STM32 KEY 4*4按鍵掃描源程序
liuyibo
2019-11-26 16:11
原理很簡單 慢慢看 就看懂了
#include "key.h"
#include "delay.h"
typedef struct
GPIO_TypeDef* GPIOX;
uint16_t GPIO_Pin;
}KGPT[2][4];
KGPT KPIN={ {{GPIOG,GPIO_Pin_11},{GPIOG,GPIO_Pin_9}, {GPIOD,GPIO_Pin_6},{GPIOD,GPIO_Pin_4}} ,//row 橫行
{{GPIOD,GPIO_Pin_2}, {GPIOD,GPIO_Pin_0},{GPIOC,GPIO_Pin_11},{GPIOA,GPIO_Pin_15}}
}; //col 豎行
#define RCC_APB2_GPIOX RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOG//IO時鐘
#define MAX_Time 36000000 // 松手檢測最大延時
//按鍵初始化函數(shù)
void KEY_Init(void)
u8 i;
RCC_APB2PeriphClockCmd(RCC_APB2_GPIOX,ENABLE);//使能PORTC時鐘
for(i=0;i<4;i++)
GPIO_InitStructure.GPIO_Pin = KPIN[0][i].GPIO_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //設(shè)置成推挽輸出
GPIO_Init(KPIN[0][i].GPIOX, &GPIO_InitStructure);//初始化row
GPIO_ResetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin);
for(i=0;i<4;i++)
GPIO_InitStructure.GPIO_Pin = KPIN[1][i].GPIO_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //設(shè)置成S拉輸入
GPIO_Init(KPIN[1][i].GPIOX, &GPIO_InitStructure);//初始化col
u8 ReScan(GPIO_TypeDef* GPIOX,uint16_t colPin,u8 colIndex)
u8 i;
delay_ms(10);//消抖延時
for(i = 0;i<4;i++){
GPIO_SetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin);//每個行置1
if((GPIO_ReadInputDataBit(GPIOX, colPin) == 1)) //如果列也變了 行的值就知道了 為 i
GPIO_ResetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin); //行恢復(fù) 置0
return colIndex+i*4+1;//返回的數(shù)據(jù) 為1-16 對應(yīng)4x4鍵盤的16個鍵
return 0;
u8 KEY_Scan(void)
u8 i,keyvalue;
//u32 j=0;
for(i = 0;i<4;i++)
if(GPIO_ReadInputDataBit(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin) == 0)//檢測列 列值為 i
keyvalue = ReScan(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin,i);//檢測行 取鍵值
while(GPIO_ReadInputDataBit(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin) == 0);
// while((GPIO_ReadInputDataBit(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin) == 0)&&(j<MAX_Time))j++;//松手檢測
return keyvalue;//返回鍵值
return 0;
KEY按鍵掃描.rar
(1.33 KB, 下載次數(shù): 21)
2019-11-26 16:11 上傳
STM32
admin
2019-11-26 19:49
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
