松翰SN8P2758單片機設置128階電流型模擬信號輸出源程序
huaxing
2019-10-22 17:18
功能代碼 設置128階電流型模擬信號輸出 匯編和C兩種代碼
chip sn8p2758
.data
.code
org 00h
jmp main
org 10h
// DAC
main:
mov a,#01111111b // Setting value as 0xxxxxxxb -->0~127
b0mov dam,a // Set DAB to a half of the full scale.
b0bset fdaenb // Enable D/A function
// User code
jmp main
