一個單片機通過串口控制另一個單片機的led燈 Proteus仿真源程序
swl1515
2019-11-27 18:03
(20.72 KB, 下載次數: 58)
2019-12-3 15:25 上傳
/*************** writer:shopping.w ******************/
#include <reg52.h>
sbit LED1 = P0^0;
sbit LED2 = P0^3;
sbit K1 = P1^0;
void Delay(uint x)
uchar i;
while(x--)
for(i=0;i<120;i++);
void putc_to_SerialPort(uchar c)
SBUF = c;
while(TI == 0);
TI = 0;
uchar Operation_NO = 0;
SCON = 0x40;
TMOD = 0x20;
PCON = 0x00;
TH1 = 0xfd;
TL1 = 0xfd;
TI = 0;
TR1 = 1;
if(K1 == 0)
while(K1==0);
Operation_NO=(Operation_NO+1)%4;
switch(Operation_NO)
case 0:
LED1=LED2=1; break;
case 1:
putc_to_SerialPort('A');
LED1=~LED1;LED2=1;break;
case 2:
putc_to_SerialPort('B');
LED2=~LED2;LED1=1;break;
case 3:
putc_to_SerialPort('C');
LED1=~LED1;LED2=LED1;break;
Delay(10);
甲機通過串口控制乙機LED閃爍.rar
(53.81 KB, 下載次數: 36)
2019-11-27 18:02 上傳
shenyan2009
2020-6-4 10:14
學習了 不錯啊
