標題: aes_128算法verilog實現程序 [打印本頁]
作者: 吉閬尤人    時間: 2019-9-19 11:20
AES算法FPGA實現,包括密鑰加變換,字節代換,密鑰擴展,行位移,列混合
  1. `timescale 1ns / 1ps
  2. //////////////////////////////////////////////////////////////////////////////////
  3. // Company:
  4. // Engineer:
  5. //
  6. // Create Date:    21:27:15 12/03/2013
  7. // Design Name:
  8. // Module Name:    test
  9. // Project Name:
  10. // Target Devices:
  11. // Tool versions:
  12. // Description:
  13. //
  14. // Dependencies:
  15. //
  16. // Revision:
  17. // Revision 0.01 - File Created
  18. // Additional Comments:
  19. //
  20. //////////////////////////////////////////////////////////////////////////////////
  21. module test_bench_top;
  22. reg                clk;
  23. reg                rst;
  24. reg        [383:0]        tv[512:0];
  25. reg        [383:0]        tmp;
  26. reg                kld;
  27. reg        [127:0]        plain, ciph;
  28. reg        [127:0]        key,text_in;
  29. wire        [127:0]        text_out;
  30. wire        [127:0]        text_out2;
  31. //reg        [127:0]        text_exp;
  32. wire                done, done2;
  33. integer                n, error_cnt;
  34. initial
  35.    begin
  36.         $display("\n\n");
  37.         $display("*****************************************************");
  38.         $display("* AES Test bench ...");
  39.         $display("*****************************************************");
  40.         $display("\n");
  41. `ifdef WAVES
  42.           $shm_open("waves");
  43.         $shm_probe("AS",test,"AS");
  44.         $display("INFO: Signal dump enabled ...\n\n");
  45. `endif
  46.         kld = 0;
  47.         clk = 0;
  48.         rst = 0;
  49.         error_cnt = 0;
  50.         repeat(4)        @(posedge clk);
  51.         rst = 1;
  52.         repeat(20)        @(posedge clk);
  53.         $display("");
  54.         $display("");
  55.         $display("Started random test ...");
  56. tv[0]= 384'h00000000000000000000000000000000f34481ec3cc627bacd5dc3fb08f273e60336763e966d92595a567cc9ce537f5e;
  57. tv[1]= 384'h000000000000000000000000000000009798c4640bad75c7c3227db910174e72a9a1631bf4996954ebc093957b234589;
  58. tv[2]= 384'h0000000000000000000000000000000096ab5c2ff612d9dfaae8c31f30c42168ff4f8391a6a40ca5b25d23bedd44a597;
  59. tv[3]= 384'h000000000000000000000000000000006a118a874519e64e9963798a503f1d35dc43be40be0e53712f7e2bf5ca707209;
  60. tv[4]= 384'h00000000000000000000000000000000cb9fceec81286ca3e989bd979b0cb28492beedab1895a94faa69b632e5cc47ce;
  61. tv[5]= 384'h00000000000000000000000000000000b26aeb1874e47ca8358ff22378f09144459264f4798f6a78bacb89c15ed3d601;
  62. tv[6]= 384'h0000000000000000000000000000000058c8e00b2631686d54eab84b91f0aca108a4e2efec8a8e3312ca7460b9040bbf;
  63. tv[7]= 384'h10a58869d74be5a374cf867cfb473859000000000000000000000000000000006d251e6944b051e04eaa6fb4dbf78465;
  64. tv[8]= 384'hcaea65cdbb75e9169ecd22ebe6e54675000000000000000000000000000000006e29201190152df4ee058139def610bb;
  65. tv[9]= 384'ha2e2fa9baf7d20822ca9f0542f764a4100000000000000000000000000000000c3b44b95d9d2f25670eee9a0de099fa3;
  66. tv[10]= 384'hb6364ac4e1de1e285eaf144a2415f7a0000000000000000000000000000000005d9b05578fc944b3cf1ccf0e746cd581;
  67. tv[11]= 384'h64cf9c7abc50b888af65f49d521944b200000000000000000000000000000000f7efc89d5dba578104016ce5ad659c05;
  68. tv[12]= 384'h47d6742eefcc0465dc96355e851b64d9000000000000000000000000000000000306194f666d183624aa230a8b264ae7;
  69. tv[13]= 384'h3eb39790678c56bee34bbcdeccf6cdb500000000000000000000000000000000858075d536d79ccee571f7d7204b1f67;
  70. tv[14]= 384'h64110a924f0743d500ccadae72c134270000000000000000000000000000000035870c6a57e9e92314bcb8087cde72ce;
  71. tv[15]= 384'h18d8126516f8a12ab1a36d9f04d68e51000000000000000000000000000000006c68e9be5ec41e22c825b7c7affb4363;
  72. tv[16]= 384'hf530357968578480b398a3c251cd109300000000000000000000000000000000f5df39990fc688f1b07224cc03e86cea;
  73. tv[17]= 384'hda84367f325d42d601b4326964802e8e00000000000000000000000000000000bba071bcb470f8f6586e5d3add18bc66;
  74. tv[18]= 384'he37b1c6aa2846f6fdb413f238b089f230000000000000000000000000000000043c9f7e62f5d288bb27aa40ef8fe1ea8;
  75. tv[19]= 384'h6c002b682483e0cabcc731c253be5674000000000000000000000000000000003580d19cff44f1014a7c966a69059de5;
  76. tv[20]= 384'h143ae8ed6555aba96110ab58893a8ae100000000000000000000000000000000806da864dd29d48deafbe764f8202aef;
  77. tv[21]= 384'hb69418a85332240dc82492353956ae0c00000000000000000000000000000000a303d940ded8f0baff6f75414cac5243;
  78. tv[22]= 384'h71b5c08a1993e1362e4d0ce9b22b78d500000000000000000000000000000000c2dabd117f8a3ecabfbb11d12194d9d0;
