#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
uchar count,shi,fen ,miao;
uchar code table[]=" 2009-5-16";
uchar code table1[]=" 00:00:00";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
uchar ge, shi ;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_data(0x30+shi);
write_data(0x30+ge);
void write_com(uchar com)
lcdrs=0;
lcden=0;
delay(5);
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
lcden=0;
delay(5);
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
lcdrw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com (0x80);
TMOD=0X01;
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
EA=1;
ET0=1;
TR0=1;
main()
uchar num;
init();
for(num=0;num<12;num++)
write_data(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<11;num++)
write_data(table1[num]);
delay(5);
if(count==20)
miao++;
if(miao==60)
miao==0;
fen++;
if(fen==60)
{fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(10,miao);
void time0() interrupt 1
count++;
}keil調(diào)試后,出現(xiàn) warning C206: 'write_com': missing function-prototype。
write_com(0x80+0x40+add);這句有何錯(cuò)
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void write_com(uchar com);
void write_data(uchar date);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--)
uchar ge, shi ;
shi=date/10;
ge=date%10;
lcdrs=0;
lcden=0;
delay(5);
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
lcdrs=1;
lcden=0;
delay(5);
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
lcdrw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com (0x80);
TMOD=0X01;
EA=1;
ET0=1;
TR0=1;
main()
uchar num;
init();
delay(5);
delay(5);
if(count==20)
miao++;
if(miao==60)
miao==0;
fen++;
if(fen==60)
{fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(10,miao);
count++;
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
lcdrs=1;
lcden=0;
delay(5);
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_com( uchar com)
lcdrs=0;
lcden=0;
delay(5);
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
uchar ge, shi ;
shi=date/10;
ge=date%10;
void init()
lcdrw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com (0x80);
TMOD=0X01;
EA=1;
ET0=1;
TR0=1;
main()
uchar num;
init();
delay(5);
delay(5);
if(count==20)
miao++;
if(miao==60)
miao==0;
fen++;
if(fen==60)
{fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(10,miao);
count++;
支持樓上了,寫(xiě)函數(shù)之前,在main之前聲明一下啊。
一樓正解,write_com()跟write_data()這兩個(gè)函數(shù)要寫(xiě)在write_sfm()前面,在者在它前面需要有個(gè)函數(shù)說(shuō)明,不然調(diào)用的時(shí)候找不到地址,系統(tǒng)不知道去哪里找這個(gè)函數(shù)
