藍牙串口助手調試藍牙模塊控制led燈不亮
13721371025
2019-12-11 21:06
我用藍牙串口助手輸入1,2,3,4和其他字符都是執行default里的語句,大哥們,幫忙給看看。
#include"reg52.h"
sbit led1=P2^0;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
sbit led5=P2^4;
sbit led6=P2^7;
uchar tmp;
void xingtai1()
led1=0;
led2=1;
led3=1;
led4=1;
void xingtai2()
led1=1;
led2=0;
led3=1;
led4=1;
void xingtai3()
led1=1;
led2=1;
led3=0;
led4=1;
void xingtai4()
led1=1;
led2=1;
led3=1;
led4=0;
void init()
TMOD = 0x20;
PCON = 0x00;
SCON = 0x50;
TH1 = 0xFd; //設置波特率 9600
TL1 = 0xFd;
TR1 = 1; //啟動定時器1
ES = 1; //開串口中斷
EA = 1; //開總中斷
led6=0;
init();
if(RI) // 是否有數據到來
RI = 0;
// 暫存接收到的數據
switch(SBUF)
case '1': xingtai1();break;
case '2': xingtai2();break;
case '3': xingtai3();break;
case '4': led1=0;
led2=0;
led3=0;break;
default: led1=0;
led2=0;
led3=0;
led4=0;
led5=0;