  79. tv[23]= 384'he234cdca2606b81f29408d5f6da2120600000000000000000000000000000000fff60a4740086b3b9c56195b98d91a7b;
  80. tv[24]= 384'h13237c49074a3da078dc1d828bb78c6f000000000000000000000000000000008146a08e2357f0caa30ca8c94d1a0544;
  81. tv[25]= 384'h3071a2a48fe6cbd04f1a129098e308f8000000000000000000000000000000004b98e06d356deb07ebb824e5713f7be3;
  82. tv[26]= 384'h90f42ec0f68385f2ffc5dfc03a654dce000000000000000000000000000000007a20a53d460fc9ce0423a7a0764c6cf2;
  83. tv[27]= 384'hfebd9a24d8b65c1c787d50a4ed3619a900000000000000000000000000000000f4a70d8af877f9b02b4c40df57d45b17;
  84. tv[28]= 384'h80000000000000000000000000000000000000000000000000000000000000000edd33d3c621e546455bd8ba1418bec8;
  85. tv[29]= 384'hc0000000000000000000000000000000000000000000000000000000000000004bc3f883450c113c64ca42e1112a9e87;
  86. tv[30]= 384'he00000000000000000000000000000000000000000000000000000000000000072a1da770f5d7ac4c9ef94d822affd97;
  87. tv[31]= 384'hf000000000000000000000000000000000000000000000000000000000000000970014d634e2b7650777e8e84d03ccd8;
  88. tv[32]= 384'hf800000000000000000000000000000000000000000000000000000000000000f17e79aed0db7e279e955b5f493875a7;
  89. tv[33]= 384'hfc000000000000000000000000000000000000000000000000000000000000009ed5a75136a940d0963da379db4af26a;
  90. tv[34]= 384'hfe00000000000000000000000000000000000000000000000000000000000000c4295f83465c7755e8fa364bac6a7ea5;
  91. tv[35]= 384'hff00000000000000000000000000000000000000000000000000000000000000b1d758256b28fd850ad4944208cf1155;
  92. tv[36]= 384'hff8000000000000000000000000000000000000000000000000000000000000042ffb34c743de4d88ca38011c990890b;
  93. tv[37]= 384'hffc00000000000000000000000000000000000000000000000000000000000009958f0ecea8b2172c0c1995f9182c0f3;
  94. tv[38]= 384'hffe0000000000000000000000000000000000000000000000000000000000000956d7798fac20f82a8823f984d06f7f5;
  95. tv[39]= 384'hfff0000000000000000000000000000000000000000000000000000000000000a01bf44f2d16be928ca44aaf7b9b106b;
  96. tv[40]= 384'hfff8000000000000000000000000000000000000000000000000000000000000b5f1a33e50d40d103764c76bd4c6b6f8;
  97. tv[41]= 384'hfffc0000000000000000000000000000000000000000000000000000000000002637050c9fc0d4817e2d69de878aee8d;
  98. tv[42]= 384'hfffe000000000000000000000000000000000000000000000000000000000000113ecbe4a453269a0dd26069467fb5b5;
  99. tv[43]= 384'hffff00000000000000000000000000000000000000000000000000000000000097d0754fe68f11b9e375d070a608c884;
  100. tv[44]= 384'hffff800000000000000000000000000000000000000000000000000000000000c6a0b3e998d05068a5399778405200b4;
  101. tv[45]= 384'hffffc00000000000000000000000000000000000000000000000000000000000df556a33438db87bc41b1752c55e5e49;
  102. tv[46]= 384'hffffe0000000000000000000000000000000000000000000000000000000000090fb128d3a1af6e548521bb962bf1f05;
  103. tv[47]= 384'hfffff0000000000000000000000000000000000000000000000000000000000026298e9c1db517c215fadfb7d2a8d691;
  104. tv[48]= 384'hfffff80000000000000000000000000000000000000000000000000000000000a6cb761d61f8292d0df393a279ad0380;
  105. tv[49]= 384'hfffffc000000000000000000000000000000000000000000000000000000000012acd89b13cd5f8726e34d44fd486108;
  106. tv[50]= 384'hfffffe000000000000000000000000000000000000000000000000000000000095b1703fc57ba09fe0c3580febdd7ed4;
  107. tv[51]= 384'hffffff0000000000000000000000000000000000000000000000000000000000de11722d893e9f9121c381becc1da59a;
  108. tv[52]= 384'hffffff80000000000000000000000000000000000000000000000000000000006d114ccb27bf391012e8974c546d9bf2;
  109. tv[53]= 384'hffffffc0000000000000000000000000000000000000000000000000000000005ce37e17eb4646ecfac29b9cc38d9340;
  110. tv[54]= 384'hffffffe00000000000000000000000000000000000000000000000000000000018c1b6e2157122056d0243d8a165cddb;
  111. tv[55]= 384'hfffffff00000000000000000000000000000000000000000000000000000000099693e6a59d1366c74d823562d7e1431;
  112. tv[56]= 384'hfffffff8000000000000000000000000000000000000000000000000000000006c7c64dc84a8bba758ed17eb025a57e3;
  113. tv[57]= 384'hfffffffc00000000000000000000000000000000000000000000000000000000e17bc79f30eaab2fac2cbbe3458d687a;
  114. tv[58]= 384'hfffffffe000000000000000000000000000000000000000000000000000000001114bc2028009b923f0b01915ce5e7c4;
  115. tv[59]= 384'hffffffff000000000000000000000000000000000000000000000000000000009c28524a16a1e1c1452971caa8d13476;
  116. tv[60]= 384'hffffffff80000000000000000000000000000000000000000000000000000000ed62e16363638360fdd6ad62112794f0;
  117. tv[61]= 384'hffffffffc00000000000000000000000000000000000000000000000000000005a8688f0b2a2c16224c161658ffd4044;
  118. tv[62]= 384'hffffffffe000000000000000000000000000000000000000000000000000000023f710842b9bb9c32f26648c786807ca;
