標題: 關于51單片機利用rs485進行多機通信的問題 [打印本頁]
作者: tomli561    時間: 2019-11-14 13:31
我現在發送端發送地址,接收端能收到,但是收到地址后就無法執行后面的操作了,麻煩給位幫我看看(程序是從網上找的例程小改了下,只改了幾個端口定義)
發送端:
#include <reg52.h>
sbit LED1 = P3^4;
sbit LED2 = P3^5;
sbit MCU1 = P2^2;
sbit MCU2 = P2^3;
sbit rs485dir = P3^2;
uchar code tab[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x77,0x7c};
uchar keyscan(void);
void delayms(uint t);
void init_serial(void);
void SBUFSend(uchar key);
void senddat(uchar addr,uchar dat);
void display(uchar addr,uchar dat);
/******************************按鍵掃描函數*******************************/
uchar keyscan(void)
        uchar temp,key;
        P0 = 0xfe;
        temp = P0;
        temp = temp&0xf0;
        if(temp!=0xf0)
                delayms(10);
                if(temp!=0xf0)
                        temp = P0;
                        switch(temp)
                                case 0xee:        key = 0;        break;
                                case 0xde:        key = 1;        break;
                                case 0xbe:        key = 3;        break;
                                case 0x7e:        key = 4;        break;
                        while(temp!=0xf0)
                                temp = P0;
                                temp = temp&0xf0;
        P0 = 0xfd;
        temp = P0;
        temp = temp&0xf0;
        if(temp!=0xf0)
                delayms(10);
                if(temp!=0xf0)
                         temp = P0;
                         switch(temp)
                                 case 0xed:        key = 4;        break;
                                case 0xdd:        key = 5;        break;
                                case 0xbd:        key = 6;        break;
                                case 0x7d:        key = 7;        break;
                         while(temp!=0xf0)
                                 temp = P0;
                                temp = temp&0xf0;
        P0 = 0xfb;
        temp = P0;
        temp = temp&0xf0;
        if(temp!=0xf0)
                delayms(10);
                if(temp!=0xf0)
                        temp = P0;
                        switch(temp)
                                case 0xeb:        key = 8;        break;
                                case 0xdb:        key = 9;        break;
                                case 0xbb:        key = 10;        break;
                                case 0x7b:        key = 11;        break;
                        while(temp!=0xf0)
                                temp = P0;
                                temp = temp&0xf0;
        P0 = 0xf7;
        temp = P0;
        temp = temp&0xf0;
        if(temp!=0xf0)
                delayms(10);
                if(temp!=0xf0)
                        temp = P0;
                        switch(temp)
                                case 0xe7:        key = 12;        break;
                                case 0xd7:        key = 13;        break;
                                case 0xb7:        key = 13;        break;
                                case 0x77:        key = 15;        break;
                        while(temp!=0xf0)
                                temp = P0;
                                temp = temp&0xf0;
        return key;
/******************************毫秒延時函數*******************************/
        uchar i,j;
        for(i=0;i<t;i++)
                for(j=0;j<110;j++);
/********************定時器串口寄存器初始化函數***************************/
        TMOD = 0x20;
        TH1 = 0xfa;
        TL1 = 0xfa;
        PCON = 0x80;
        SCON = 0x50;
        TR1 = 1;
        ES = 1;
        EA = 1;
        rs485dir = 1;
