標(biāo)題: 基于51單片機(jī)的RLC測量儀Proteus仿真程序 [打印本頁]
作者: 2376836120    時(shí)間: 2019-12-8 15:52
RLC測量,電容電阻采用555單穩(wěn)態(tài)電路,電感采用三點(diǎn)振蕩式電路,電感誤差較大
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint  unsigned int
  5. sbit RS=P2^6;
  6. sbit RW=P2^5;
  7. sbit E=P2^7;
  8. sbit R=P1^0;
  9. sbit C=P1^1;
  10. sbit L=P1^2;
  11. sbit A1=P1^3;
  12. sbit A0=P1^4;
  13. #define LCD_data  P0
  14. uchar   code  table1[11]={"R=       Ω"};
  15. uchar   code  table2[11]={"C=       pF"};
  16. uchar   code  table3[11]={"L=        H"};
  17. uchar code f_table[88]={13,14,15,16,17,        18,        19,        20,        21,        22,        23,        24,        25,        26,        27,        28,        29,        30,        31,        32,        33,        34,        35,        36,        37,        38,        39,        40,        41,        42,        43,        44,        45,        46,        47,        48,        49,        50,        51,        52,        53,        54,        55,        56,        57,        58,        59,        60,        61,        62,        63,        64,        65,        66,        67,        68,        69,        70,        71,        72,        73,        74,        75,        76,        77,        78,        79,        80,        81,        82,        83,        84,        85,        86,        87,        88,        89,        90,        91,        92,        93,        94,        95,        96,        97,        98,        99,        100};
  18. uchar code f_correct[88]={9,10,        11,        12,        12,        12,        13,        14,        15,        16,        17,        18,        18,        18,        19,        20,        21,        21,        22,        23,        24,        25,        25,        26,        26,        27,        28,        29,        29,        30,        30,        31,        32,        33,        33,        34,        35,        35,        36,        37,        38,        38,        39,        40,        41,        41,        42,        42,        43,        44,        45,        45,        46,        47,        48,        49,        49,        50,        51,        51,        52,        53,        54,        54,        55,        55,        56,        57,        57,        58,        59,        60,        60,        62,        62,        63,        64,        64,        65,        66,        66,        67,        67,        68,        69,        70,        71,        71,};
  19. uchar a7,a6,a5,a4,a3,a2,a1;
  20. uchar flag;
  21. unsigned long cnt,cnt1,count;
  22. uchar f_cnt;
  23. /********************************/
  24. void delay_us(); //18us
  25. void delay_ms(uint);
  26. void lcd_init();
  27. void lcd_write_com(uchar com);
  28. void lcd_write_dat(uchar dat);
  29. void lcd_init();
  30. void lcd_display(uchar add,uchar dat);
  31. /***********************************/
  32. void delay_us()
  33. {
  34.         uchar x;
  35.         for(x=0;x<5;x++);
  36. }
  37. void delay_ms(uint z)
  38. {
  39.         uint x,y;
  40.         for(x=0;x<z;x++)
  41.                 for(y=0;y<123;y++);
  42. }
  43. void lcd_write_com(uchar com)
  44. {
  45.   E=0;
  46.   RS=0;
  47.   RW=0;
  48.   delay_us();
  49.   LCD_data=com;
  50.   E=1;           //高脈沖寫入數(shù)據(jù)
  51.   delay_us();
  52.   E=0;
  53. }
  54. void lcd_write_dat(uchar dat)
  55. {
  56.   E=0;
  57.   RS=1;
  58.   RW=0;
  59.   delay_us();
  60.   LCD_data=dat;
  61.   E=1;           //高脈沖寫入數(shù)據(jù)
  62.   delay_us();
  63.   E=0;
  64. }
  65. void lcd_init()                  //lcd初始化
  66. {
  67.         delay_ms(15);
  68.         lcd_write_com(0x38);
  69.         delay_ms(10);
  70.         lcd_write_com(0x0c);
  71.         lcd_write_com(0x06);
  72.         lcd_write_com(0x01);
  73.         delay_ms(2);
  74.
  75.
  76. }
  77. void timer_init(void)  //定時(shí)器初始化
  78. {
  79.         TMOD=0X51;
  80.         PT0=1;     /*中斷優(yōu)先*/
  81.         TH0=0x3c;
  82.         TL0=0xb0;
  83.         TH1=0;
  84.         TL1=0;
  85.         ET0=1;
  86.         ET1=1;
  87.         IT0=1;
  88.         EX0=1;
  89.         TR0=1;
  90.         TR1=1;
  91.         EA=1;
  92. }
  93. void lcd_display(uchar add,uchar dat)           //lcd顯示(地址,數(shù)據(jù))
  94. {
  95.         lcd_write_com(add);
  96.