  119. tv[63]= 384'hfffffffff000000000000000000000000000000000000000000000000000000044a98bf11e163f632c47ec6a49683a89;
  120. tv[64]= 384'hfffffffff80000000000000000000000000000000000000000000000000000000f18aff94274696d9b61848bd50ac5e5;
  121. tv[65]= 384'hfffffffffc00000000000000000000000000000000000000000000000000000082408571c3e2424540207f833b6dda69;
  122. tv[66]= 384'hfffffffffe000000000000000000000000000000000000000000000000000000303ff996947f0c7d1f43c8f3027b9b75;
  123. tv[67]= 384'hffffffffff0000000000000000000000000000000000000000000000000000007df4daf4ad29a3615a9b6ece5c99518a;
  124. tv[68]= 384'hffffffffff800000000000000000000000000000000000000000000000000000c72954a48d0774db0b4971c526260415;
  125. tv[69]= 384'hffffffffffc000000000000000000000000000000000000000000000000000001df9b76112dc6531e07d2cfda04411f0;
  126. tv[70]= 384'hffffffffffe000000000000000000000000000000000000000000000000000008e4d8e699119e1fc87545a647fb1d34f;
  127. tv[71]= 384'hfffffffffff00000000000000000000000000000000000000000000000000000e6c4807ae11f36f091c57d9fb68548d1;
  128. tv[72]= 384'hfffffffffff800000000000000000000000000000000000000000000000000008ebf73aad49c82007f77a5c1ccec6ab4;
  129. tv[73]= 384'hfffffffffffc00000000000000000000000000000000000000000000000000004fb288cc2040049001d2c7585ad123fc;
  130. tv[74]= 384'hfffffffffffe000000000000000000000000000000000000000000000000000004497110efb9dceb13e2b13fb4465564;
  131. tv[75]= 384'hffffffffffff000000000000000000000000000000000000000000000000000075550e6cb5a88e49634c9ab69eda0430;
  132. tv[76]= 384'hffffffffffff8000000000000000000000000000000000000000000000000000b6768473ce9843ea66a81405dd50b345;
  133. tv[77]= 384'hffffffffffffc000000000000000000000000000000000000000000000000000cb2f430383f9084e03a653571e065de6;
  134. tv[78]= 384'hffffffffffffe000000000000000000000000000000000000000000000000000ff4e66c07bae3e79fb7d210847a3b0ba;
  135. tv[79]= 384'hfffffffffffff0000000000000000000000000000000000000000000000000007b90785125505fad59b13c186dd66ce3;
  136. tv[80]= 384'hfffffffffffff8000000000000000000000000000000000000000000000000008b527a6aebdaec9eaef8eda2cb7783e5;
  137. tv[81]= 384'hfffffffffffffc0000000000000000000000000000000000000000000000000043fdaf53ebbc9880c228617d6a9b548b;
  138. tv[82]= 384'hfffffffffffffe0000000000000000000000000000000000000000000000000053786104b9744b98f052c46f1c850d0b;
  139. tv[83]= 384'hffffffffffffff00000000000000000000000000000000000000000000000000b5ab3013dd1e61df06cbaf34ca2aee78;
  140. tv[84]= 384'hffffffffffffff800000000000000000000000000000000000000000000000007470469be9723030fdcc73a8cd4fbb10;
  141. tv[85]= 384'hffffffffffffffc0000000000000000000000000000000000000000000000000a35a63f5343ebe9ef8167bcb48ad122e;
  142. tv[86]= 384'hffffffffffffffe0000000000000000000000000000000000000000000000000fd8687f0757a210e9fdf181204c30863;
  143. tv[87]= 384'hfffffffffffffff00000000000000000000000000000000000000000000000007a181e84bd5457d26a88fbae96018fb0;
  144. tv[88]= 384'hfffffffffffffff8000000000000000000000000000000000000000000000000653317b9362b6f9b9e1a580e68d494b5;
  145. tv[89]= 384'hfffffffffffffffc000000000000000000000000000000000000000000000000995c9dc0b689f03c45867b5faa5c18d1;
  146. tv[90]= 384'hfffffffffffffffe00000000000000000000000000000000000000000000000077a4d96d56dda398b9aabecfc75729fd;
  147. tv[91]= 384'hffffffffffffffff00000000000000000000000000000000000000000000000084be19e053635f09f2665e7bae85b42d;
  148. tv[92]= 384'hffffffffffffffff80000000000000000000000000000000000000000000000032cd652842926aea4aa6137bb2be2b5e;
  149. tv[93]= 384'hffffffffffffffffc00000000000000000000000000000000000000000000000493d4a4f38ebb337d10aa84e9171a554;
  150. tv[94]= 384'hffffffffffffffffe00000000000000000000000000000000000000000000000d9bff7ff454b0ec5a4a2a69566e2cb84;
  151. tv[95]= 384'hfffffffffffffffff000000000000000000000000000000000000000000000003535d565ace3f31eb249ba2cc6765d7a;
  152. tv[96]= 384'hfffffffffffffffff80000000000000000000000000000000000000000000000f60e91fc3269eecf3231c6e9945697c6;
  153. tv[97]= 384'hfffffffffffffffffc0000000000000000000000000000000000000000000000ab69cfadf51f8e604d9cc37182f6635a;
  154. tv[98]= 384'hfffffffffffffffffe00000000000000000000000000000000000000000000007866373f24a0b6ed56e0d96fcdafb877;
  155. tv[99]= 384'hffffffffffffffffff00000000000000000000000000000000000000000000001ea448c2aac954f5d812e9d78494446a;
  156. tv[100]= 384'hffffffffffffffffff8000000000000000000000000000000000000000000000acc5599dd8ac02239a0fef4a36dd1668;
  157. tv[101]= 384'hffffffffffffffffffc000000000000000000000000000000000000000000000d8764468bb103828cf7e1473ce895073;