/******************************信息發送函數*******************************/
        SBUF = key;
        while(TI ==0);
        TI = 0;
/****************************發送地址數據函數*****************************/
        TB8 = 1;
        SBUFSend(addr);
        delayms(1);
        TB8 = 0;
        SBUFSend(dat);
        delayms(1);
/*****************************數碼管顯示函數******************************/
        P1 = tab[addr];                /*顯示發送的地址*/
        LED1 = 0;
        LED2 = 1;
        delayms(1000);
        P1 = 0x00;
        P1 = tab[dat];                /*顯示發送的數據*/
        LED1 = 1;
        LED2 = 0;
        delayms(1000);
        P1 = 0x00;
        char addr,dat;
        init_serial();
        dat = keyscan();
                if(MCU1==0)
                        addr = 1;
                        dat = keyscan();
                        senddat(1,dat);
                        display(1,dat);
                if(MCU2==0)
                        addr = 2;
                        dat = keyscan();
                        senddat(2,dat);
                        senddat(2,dat);
void serial_init()        interrupt 4
        if(RI==1)
                RI = 0;
        if(TI==1)
                TI = 0;
接收端:
#include <reg52.h>
sbit LED1 = P1^0;
sbit LED2 = P1^1;
uchar DispCode[16] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
void SerialInit()
        SCON = 0xf0;
        PCON = 0x00;
        TMOD = 0x20;
        TH1 = 0xfd;
        TH1 = 0xfd;
        TR1 = 1;
        ES = 1;
        EA = 1;
void SBUFSend(uchar Ch)
        SBUF = Ch;
        while(TI==0);
        TI = 0;
        P2 = 0xff;
        SerialInit();
        while(1);
void SerialServer()        interrupt 4
        uchar Ch;
        if(RI == 1)
                uchar i;
                RI = 0;
                Ch = SBUF;
                if(RB8 == 1)
                        if(Ch==1)
                                SM2 = 0;
                                SBUFSend(1);
                                LED1 = 0;
                                LED2 = 1;
                                for(i=500;i>0;i--)
                                        P2 = DispCode[Ch];
                                SM2 = 1;
                if(RB8 == 0)
                        P2 = 0xff;
                        LED1 = 1;
                        LED2 = 0;
                        for(i=500;i>0;i--)
                                P2 = DispCode[Ch];
                        SM2 = 1;
作者: faiwong    時間: 2019-11-14 20:47
把主機發送數據改在收到分機應答后再發送
作者: tomli561    時間: 2019-11-15 10:15
faiwong 發表于 2019-11-14 20:47
把主機發送數據改在收到分機應答后再發送
必須驗證地址后才能再發送數據么?那后面發送完數據后是不是也還要在驗證?
作者: tomli561    時間: 2019-11-15 10:21
把主機發送數據改在收到分機應答后再發送
        TB8 = 1;
        SBUFSend(addr);
        rs485dir = 0;
        while(!RI);
        RI = 0;
        rs485dir = 1;
        TB8 = 0;
        SBUFSend(dat);
吧這個數據發送函數改成了這樣還是不行啊
作者: lele5211314    時間: 2019-11-15 18:48
RS485通訊這一部分我比較擅長,可以加我QQ詳細教你下
作者: yzwzfyz    時間: 2019-11-16 09:10
先弄清楚通訊原理,再構思出通訊的協議,而后再寫程序才靠譜。
作者: tomli561    時間: 2019-11-18 10:51
yzwzfyz 發表于 2019-11-16 09:10
通信原理知道哈, 第一次些 細節肯定沒法都注意到,所以才會找例程這樣學習才是最快的,啥都自己摸索有些東西沒有那個思維很難解決,我在這提問肯定是遇到了自己無法解決的問題,別老是覺得什么都很輕松一樣靠自學都行,要是這樣了師傅下崗得了,學生只要發本教材自己學就可以了
作者: tomli561    時間: 2019-11-18 10:52
把主機發送數據改在收到分機應答后再發送
親,有沒有完整能用的例程給小弟一下,萬分 感謝
作者: faiwong    時間: 2019-11-19 15:20
tomli561 發表于 2019-11-15 10:21
        TB8 = 1;
把主機發送數據改在收到分機應答后再發送
        TB8 = 1;
        SBUFSend(addr);
        while(!TI);
        TI=0;
        rs485dir = 0;
        while(!RI);
        RI = 0;
        rs485dir = 1;
        TB8 = 0;
        SBUFSend(dat);
這樣試試,要讓CPU數據發送完畢才 rs485dir = 0;不然你的數據送不到485總線上
正常情況不建議用  while(!RI);
