51單片機實時數(shù)據(jù)采集ADC0809與報警系統(tǒng)源程序
wangfushou
2019-11-22 17:06
51實時數(shù)據(jù)采集ADC0809與報警系統(tǒng)
//程序編寫:劉先生
接線:D0--D7接P0.0-P0.7
ST---P2.3
EOC--P2.2
OE---P2.1
CLK--P2.0
[注:使用12M或11.0592M晶振,實測使用11.0592M]
#include <reg52.H> //器件配置文件
#include <intrins.h>
#include "lcd.h"
#define adc0809_data P3 //單片機P0接模塊D0~D7引腳
sbit STR = P2^3; //單片機P2.3接模塊STR引腳, 啟動轉換信號
sbit EOC = P2^2; //單片機P2.2接模塊EOC, 轉換結束信號,高電平有效
sbit OE = P2^1; //單片機P2.1接模塊OE,輸出允許信號,高電平有效
sbit CLK = P2^0; //單片機P2.0接CLK ,ADC0809時鐘,輸入50-800KHZ的頻率
//一般選用500K
//將短接片去掉開啟位選功能,否則默認IN0為輸入引腳
sbit AA = P2^6; //單片機P2.6接模塊A引腳
sbit BB = P2^5; //單片機P2.6接模塊B引腳
sbit CC = P2^4; //單片機P2.6接模塊C引腳
unsigned char AD_DATA[1]; //保存IN0通道轉換后的數(shù)據(jù)
unsigned char disbuff[4] = { 0,0,0,0,};
unsigned char Disp[]="0123456789"; //使用字符串保存數(shù)字0~9所對應的ASCLL碼
unsigned char I_Disp[]="Smoke_C : "; //初始顯示值
unsigned char i;
函數(shù)名: AD()
功能: 啟動AD轉換將值儲存于 AD_DATA[0]
void AD(void )
STR=0;
STR=1; //啟動AD轉換
STR=0;
while(0==EOC);//等待轉換結束
OE=1;
AD_DATA[0]=adc0809_data; //讀取AD數(shù)據(jù),數(shù)據(jù)范圍為0-255
OE=0;
函數(shù)名: t0()
功能: 產(chǎn)生ADC0809CLK所需要的時鐘
void t0(void) interrupt 1 using 0
CLK=~CLK;
函數(shù)名: Conut()
功能: 將AD_DATA[0]的各位拆分以方便lcd顯示
void Conut(void)
disbuff[0]=AD_DATA[0]/100;
disbuff[1]=AD_DATA[0]/10%10;
disbuff[2]=AD_DATA[0]%10;
函數(shù)名: delayms()
功能: 延時 ms 毫秒
void delayms(unsigned int ms)
unsigned char j;
i=100;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
函數(shù)名: LcdDisplay()
功能: 用lcd顯示數(shù)組disbuff[]中的值
void LcdDisplay(void)
LcdWriteCom(0x0b+0x80);
for(i=0;i<3;i++)
LcdWriteData(Disp[disbuff[i]]);
函數(shù)名: Analog_IO_Sel()
參數(shù)說明: m 的值對應ADC0809芯片上模擬輸入的IO
功能: 確定模擬輸入位選
void Analog_IO_Sel(unsigned char m)
switch(m)
case 0 : CC = 0; BB = 0; AA = 0; break;
case 1 : CC = 0; BB = 0; AA = 1; break;
case 2 : CC = 0; BB = 1; AA = 0; break;
case 3 : CC = 0; BB = 1; AA = 1; break;
case 4 : CC = 1; BB = 0; AA = 0; break;
case 5 : CC = 1; BB = 0; AA = 1; break;
case 6 : CC = 1; BB = 1; AA = 0; break;
case 7 : CC = 1; BB = 1; AA = 1; break;
EA=1; //開總中斷
TMOD=0x02; //設定定時器 T0工作方式
TH0=216; //利用T0中斷產(chǎn)生CLK信號
TL0=216;
TR0=1; //啟動定時器T0
ET0=1;
STR=0;
OE=0;
Analog_IO_Sel(0); //設置為IN0輸入
LcdInit();
for(i=0;i<10;i++) //顯示初始值
LcdWriteData(I_Disp[i]);
AD();
Conut(); //計算
LcdDisplay(); //lcd顯示
delayms(10); //10MS
單片機控制系統(tǒng)綜合實訓.7z
(181.49 KB, 下載次數(shù): 58)
2019-11-22 17:48 上傳
(71.41 KB, 下載次數(shù): 114)
2019-11-22 17:05 上傳
高富師
2025-6-9 09:16
報警模塊在哪?