  158. tv[102]= 384'hffffffffffffffffffe0000000000000000000000000000000000000000000001b0d02893683b9f180458e4aa6b73982;
  159. tv[103]= 384'hfffffffffffffffffff00000000000000000000000000000000000000000000096d9b017d302df410a937dcdb8bb6e43;
  160. tv[104]= 384'hfffffffffffffffffff800000000000000000000000000000000000000000000ef1623cc44313cff440b1594a7e21cc6;
  161. tv[105]= 384'hfffffffffffffffffffc00000000000000000000000000000000000000000000284ca2fa35807b8b0ae4d19e11d7dbd7;
  162. tv[106]= 384'hfffffffffffffffffffe00000000000000000000000000000000000000000000f2e976875755f9401d54f36e2a23a594;
  163. tv[107]= 384'hffffffffffffffffffff00000000000000000000000000000000000000000000ec198a18e10e532403b7e20887c8dd80;
  164. tv[108]= 384'hffffffffffffffffffff80000000000000000000000000000000000000000000545d50ebd919e4a6949d96ad47e46a80;
  165. tv[109]= 384'hffffffffffffffffffffc0000000000000000000000000000000000000000000dbdfb527060e0a71009c7bb0c68f1d44;
  166. tv[110]= 384'hffffffffffffffffffffe00000000000000000000000000000000000000000009cfa1322ea33da2173a024f2ff0d896d;
  167. tv[111]= 384'hfffffffffffffffffffff00000000000000000000000000000000000000000008785b1a75b0f3bd958dcd0e29318c521;
  168. tv[112]= 384'hfffffffffffffffffffff800000000000000000000000000000000000000000038f67b9e98e4a97b6df030a9fcdd0104;
  169. tv[113]= 384'hfffffffffffffffffffffc000000000000000000000000000000000000000000192afffb2c880e82b05926d0fc6c448b;
  170. tv[114]= 384'hfffffffffffffffffffffe0000000000000000000000000000000000000000006a7980ce7b105cf530952d74daaf798c;
  171. tv[115]= 384'hffffffffffffffffffffff000000000000000000000000000000000000000000ea3695e1351b9d6858bd958cf513ef6c;
  172. tv[116]= 384'hffffffffffffffffffffff8000000000000000000000000000000000000000006da0490ba0ba0343b935681d2cce5ba1;
  173. tv[117]= 384'hffffffffffffffffffffffc00000000000000000000000000000000000000000f0ea23af08534011c60009ab29ada2f1;
  174. tv[118]= 384'hffffffffffffffffffffffe00000000000000000000000000000000000000000ff13806cf19cc38721554d7c0fcdcd4b;
  175. tv[119]= 384'hfffffffffffffffffffffff000000000000000000000000000000000000000006838af1f4f69bae9d85dd188dcdf0688;
  176. tv[120]= 384'hfffffffffffffffffffffff8000000000000000000000000000000000000000036cf44c92d550bfb1ed28ef583ddf5d7;
  177. tv[121]= 384'hfffffffffffffffffffffffc0000000000000000000000000000000000000000d06e3195b5376f109d5c4ec6c5d62ced;
  178. tv[122]= 384'hfffffffffffffffffffffffe0000000000000000000000000000000000000000c440de014d3d610707279b13242a5c36;
  179. tv[123]= 384'hffffffffffffffffffffffff0000000000000000000000000000000000000000f0c5c6ffa5e0bd3a94c88f6b6f7c16b9;
  180. tv[124]= 384'hffffffffffffffffffffffff80000000000000000000000000000000000000003e40c3901cd7effc22bffc35dee0b4d9;
  181. tv[125]= 384'hffffffffffffffffffffffffc000000000000000000000000000000000000000b63305c72bedfab97382c406d0c49bc6;
  182. tv[126]= 384'hffffffffffffffffffffffffe00000000000000000000000000000000000000036bbaab22a6bd4925a99a2b408d2dbae;
  183. tv[127]= 384'hfffffffffffffffffffffffff000000000000000000000000000000000000000307c5b8fcd0533ab98bc51e27a6ce461;
  184. tv[128]= 384'hfffffffffffffffffffffffff800000000000000000000000000000000000000829c04ff4c07513c0b3ef05c03e337b5;
  185. tv[129]= 384'hfffffffffffffffffffffffffc00000000000000000000000000000000000000f17af0e895dda5eb98efc68066e84c54;
  186. tv[130]= 384'hfffffffffffffffffffffffffe00000000000000000000000000000000000000277167f3812afff1ffacb4a934379fc3;
  187. tv[131]= 384'hffffffffffffffffffffffffff000000000000000000000000000000000000002cb1dc3a9c72972e425ae2ef3eb597cd;
  188. tv[132]= 384'hffffffffffffffffffffffffff8000000000000000000000000000000000000036aeaa3a213e968d4b5b679d3a2c97fe;
  189. tv[133]= 384'hffffffffffffffffffffffffffc00000000000000000000000000000000000009241daca4fdd034a82372db50e1a0f3f;
  190. tv[134]= 384'hffffffffffffffffffffffffffe0000000000000000000000000000000000000c14574d9cd00cf2b5a7f77e53cd57885;
  191. tv[135]= 384'hfffffffffffffffffffffffffff0000000000000000000000000000000000000793de39236570aba83ab9b737cb521c9;
  192. tv[136]= 384'hfffffffffffffffffffffffffff800000000000000000000000000000000000016591c0f27d60e29b85a96c33861a7ef;
  193. tv[137]= 384'hfffffffffffffffffffffffffffc00000000000000000000000000000000000044fb5c4d4f5cb79be5c174a3b1c97348;
  194. tv[138]= 384'hfffffffffffffffffffffffffffe000000000000000000000000000000000000674d2b61633d162be59dde04222f4740;
  195. tv[139]= 384'hffffffffffffffffffffffffffff000000000000000000000000000000000000b4750ff263a65e1f9e924ccfd98f3e37;
  196. tv[140]= 384'hffffffffffffffffffffffffffff80000000000000000000000000000000000062d0662d6eaeddedebae7f7ea3a4f6b6;
