.3s掃描一次鍵值,同時(shí)更新一次上下限的顯示
  100.         key=0xf7;
  101.                             if(key!=0xf7)
  102.                                           {
  103.                delay_ms(10);
  104.                                                  switch(key)
  105.                                                  {
  106.                                                         case0xe7:
  107.                                                          D++;
  108.                                                          if(D==G)D=0;
  109.        len= IntToString(str, D); //整數(shù)部分轉(zhuǎn)換為字符串
  110.        while(len < 6)               //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
  111.        {
  112.        str[len++]= ' ';
  113.        }
  114.        str[len]= '\0';              //添加字符串結(jié)束符
  115.        LcdShowStr(2,0, str);
  116.                   break;
  117.                                                         case0xd7:
  118.        G--;
  119.        if(G==D)G=50;
  120.        len= IntToString(str, G); //整數(shù)部分轉(zhuǎn)換為字符串
  121.        while(len < 6)               //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
  122.        {
  123.        str[len++]= ' ';
  124.        }
  125.        str[len]= '\0';              //添加字符串結(jié)束符
  126.        LcdShowStr(10,0, str);
  127.        break;
  128.                                                  }
  129.                                             Start18B20();
  130.                                       delay_ms(300);//等待0.3s開(kāi)始下一次掃描鍵值
  131.             }
  132.                                           //光和聲音警報(bào)部分
  133.
  134.                                                         if(D>temp*0.0625||G<temp*0.0625)//超值報(bào)警
  135.                                                         {
  136.
  137.        ENLED= 0;
  138.        ADDR3= 1;
  139.        ADDR2= 1;
  140.        LCD1602_RW= 1;
  141.        LCD1602_RS= 0;
  142.        LCD1602_DB=0xf0;
  143.
  144.        buzz=1;
  145.        DelayX10us(17);
  146.        buzz=0;
  147.        DelayX10us(17);
  148.
  149.        ENLED= 1;//138使能關(guān)閉
  150.                                                         }
  151.        if(D==(temp*0.0625)||G==(temp*0.0625))//等值報(bào)警
  152.                                                         {
  153.        ENLED= 0;
  154.        ADDR3= 1;
  155.        ADDR2= 1;
  156.        LCD1602_RW = 1;
  157.        LCD1602_RS= 0;
  158.        LCD1602_DB=0xf8;
  159.        buzz=1;
  160.        DelayX10us(100);
  161.        buzz=0;
  162.        DelayX10us(100);
  163.        ENLED= 1;//138使能關(guān)閉
  164.                                                         }
  165.                                                         if((D<temp*0.0625&&(1.1*D)>temp*0.0625)||(G>temp*0.0625&&(0.9*G)<temp*0.0625))//接近報(bào)警
  166.                                                         {
  167.        ENLED= 0;
  168.        ADDR3= 1;
  169.        ADDR2= 1;
  170.        LCD1602_RW= 1;
  171.        LCD1602_RS= 0;
  172.        LCD1602_DB=0xfc;
  173.        buzz=1;
  174.        DelayX10us(2500);
  175.        buzz=0;
  176.        DelayX10us(2500);
  177.        ENLED= 1;//138使能關(guān)閉
  178.                                                         }
  179.
  180.
  181.     }
  182. }
  183. /* 整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長(zhǎng)度*/
  184. unsigned char IntToString(unsigned char*str, int dat)
  185. {
  186.    signed char i = 0;
  187.    unsigned char len = 0;
  188.    unsigned char buf[6];
  189.
  190.    if (dat < 0)  //如果為負(fù)數(shù),首先取絕對(duì)值,并在指針上添加負(fù)號(hào)
  191.     {
  192.        dat = -dat;
  193.        *str++ = '-';
  194.        len++;
  195.     }
  196.               else
  197.               {
  198.               *str++= ' ';
  199.     len++;
  200.               }
  201.    do {          //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
  202.        buf[i++] = dat % 10;
  203.        dat /= 10;
  204.     }while (dat > 0);
  205.    len += i;     //i最后的值就是有效字符的個(gè)數(shù)
  206.    while (i-- > 0)   //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
  207.     {
  208.        *str++ = buf[i] + '0';
  209.     }
  210.    *str = '\0';  //添加字符串結(jié)束符
  211.
  212.    return len;   //返回字符串長(zhǎng)度
  213. }
  214. /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
  215. void ConfigTimer0(unsigned int ms)
  216. {
  217.    unsigned long tmp;  //臨時(shí)變量
  218.
  219.    tmp = 11059200 / 12;      //定時(shí)器計(jì)數(shù)頻率
  220.    tmp = (tmp * ms) / 1000;  //計(jì)算所需的計(jì)數(shù)值
  221.    tmp = 65536 - tmp;        //計(jì)算定時(shí)器重載值
  222.    tmp = tmp + 12;           //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
  223.    T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
  224.    T0RL = (unsigned char)tmp;
  225.    TMOD &= 0xF0;   //清零T0的控制位
  226.    TMOD |= 0x01;   //配置T0為模式1
  227.    TH0 = T0RH;     //加載T0重載值
  228.    TL0 = T0RL;
  229.    ET0 = 1;        //使能T0中斷
  230.    TR0 = 1;        //啟動(dòng)T0
  231. }
  232. /* T0中斷服務(wù)函數(shù),完成1秒定時(shí) */
  233. void InterruptTimer0() interrupt 1
  234. {
  235.    static unsigned int tmr1s = 0;
  236.
  237.    TH0 = T0RH;  //重新加載重載值
  238.    TL0 = T0RL;
  239.    tmr1s++;
  240.    if (tmr1s >= 500)  //定時(shí)5s
  241.     {
  242.        tmr1s = 0;
  243.        flag1s = 1;
  244.     }
  245. }
超級(jí)無(wú)敵終極版本數(shù)字溫度計(jì).zip
64.21 KB, 下載次數(shù): 75, 下載積分: 黑幣 -5
作者: 土豆哥666    時(shí)間: 2020-4-28 23:04
樓主方便把仿真也放一下么?麻煩了
作者: jiangxinhong    時(shí)間: 2021-12-22 08:16
那個(gè),溫度可以顯示負(fù)數(shù)啊
