51單片機顯示時間可調時間
812540228
2019-12-24 03:42
51單片機顯示時間可調時間
#include <reg52.h>
#include <intrins.h>
#define lcd1602data P0
typedef unsigned char u8;
typedef unsigned int u16;
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
sbit key1=P3^1;
sbit key2=P3^0;
sbit key3=P3^2;
sbit SCLK=P3^6;
sbit IO=P3^4;
sbit RST=P3^5;
u16 read[]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
u16 write[]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};
u8 time[]={0x30,0x30,0x22,0x08,0x02,0x05,0x19};
u16 setmark,setplace;
void delay_ms(u16 n);
void initConfiguration();
void lcdDisplay();
void lcdwrite_com(u8 datas);
void lcdwrite_datas(u8 datas);
void lcdinit();
void writebyte(u8 address,u8 datas);
u8 readbyte(u8 address);
void ds1302init();
void read_time();
u16 i;
lcdinit();
ds1302init();
if(setmark==0)
read_time();
if(key1==0)
delay_ms(1);
if(key1==0)
setplace++;
setplace%=7;
while(i<50&&key1==0)
i++;
delay_ms(10);
i=0;
if(key2==0)
delay_ms(1);
if(key2==0)
time[setplace]++;
if((time[setplace]&0x0f)>9)
time[setplace]=time[setplace]+6;
if((time[setplace]>=0x60)&&(setplace<2))
time[setplace]=0;
if((time[setplace]>=0x24)&&(setplace==2))
time[setplace]=0;
if((time[setplace]>=0x32)&&(setplace==3))
time[setplace]=0;
if((time[setplace]>=0x13)&&(setplace==4))
time[setplace]=0;
if((time[setplace]>=0x7)&&(setplace==5))
time[setplace]=1;
while((i<50)&&(0==key2))
i++;
delay_ms(10);
i=0;
lcdDisplay();
u16 a,b;
for(;n>0;n--)
for(a=199;a>0;a--)
for(b=1;b>0;b--)
EA=1;
IT0=1;
EX0=1;
void init0() interrupt 0
delay_ms(10);
if(key3==0)
setmark=~setmark;
setplace=0;
ds1302init();
void lcdDisplay()
lcdwrite_com(0x80+0x00);
lcdwrite_datas('2');
lcdwrite_datas('0');
lcdwrite_datas('0'+time[6]/16);
lcdwrite_datas('0'+(time[6]&0x0f));
lcdwrite_datas('-');
lcdwrite_datas('0'+time[4]/16);
lcdwrite_datas('0'+(time[4]&0x0f));
lcdwrite_datas('0'+time[3]/16);
lcdwrite_datas('0'+(time[3]&0x0f));
lcdwrite_com(0x8c);
lcdwrite_datas('0'+(time[5]&0x07));
lcdwrite_com(0xc0);
lcdwrite_datas('0'+time[2]/16);
lcdwrite_datas('0'+(time[2]&0x0f));
lcdwrite_datas('0'+time[1]/16);
lcdwrite_datas('0'+(time[1]&0x0f));
lcdwrite_datas('0'+time[0]/16);
lcdwrite_datas('0'+(time[0]&0x0f));
E=0;
RW=0;
RS=0;
lcd1602data=datas;
delay_ms(1);
E=1;
//delay_ms(1);
E=0;
E=0;
RW=0;
RS=1;
lcd1602data=datas;
delay_ms(1);
E=1;
//delay_ms(1);
E=0;
void lcdinit()
lcdwrite_com(0x38);
lcdwrite_com(0x0c);
lcdwrite_com(0x06);
lcdwrite_com(0x01);
lcdwrite_com(0x80);
u8 i;
RST=0;
_nop_();
SCLK=0;
_nop_();
RST=1;
_nop_();
for(i=0;i<8;i++)
IO=address&0x01;
address>>=1;
SCLK=1;
_nop_();
SCLK=0;
_nop_();
for(i=0;i<8;i++)
IO=datas&0x01;
datas>>=1;
SCLK=1;
_nop_();
SCLK=0;
_nop_();
RST=0;
u8 i,datas,dat;
RST=0;
//_nop_();
SCLK=0;
//_nop_();
RST=1;
//_nop_();
for(i=0;i<8;i++)
IO=address&0x01;
address>>=1;
SCLK=1;
_nop_();
SCLK=0;
_nop_();
//_nop_();
for(i=0;i<8;i++)
dat=IO;
datas=(datas>>1)|(dat<<7);
SCLK=1;
_nop_();
SCLK=0;
_nop_();
RST=0;
//_nop_();
SCLK=1;
//_nop_();
IO=0;
//_nop_();
IO=1;
//_nop_();
return datas;
void ds1302init()
u8 i;
writebyte(0x8e,0x00);
for(i=0;i<7;i++)
writebyte(write[i],time[i]);
writebyte(0x8e,0x80);
void read_time()
u8 i;
for(i=0;i<7;i++)
time[i]=readbyte(read[i]);