  197. tv[141]= 384'hffffffffffffffffffffffffffffc0000000000000000000000000000000000070c46bb30692be657f7eaa93ebad9897;
  198. tv[142]= 384'hffffffffffffffffffffffffffffe00000000000000000000000000000000000323994cfb9da285a5d9642e1759b224a;
  199. tv[143]= 384'hfffffffffffffffffffffffffffff000000000000000000000000000000000001dbf57877b7b17385c85d0b54851e371;
  200. tv[144]= 384'hfffffffffffffffffffffffffffff80000000000000000000000000000000000dfa5c097cdc1532ac071d57b1d28d1bd;
  201. tv[145]= 384'hfffffffffffffffffffffffffffffc00000000000000000000000000000000003a0c53fa37311fc10bd2a9981f513174;
  202. tv[146]= 384'hfffffffffffffffffffffffffffffe0000000000000000000000000000000000ba4f970c0a25c41814bdae2e506be3b4;
  203. tv[147]= 384'hffffffffffffffffffffffffffffff00000000000000000000000000000000002dce3acb727cd13ccd76d425ea56e4f6;
  204. tv[148]= 384'hffffffffffffffffffffffffffffff80000000000000000000000000000000005160474d504b9b3eefb68d35f245f4b3;
  205. tv[149]= 384'hffffffffffffffffffffffffffffffc00000000000000000000000000000000041a8a947766635dec37553d9a6c0cbb7;
  206. tv[150]= 384'hffffffffffffffffffffffffffffffe00000000000000000000000000000000025d6cfe6881f2bf497dd14cd4ddf445b;
  207. tv[151]= 384'hfffffffffffffffffffffffffffffff00000000000000000000000000000000041c78c135ed9e98c096640647265da1e;
  208. tv[152]= 384'hfffffffffffffffffffffffffffffff8000000000000000000000000000000005a4d404d8917e353e92a21072c3b2305;
  209. tv[153]= 384'hfffffffffffffffffffffffffffffffc0000000000000000000000000000000002bc96846b3fdc71643f384cd3cc3eaf;
  210. tv[154]= 384'hfffffffffffffffffffffffffffffffe000000000000000000000000000000009ba4a9143f4e5d4048521c4f8877d88e;
  211. tv[155]= 384'hffffffffffffffffffffffffffffffff00000000000000000000000000000000a1f6258c877d5fcd8964484538bfc92c;
  212. tv[156]= 384'h00000000000000000000000000000000800000000000000000000000000000003ad78e726c1ec02b7ebfe92b23d9ec34;
  213. tv[157]= 384'h00000000000000000000000000000000c0000000000000000000000000000000aae5939c8efdf2f04e60b9fe7117b2c2;
  214. tv[158]= 384'h00000000000000000000000000000000e0000000000000000000000000000000f031d4d74f5dcbf39daaf8ca3af6e527;
  215. tv[159]= 384'h00000000000000000000000000000000f000000000000000000000000000000096d9fd5cc4f07441727df0f33e401a36;
  216. tv[160]= 384'h00000000000000000000000000000000f800000000000000000000000000000030ccdb044646d7e1f3ccea3dca08b8c0;
  217. tv[161]= 384'h00000000000000000000000000000000fc00000000000000000000000000000016ae4ce5042a67ee8e177b7c587ecc82;
  218. tv[162]= 384'h00000000000000000000000000000000fe000000000000000000000000000000b6da0bb11a23855d9c5cb1b4c6412e0a;
  219. tv[163]= 384'h00000000000000000000000000000000ff000000000000000000000000000000db4f1aa530967d6732ce4715eb0ee24b;
  220. tv[164]= 384'h00000000000000000000000000000000ff800000000000000000000000000000a81738252621dd180a34f3455b4baa2f;
  221. tv[165]= 384'h00000000000000000000000000000000ffc0000000000000000000000000000077e2b508db7fd89234caf7939ee5621a;
  222. tv[166]= 384'h00000000000000000000000000000000ffe00000000000000000000000000000b8499c251f8442ee13f0933b688fcd19;
  223. tv[167]= 384'h00000000000000000000000000000000fff00000000000000000000000000000965135f8a81f25c9d630b17502f68e53;
  224. tv[168]= 384'h00000000000000000000000000000000fff800000000000000000000000000008b87145a01ad1c6cede995ea3670454f;
  225. tv[169]= 384'h00000000000000000000000000000000fffc00000000000000000000000000008eae3b10a0c8ca6d1d3b0fa61e56b0b2;
  226. tv[170]= 384'h00000000000000000000000000000000fffe000000000000000000000000000064b4d629810fda6bafdf08f3b0d8d2c5;
  227. tv[171]= 384'h00000000000000000000000000000000ffff0000000000000000000000000000d7e5dbd3324595f8fdc7d7c571da6c2a;
  228. tv[172]= 384'h00000000000000000000000000000000ffff8000000000000000000000000000f3f72375264e167fca9de2c1527d9606;
  229. tv[173]= 384'h00000000000000000000000000000000ffffc0000000000000000000000000008ee79dd4f401ff9b7ea945d86666c13b;
  230. tv[174]= 384'h00000000000000000000000000000000ffffe000000000000000000000000000dd35cea2799940b40db3f819cb94c08b;
  231. tv[175]= 384'h00000000000000000000000000000000fffff0000000000000000000000000006941cb6b3e08c2b7afa581ebdd607b87;
  232. tv[176]= 384'h00000000000000000000000000000000fffff8000000000000000000000000002c20f439f6bb097b29b8bd6d99aad799;
  233. tv[177]= 384'h00000000000000000000000000000000fffffc00000000000000000000000000625d01f058e565f77ae86378bd2c49b3;
  234. tv[178]= 384'h00000000000000000000000000000000fffffe00000000000000000000000000c0b5fd98190ef45fbb4301438d095950;
  235. tv[179]= 384'h00000000000000000000000000000000ffffff0000000000000000000000000013001ff5d99806efd25da34f56be854b;
