rtthread stm32f103 modbus 從機例程
mikehhuang
2019-9-28 20:02
stm32F103 最小系統,modbus slave RTU 示例代碼,采用freemodbus
#include <rtthread.h>
#include <rtdevice.h>
#include <board.h>
#include "wdt.h"
//#include "uart.h"
//#include "mpu6050.h"
#include "mb_slave.h"
#include "bsp_flash.h"
/* 私用宏定義----------------------------------------------------------------*/
#define THREAD_PRIORITY 25
#define THREAD_STACK_SIZE 512
#define THREAD_TIMESLICE 5
#define EVENT_BIT_0 (1 << 0)
#define EVENT_BIT_1 (1 << 1)
//#define EVENT_BIT_2 (1 << 2)
//#define EVENT_BIT_3 (1 << 3)
//#define EVENT_BIT_4 (1 << 4)
//#define EVENT_BIT_5 (1 << 5)
/* 私用變量----------------------------------------------------------------*/
/**************************** 任務句柄 ********************************/
static rt_thread_t th_wdg = RT_NULL; //看門狗
static rt_thread_t th_Gyro = RT_NULL; //陀螺儀
/*事件控制塊*/
static struct rt_event event;
/*wdg 入口函數*/
static void th_wdg_entry(void *parameter)
rt_uint32_t count = 0;
while (1)
// rt_kprintf("wdg thread count: %d\n", count ++);
rt_thread_mdelay(50);
/* 收到所有事件,復位看門狗*/
rt_uint32_t e;
if (rt_event_recv(&event, (EVENT_BIT_0 ),
RT_EVENT_FLAG_AND | RT_EVENT_FLAG_CLEAR,
RT_WAITING_FOREVER, &e) == RT_EOK)
// rt_kprintf("wdg: AND recv event 0x%x\n", e);
//喂狗
iwdg_feed();
/* gyro 入口函數*/
static void th_Gyro_entry(void *parameter)
// float angle_Y = 0; //初始狀態值
// float angle_X = 0;
// float angle_Z = 0;
// rt_int16_t temp; //溫度
// rt_int16_t gx,gy,gz; //三軸加速度
// rt_int16_t ax,ay,az; //三軸角速度
// rt_err_t ret;
// ret = mpu6050_temperature_get(&temp);
// if (ret != RT_EOK)
// rt_kprintf("mpu6050 : get temperature error\r\n");
// ret = mpu6050_accelerometer_get(&ax, &ay, &az);
// rt_kprintf("mpu6050 : get acc error\r\n");
// ret = mpu6050_gyroscope_get(&gx, &gy, &gz);
// rt_kprintf("mpu6050 : get gyro error\r\n");
// if (ret == RT_EOK)
// rt_kprintf("mpu6050: temperature=%-6d gx=%-6d gy=%-6d gz=%-6d ax=%-6d ay=%-6d az=%-6d\r\n",temp/100,gx,gy,gz,ax,ay,az);
// angle_X=Kalman_X(ax/100,ay/100,az/100,gx,gy,gz);
// angle_Y=Kalman_Y(ax/100,ay/100,az/100,gx,gy,gz);
// angle_Z=Kalman_Z(ax/100,ay/100,az/100,gx,gy,gz);
// rt_kprintf("x=%-6d y=%-6d z=%-6d \r\n ",angle_X,angle_Y,angle_Z);
// rt_thread_delay(rt_tick_from_millisecond(1000));
rt_event_send(&event, EVENT_BIT_0);
rt_thread_delay(200);
//動態創建線程
void th_create(){
rt_err_t result;
/* 初始化事件對象 */
result = rt_event_init(&event, "event", RT_IPC_FLAG_FIFO);
if (result != RT_EOK)
rt_kprintf("init event failed.\n");
return ;
/*動態創建WDG線程*/
th_wdg = rt_thread_create("wdg",
th_wdg_entry, RT_NULL,
THREAD_STACK_SIZE-256,
THREAD_PRIORITY, THREAD_TIMESLICE);
/* 如果獲取線程控制塊,啟動這個線程 */
if (th_wdg != RT_NULL)
rt_thread_startup(th_wdg);
/*動態創建姿態獲取線程*/
th_Gyro = rt_thread_create("Gyro",
th_Gyro_entry, RT_NULL,
THREAD_STACK_SIZE,
THREAD_PRIORITY-1, THREAD_TIMESLICE);
if (th_Gyro != RT_NULL)
rt_thread_startup(th_Gyro);
int main(void)
// //485 初始化
// uart5_init();
//創建線程
th_create();
//modbus 初始化
mb_slave_init();
//看門狗初始化
if(iwdg_init()==RT_EOK){
rt_kprintf("iwdg init success.\n");
// rt_pin_mode(MODBUS_MASTER_RT_CONTROL_PIN_INDEX, PIN_MODE_OUTPUT);
// rt_pin_write(MODBUS_MASTER_RT_CONTROL_PIN_INDEX, PIN_HIGH);
// #define RT_MODBUS_MASTER_USE_CONTROL_PIN 1
// #define MODBUS_MASTER_RT_CONTROL_PIN_INDEX 19
// uint16_t Data [6] = {7,1,2,3,4,5};
// uint32_t Address = 0x0800FC00 ;
// FLASH_WriteData(Address,Data,1);
// uint16_t Text [6] = {0};
// FLASH_ReadMoreData(Address,Text,6);
// for(int i=0;i<6;i++){
// rt_kprintf("%d \r\n",Text[i]);
return RT_EOK;
stm32f103_modbus.rar
(111.17 KB, 下載次數: 74)
2019-9-28 20:01 上傳
shanren1
2021-3-2 16:45
能不能直接用?
