標(biāo)題: 8051 寫讀(寫后再讀出)24c02 iic程序報(bào)錯(cuò)45&47行。幫忙查一下 [打印本頁(yè)]
作者: hary    時(shí)間: 2012-12-22 21:14
#include<reg51.h>
#include<intrins.h>
#include<absacc.h>
#define lcddisp P0
#define unint unsigned int
#define unchar unsigned char
#define _5us_delay {_nop_();_nop_();_nop_();_nop_();_nop_()}
 sbit EN=P2^0;
 sbit RW=P2^1;
 sbit RS=P2^2;
 sbit SCL=P2^3;
 sbit SDA=P2^4;
 bit ack;
 unchar rxtable[56];
 unchar m=0;//for 1602 顯示計(jì)數(shù)
 unchar txtable[56]=" FM 89.6 please turn the key to the channel you wish to!";//
{    void lcd_init(void);
     void lcd_wcom(unchar com);
  void lcd_wdata(unchar lcddata);
     void iic_init(void);
  void iic_star(void);
  void iic_stop(void);
     void iic_sendbyte(unchar c);//需發(fā)送c
  unchar  iic_rcvbyte();//需返回c
  void iic_ack(void);
  void iic_nack(void);
  void ms_delay(unchar);
void iic_sendstr(unchar sla,unchar suba,unchar *s,unchar n);
void iic_rcvstr(unchar sla,unchar suba,unchar *s,unchar n);
      unchar i;
   TMOD=0x20;//定時(shí)器0工作方式2
   SCON=0xd0;//串口工作方式3,sm2=0允許接收
   PCON&=0x7F;//SMOD=0
   TH1=0xfd;
   TL1=0xfd;//9600 @11.0592MHZ
   TR1=1;//定時(shí)器1開
   ES=1;//開串口中斷
   EA=1;//開中斷
  lcd_init();//1602&iic初始化
  iic_init();
void iic_sendstr(0xa8,0x10,txtable,0x38);//報(bào)錯(cuò)IIC_24C02.C(45): error C141: syntax error near 'void'
      ms_delay(110);
void iic_rcvstr(0xa8,0x10,rxtable,0x38);//報(bào)錯(cuò)IIC_24C02.C(47): error C141: syntax error near 'void'
    ms_delay(110);
lcd_wcom(0x80);
for(m=0;m<16;m++)
{lcd_wdata(rxtable[m]);
ms_delay(5);}
lcd_wcom(0x80+0x44);
{for(m=16;m<32;m++)
lcd_wdata(rxtable[m]);}
while(1);
/*--------向地址為sla,子地址為suba,寫入以*s為地址的數(shù)據(jù)------*/
           {unchar i;
           iic_star();//啟動(dòng)總線
     iic_sendbyte(sla);//發(fā)送器件地址 sla
     iic_sendbyte(suba);//發(fā)送器件子地址 suba
 for(i=0;i<n;i++)//發(fā)送數(shù)據(jù)
        {iic_sendbyte(*s);
   s++;
   iic_stop();//發(fā)送結(jié)束
 /*--------接收數(shù)據(jù)------*/
  {unchar i;
 iic_sendbyte(sla);//送器件地址
    iic_sendbyte(suba);//送器件子地址
    iic_star();//再次發(fā)起啟動(dòng)信號(hào),啟動(dòng)讀程序
 sendbyte(sla+1);//SLA+1 進(jìn)入讀程序
 for(i=0;i<n;i++)//對(duì)前n-1個(gè)字節(jié)發(fā)應(yīng)答信號(hào)
     {*s=iic_rcvbyte();//接收iic_rcvbyte信號(hào)
   iic_ack();
   s++;
  *s=rcvbyte();//接收最后一個(gè)信號(hào)
  iic_nack();//發(fā)非應(yīng)答信號(hào)
  iic_stop();//結(jié)束
   /*------------------從iic BUS接收(讀)一個(gè)字節(jié)--------------------*/
 unchar rcvbyte()
 {unchar c,n;
  for(n=0;n<8;n++)
  {SDA=1;
   SCL=1;
   if(SDA==0)c=c&0x7f;
   else c=c|0x80;
   c=_crol_(c,1);
   SCL=0;
   return(c);//傳回c
  /*------------------向iic BUS 發(fā)送一個(gè)字節(jié)+應(yīng)答判斷------------------*/
  void sendbyte(unchar c)
   {unchar n;
delay : _5us_delay;
     for(n=0;n<8;n++)//循環(huán)8次,先送高位,后送低位
     {if(c&0x08)SDA=1;//根據(jù)發(fā)送位將SDA置為1/清零
         else SDA=0;
   SCL=1;  //置時(shí)鐘線SCL為高,通知被控從機(jī)開始接收數(shù)據(jù)位
   _5us_delay;
   SCL=0;//SCL LOW 防誤,及準(zhǔn)備下次通信。
   c=c<<1;   //移到到最高位
  _5us_delay;
  SDA=1; //8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位
  _NOP_();
  scl=1; // SCL由低變高,產(chǎn)生一個(gè)時(shí)鐘,讀取SDA狀態(tài)
  _5us_delay;
  if(SDA==1){ack=0;goto delay;}//如果SDA=1,則發(fā)送失敗,將ack_mk清零
       else ack=1; // 否則發(fā)送成功,將ack_mk置1
    SCL=0;
  void iic_init(void)
  {sda=1;
 _5us_delay;
 scl=1;
 _5us_delay;
     void ii_star()//啟動(dòng)iic函數(shù)
  {SDA=1;
   SCL=1;
   _5us_delay;
   SDA=0;
   _5us_delay;
   SCL=0;
  void iic_stop()//結(jié)束iic函數(shù)
  {SDA=0;
   SCL=1;
   _5us_delay;
   SDA=1;
   _5us_delay;
   SCL=0;
  void ack(void)
  {SDA=0;//SDA先清零,發(fā)送應(yīng)答信號(hào)
   SCL=1;
   _5us_delay;
   SCL=0;
  void nack(void)
  {SDA=1;//SDA先置1,發(fā)非應(yīng)答信號(hào)
   SCL=1;// 由低變高,產(chǎn)生一個(gè)時(shí)鐘
   _5us_delay;// 延時(shí)5us
   SCL=0;   //時(shí)鐘線SCL清恢復(fù)到低電平,以便繼續(xù)接收
/*----------LCD 初始化---------------------------*/
  void lcd_init() /*LCD intiation*/
  {lcd_wcom(0x38); //八位數(shù)據(jù),雙列
   lcd_wcom(0x0c);
   lcd_wcom(0x06);
   lcd_wcom(0x01);
/*-------------1602指令-------------------------*/
  void lcd_wcom(unchar com)/*com regester*/
  {RW=0;           //寫1602
   RS=0;          //選寄存器
   lcddisp=com;  //指令傳送
      ms_delay(1); //等待1602發(fā)送數(shù)據(jù)
   EN=1;
   _nop_();
   _nop_();
   EN=0;
  /*--------------1602數(shù)據(jù)顯示---------------------------*/
  void lcd_wdata(unchar lcddata)/*data regester*/
  RW=0;
  RS=1;
     lcddisp=lcddata;//lcd data 是否還需申明呢?
  ms_delay(1);
  EN=1;
   _nop_();
   _nop_();
   EN=0;
 /*---------------delay-----------------------*/
  void ms_delay(unint delaytime)//delay
 {unint i=0;
  for(;delaytime>0;delaytime--)
  {for(i=0;i<124;i++); }}
作者: ahshmj    時(shí)間: 2012-12-25 11:12
你知道錯(cuò)誤提示中的“void”是什么意思嗎?