  236. tv[180]= 384'h00000000000000000000000000000000ffffff800000000000000000000000003b594c60f5c8277a5113677f94208d82;
  237. tv[181]= 384'h00000000000000000000000000000000ffffffc0000000000000000000000000e9c0fc1818e4aa46bd2e39d638f89e05;
  238. tv[182]= 384'h00000000000000000000000000000000ffffffe0000000000000000000000000f8023ee9c3fdc45a019b4e985c7e1a54;
  239. tv[183]= 384'h00000000000000000000000000000000fffffff000000000000000000000000035f40182ab4662f3023baec1ee796b57;
  240. tv[184]= 384'h00000000000000000000000000000000fffffff80000000000000000000000003aebbad7303649b4194a6945c6cc3694;
  241. tv[185]= 384'h00000000000000000000000000000000fffffffc000000000000000000000000a2124bea53ec2834279bed7f7eb0f938;
  242. tv[186]= 384'h00000000000000000000000000000000fffffffe000000000000000000000000b9fb4399fa4facc7309e14ec98360b0a;
  243. tv[187]= 384'h00000000000000000000000000000000ffffffff000000000000000000000000c26277437420c5d634f715aea81a9132;
  244. tv[188]= 384'h00000000000000000000000000000000ffffffff800000000000000000000000171a0e1b2dd424f0e089af2c4c10f32f;
  245. tv[189]= 384'h00000000000000000000000000000000ffffffffc000000000000000000000007cadbe402d1b208fe735edce00aee7ce;
  246. tv[190]= 384'h00000000000000000000000000000000ffffffffe0000000000000000000000043b02ff929a1485af6f5c6d6558baa0f;
  247. tv[191]= 384'h00000000000000000000000000000000fffffffff00000000000000000000000092faacc9bf43508bf8fa8613ca75dea;
  248. tv[192]= 384'h00000000000000000000000000000000fffffffff80000000000000000000000cb2bf8280f3f9742c7ed513fe802629c;
  249. tv[193]= 384'h00000000000000000000000000000000fffffffffc0000000000000000000000215a41ee442fa992a6e323986ded3f68;
  250. tv[194]= 384'h00000000000000000000000000000000fffffffffe0000000000000000000000f21e99cf4f0f77cea836e11a2fe75fb1;
  251. tv[195]= 384'h00000000000000000000000000000000ffffffffff000000000000000000000095e3a0ca9079e646331df8b4e70d2cd6;
  252. tv[196]= 384'h00000000000000000000000000000000ffffffffff80000000000000000000004afe7f120ce7613f74fc12a01a828073;
  253. tv[197]= 384'h00000000000000000000000000000000ffffffffffc000000000000000000000827f000e75e2c8b9d479beed913fe678;
  254. tv[198]= 384'h00000000000000000000000000000000ffffffffffe00000000000000000000035830c8e7aaefe2d30310ef381cbf691;
  255. tv[199]= 384'h00000000000000000000000000000000fffffffffff000000000000000000000191aa0f2c8570144f38657ea4085ebe5;
  256. tv[200]= 384'h00000000000000000000000000000000fffffffffff80000000000000000000085062c2c909f15d9269b6c18ce99c4f0;
  257. tv[201]= 384'h00000000000000000000000000000000fffffffffffc00000000000000000000678034dc9e41b5a560ed239eeab1bc78;
  258. tv[202]= 384'h00000000000000000000000000000000fffffffffffe00000000000000000000c2f93a4ce5ab6d5d56f1b93cf19911c1;
  259. tv[203]= 384'h00000000000000000000000000000000ffffffffffff000000000000000000001c3112bcb0c1dcc749d799743691bf82;
  260. tv[204]= 384'h00000000000000000000000000000000ffffffffffff8000000000000000000000c55bd75c7f9c881989d3ec1911c0d4;
  261. tv[205]= 384'h00000000000000000000000000000000ffffffffffffc0000000000000000000ea2e6b5ef182b7dff3629abd6a12045f;
  262. tv[206]= 384'h00000000000000000000000000000000ffffffffffffe000000000000000000022322327e01780b17397f24087f8cc6f;
  263. tv[207]= 384'h00000000000000000000000000000000fffffffffffff0000000000000000000c9cacb5cd11692c373b2411768149ee7;
  264. tv[208]= 384'h00000000000000000000000000000000fffffffffffff8000000000000000000a18e3dbbca577860dab6b80da3139256;
  265. tv[209]= 384'h00000000000000000000000000000000fffffffffffffc00000000000000000079b61c37bf328ecca8d743265a3d425c;
  266. tv[210]= 384'h00000000000000000000000000000000fffffffffffffe000000000000000000d2d99c6bcc1f06fda8e27e8ae3f1ccc7;
  267. tv[211]= 384'h00000000000000000000000000000000ffffffffffffff0000000000000000001bfd4b91c701fd6b61b7f997829d663b;
  268. tv[212]= 384'h00000000000000000000000000000000ffffffffffffff80000000000000000011005d52f25f16bdc9545a876a63490a;
  269. tv[213]= 384'h00000000000000000000000000000000ffffffffffffffc000000000000000003a4d354f02bb5a5e47d39666867f246a;
  270. tv[214]= 384'h00000000000000000000000000000000ffffffffffffffe00000000000000000d451b8d6e1e1a0ebb155fbbf6e7b7dc3;
  271. tv[215]= 384'h00000000000000000000000000000000fffffffffffffff000000000000000006898d4f42fa7ba6a10ac05e87b9f2080;
  272. tv[216]= 384'h00000000000000000000000000000000fffffffffffffff80000000000000000b611295e739ca7d9b50f8e4c0e754a3f;
  273. tv[217]= 384'h00000000000000000000000000000000fffffffffffffffc00000000000000007d33fc7d8abe3ca1936759f8f5deaf20;
  274. tv[218]= 384'h00000000000000000000000000000000fffffffffffffffe00000000000000003b5e0f566dc96c298f0c12637539b25c;