  97.         lcd_write_dat(dat);
  98.         delay_us();
  99. }
  100. void real_display(void)
  101. {
  102.             if(!R)
  103.                          {
  104. //                         while(!R);
  105.                          A1=A0=0;
  106.                         lcd_display(0x80,table1[0]);
  107.                         lcd_display(0x80+1,table1[1]);
  108.                         lcd_display(0x80+9,0xf4);
  109.                         //lcd_display(0x80+10,0xf4);
  110.                           }
  111.                         else if(!C)
  112.                         {
  113.                         A0=0;A1=1;
  114.                         lcd_display(0x80,table2[0]);
  115.                         lcd_display(0x80+1,table2[1]);
  116.                         lcd_display(0x80+9,table2[9]);
  117.                         lcd_display(0x80+10,table2[10]);
  118.                         }
  119.                         else if(!L)
  120.                         {
  121.                         A0=1;A1=0;
  122.                         lcd_display(0x80,table3[0]);
  123.                         lcd_display(0x80+1,table3[1]);
  124.                         lcd_display(0x80+9,0xe4);
  125.                         lcd_display(0x80+10,table3[10]);
  126.                         }
  127.                         if(a7)
  128.                           lcd_display(0x80+2,0x30+a7);
  129.                         else
  130.                         lcd_display(0x80+2,' ');
  131.                         if(a7||a6)
  132.                           lcd_display(0x80+3,0x30+a6);
  133.                         else
  134.                         lcd_display(0x80+3,' ');
  135.                         if(a7||a6||a5)
  136.                         lcd_display(0x80+4,0x30+a5);
  137.                         else
  138.                                  lcd_display(0x80+4,' ');
  139.                         if(a7||a6||a5||a4)
  140.                         lcd_display(0x80+5,0x30+a4);
  141.                         else
  142.                    lcd_display(0x80+5,' ');
  143.                         if(a7||a6||a5||a4||a3)
  144.                         lcd_display(0x80+6,0x30+a3);
  145.                         else
  146.                     lcd_display(0x80+6,' ');
  147.                         if(a7||a6||a5||a4||a3||a2)
  148.                         lcd_display(0x80+7,0x30+a2);
  149.                         else
  150.                         lcd_display(0x80+7,' ');
  151.
  152.                         lcd_display(0x80+8,0x30+a1);
  153.
  154. }
  155. void correct(void)                        //誤差修正函數(shù)
  156. {
  157.         uchar i,k;
  158.         unsigned long wucha;
  159.         if(cnt<100000)                   //100KHz以內(nèi)的修正
  160.         {
  161.                 if(cnt>980&&cnt<2100)     cnt-=1;
  162.                 if(cnt>=2100&&cnt<3900)   cnt-=2;
  163.                 if(cnt>=3900&&cnt<4800)   cnt-=3;
  164.                 if(cnt>=4800&&cnt<5700)   cnt-=4;
  165.                 if(cnt>=5700&&cnt<8000)   cnt-=5;
  166.                 if(cnt>=8000&&cnt<9100)          cnt-=6;
  167.                 if(cnt>=9100&&cnt<10900)  cnt-=7;
  168.                 if(cnt>=10900&&cnt<11900) cnt-=8;
  169.                 if(cnt>=11900&&cnt<13000) cnt-=9;
  170.                 if(cnt>=13000&&cnt<=100000)
  171.                 {
  172.                         k=cnt/1000;
  173.                         for(i=0;i<88;i++)
  174.                         {
  175.                                 if(k==f_table[i])
  176.                                 {
  177.                                         cnt-=f_correct[i];
  178.                                 }
  179.                         }
  180.                 }
  181.
  182.
  183.         }
  184.         if(cnt>100000)
  185.         {
  186.                 wucha=(cnt/1000)*73065/100000;
  187.                 cnt-=wucha;
  188.         }
  189. }
  190. void main()
  191. {
  192.     timer_init();
  193.         lcd_init();
  194.         while(1)
  195.         {
  196.                    if(flag==1)
  197.                    {
  198.                         real_display();
  199.                         flag=0;
  200.                         }
  201.
  202.
  203.         }
  204.
  205. }
  206. void timer0() interrupt 1
  207. {
  208.         uchar timer0;
  209.
  210.         TH0=0x3c;          //50ms
  211.         TL0=0xb0;
  212.         timer0++;
  213.         if(timer0==20)
  214.         {
  215.                 TR1=0;          //關(guān)閉的計(jì)數(shù)器
  216.                 EA=0;
  217.                 //cnt=TL1+TH1+f_cnt*65536;
  218.                 cnt=count;
  219.                 correct();
  220.             //cnt1=(1e+9)/(2*0.693 *cnt)-20000/2;
  221.                 if(!R)
  222.                 {
  223. //                while(!R);
  224.                 cnt1=1000000/(0.2*0.693*cnt)-165;
  225.                 }
  226.                 else if(!C)
  227.                 {
  228.                 cnt1=1000000000/(0.693*3*510*cnt)-10000;
  229.                 }
  230.                 else if(!L)
  231.                 {
  232.                         cnt1=((38*(1e+6))/(cnt*cnt)-75);
  233.                  //cnt1=1000000000/(3.14*3.14*cnt*cnt*0.1);
  234.                 }
  235.                 timer0=0;
  236.                 count=0;
  237.                 a7=cnt1%100000000/1000000;
  238. ……………………
  239. …………限于本文篇幅 余下代碼請從51黑下載附件…………
RLC 仿真.zip (118.98 KB, 下載次數(shù): 100)
作者: 陌上流塵    時(shí)間: 2019-12-30 12:40
下載附件中并沒有看到圖
作者: 1757897801    時(shí)間: 2020-3-9 10:25
下載附件中沒有看到圖
作者: 潘基文23321    時(shí)間: 2020-3-9 12:41
不錯(cuò)不錯(cuò),我喜歡,謝謝的
作者: haiyang33333    時(shí)間: 2020-4-27 10:14
下載附件中沒有看到圖
作者: anyong1    時(shí)間: 2020-5-14 19:32
掛羊肉賣狗頭