  275. tv[219]= 384'h00000000000000000000000000000000ffffffffffffffff0000000000000000f807c3e7985fe0f5a50e2cdb25c5109e;
  276. tv[220]= 384'h00000000000000000000000000000000ffffffffffffffff800000000000000041f992a856fb278b389a62f5d274d7e9;
  277. tv[221]= 384'h00000000000000000000000000000000ffffffffffffffffc00000000000000010d3ed7a6fe15ab4d91acbc7d0767ab1;
  278. tv[222]= 384'h00000000000000000000000000000000ffffffffffffffffe00000000000000021feecd45b2e675973ac33bf0c5424fc;
  279. tv[223]= 384'h00000000000000000000000000000000fffffffffffffffff0000000000000001480cb3955ba62d09eea668f7c708817;
  280. tv[224]= 384'h00000000000000000000000000000000fffffffffffffffff80000000000000066404033d6b72b609354d5496e7eb511;
  281. tv[225]= 384'h00000000000000000000000000000000fffffffffffffffffc000000000000001c317a220a7d700da2b1e075b00266e1;
  282. tv[226]= 384'h00000000000000000000000000000000fffffffffffffffffe00000000000000ab3b89542233f1271bf8fd0c0f403545;
  283. tv[227]= 384'h00000000000000000000000000000000ffffffffffffffffff00000000000000d93eae966fac46dca927d6b114fa3f9e;
  284. tv[228]= 384'h00000000000000000000000000000000ffffffffffffffffff800000000000001bdec521316503d9d5ee65df3ea94ddf;
  285. tv[229]= 384'h00000000000000000000000000000000ffffffffffffffffffc0000000000000eef456431dea8b4acf83bdae3717f75f;
  286. tv[230]= 384'h00000000000000000000000000000000ffffffffffffffffffe000000000000006f2519a2fafaa596bfef5cfa15c21b9;
  287. tv[231]= 384'h00000000000000000000000000000000fffffffffffffffffff0000000000000251a7eac7e2fe809e4aa8d0d7012531a;
  288. tv[232]= 384'h00000000000000000000000000000000fffffffffffffffffff80000000000003bffc16e4c49b268a20f8d96a60b4058;
  289. tv[233]= 384'h00000000000000000000000000000000fffffffffffffffffffc000000000000e886f9281999c5bb3b3e8862e2f7c988;
  290. tv[234]= 384'h00000000000000000000000000000000fffffffffffffffffffe000000000000563bf90d61beef39f48dd625fcef1361;
  291. tv[235]= 384'h00000000000000000000000000000000ffffffffffffffffffff0000000000004d37c850644563c69fd0acd9a049325b;
  292. tv[236]= 384'h00000000000000000000000000000000ffffffffffffffffffff800000000000b87c921b91829ef3b13ca541ee1130a6;
  293. tv[237]= 384'h00000000000000000000000000000000ffffffffffffffffffffc000000000002e65eb6b6ea383e109accce8326b0393;
  294. tv[238]= 384'h00000000000000000000000000000000ffffffffffffffffffffe000000000009ca547f7439edc3e255c0f4d49aa8990;
  295. tv[239]= 384'h00000000000000000000000000000000fffffffffffffffffffff00000000000a5e652614c9300f37816b1f9fd0c87f9;
  296. tv[240]= 384'h00000000000000000000000000000000fffffffffffffffffffff8000000000014954f0b4697776f44494fe458d814ed;
  297. tv[241]= 384'h00000000000000000000000000000000fffffffffffffffffffffc00000000007c8d9ab6c2761723fe42f8bb506cbcf7;
  298. tv[242]= 384'h00000000000000000000000000000000fffffffffffffffffffffe0000000000db7e1932679fdd99742aab04aa0d5a80;
  299. tv[243]= 384'h00000000000000000000000000000000ffffffffffffffffffffff00000000004c6a1c83e568cd10f27c2d73ded19c28;
  300. tv[244]= 384'h00000000000000000000000000000000ffffffffffffffffffffff800000000090ecbe6177e674c98de412413f7ac915;
  301. tv[245]= 384'h00000000000000000000000000000000ffffffffffffffffffffffc00000000090684a2ac55fe1ec2b8ebd5622520b73;
  302. tv[246]= 384'h00000000000000000000000000000000ffffffffffffffffffffffe0000000007472f9a7988607ca79707795991035e6;
  303. tv[247]= 384'h00000000000000000000000000000000fffffffffffffffffffffff00000000056aff089878bf3352f8df172a3ae47d8;
  304. tv[248]= 384'h00000000000000000000000000000000fffffffffffffffffffffff80000000065c0526cbe40161b8019a2a3171abd23;
  305. tv[249]= 384'h00000000000000000000000000000000fffffffffffffffffffffffc00000000377be0be33b4e3e310b4aabda173f84f;
  306. tv[250]= 384'h00000000000000000000000000000000fffffffffffffffffffffffe000000009402e9aa6f69de6504da8d20c4fcaa2f;
  307. tv[251]= 384'h00000000000000000000000000000000ffffffffffffffffffffffff00000000123c1f4af313ad8c2ce648b2e71fb6e1;
  308. tv[252]= 384'h00000000000000000000000000000000ffffffffffffffffffffffff800000001ffc626d30203dcdb0019fb80f726cf4;
  309. tv[253]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffc000000076da1fbe3a50728c50fd2e621b5ad885;
  310. tv[254]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffe0000000082eb8be35f442fb52668e16a591d1d6;
  311. tv[255]= 384'h00000000000000000000000000000000fffffffffffffffffffffffff0000000e656f9ecf5fe27ec3e4a73d00c282fb3;
  312. tv[256]= 384'h00000000000000000000000000000000fffffffffffffffffffffffff80000002ca8209d63274cd9a29bb74bcd77683a;
  313. tv[257]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffc00000079bf5dce14bb7dd73a8e3611de7ce026;
  314. tv[258]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffe0000003c849939a5d29399f344c4a0eca8a576;
  315. tv[259]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffff000000ed3c0a94d59bece98835da7aa4f07ca2;
  316. tv[260]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffff80000063919ed4ce10196438b6ad09d99cd795;
  317. tv[261]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffc000007678f3a833f19fea95f3c6029e2bc610;
  318. tv[262]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffe000003aa426831067d36b92be7c5f81c13c56;
  319. tv[263]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffff000009272e2d2cdd11050998c845077a30ea0;
  320. tv[264]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffff80000088c4b53f5ec0ff814c19adae7f6246c;
  321. tv[265]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffc00004010a5e401fdf0a0354ddbcc0d012b17;
  322. tv[266]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffe0000a87a385736c0a6189bd6589bd8445a93;
  323. tv[267]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffff0000545f2b83d9616dccf60fa9830e9cd287;
  324. tv[268]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffff80004b706f7f92406352394037a6d4f4688d;
  325. tv[269]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffc000b7972b3941c44b90afa7b264bfba7387;
  326. tv[270]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffe0006f45732cf10881546f0fd23896d2bb60;
  327. tv[271]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffff0002e3579ca15af27f64b3c955a5bfc30ba;
  328. tv[272]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffff80034a2c5a91ae2aec99b7d1b5fa6780447;
  329. tv[273]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffc00a4d6616bd04f87335b0e53351227a9ee;
  330. tv[274]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffe007f692b03945867d16179a8cefc83ea3f;
  331. tv[275]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffff003bd141ee84a0e6414a26e7a4f281f8a2;
  332. tv[276]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffff80d1788f572d98b2b16ec5d5f3922b99bc;
  333. tv[277]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffffc00833ff6f61d98a57b288e8c3586b85a6;
  334. tv[278]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffffe08568261797de176bf0b43becc6285afb;
  335. tv[279]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffff0f9b0fda0c4a898f5b9e6f661c4ce4d07;
  336. tv[280]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffff88ade895913685c67c5269f8aae42983e;
  337. tv[281]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffffc39bde67d5c8ed8a8b1c37eb8fa9f5ac0;
  338. tv[282]= 384'h00000000000000000000000000000000fffffffffffffffffffffffffffffffe5c005e72c1418c44f569f2ea33ba54f3;
  339. tv[283]= 384'h00000000000000000000000000000000ffffffffffffffffffffffffffffffff3f5b8cc9ea855a0afa7347d23e8d664e;
  340. for(n=0;n<284;n=n+1)
  341.    begin
  342.
  343.     tmp = tv[n];
  344.     key     = tmp[383:256];
  345.     text_in = tmp[255:128];
  346.          plain   = tmp[255:128];
  347.     ciph    = tmp[127:0];
  348.         @(posedge clk);
  349.         #1;
  350.         kld = 1;
  351.         @(posedge clk);
  352.         #1;
  353.         kld = 0;
  354.         @(posedge clk);
  355.         while(!done)        @(posedge clk);
  356.         if(text_out != ciph | (|text_out)==1'bx)
  357.            begin
  358.                 $display("ERROR: (a) Vector %0d mismatch. Expected %x, Got %x",
  359.                         n, ciph, text_out);
  360.                 error_cnt = error_cnt + 1;
  361.            end
  362.         while(!done2)        @(posedge clk);
  363.         if(text_out2 != plain | (|text_out2)==1'bx)
  364.            begin
  365.                 $display("ERROR: (b) Vector %0d mismatch. Expected %x, Got %x",
  366.                         n, plain, text_out2);
  367.                 error_cnt = error_cnt + 1;
  368.            end
  369.         @(posedge clk);
  370.         #1;
  371.    end
  372.         $display("");
  373.         $display("");
  374.         $display("Test Done. Found %0d Errors.", error_cnt);
  375.         $display("");
  376.         $display("");
  377.         repeat(10)        @(posedge clk);
  378.         $finish;
  379. end
  380. always #2 clk = ~clk;
  381. ARS_aes u0 (
  382.     .clk(clk),
  383.         .reset(rst),
  384.         .load_i(kld),
  385.         .decrypt_i(1'b0),
  386.         .data_i(text_in),
  387.         .key_i(key),
  388.         .ready_o(done),
  389.         .data_o(text_out)
  390.         );
  391. ARS_aes u1 (
  392.     .clk(clk),
  393.         .reset(rst),
  394.         .load_i(done),
  395.         .decrypt_i(1'b1),
  396.         .data_i(text_out),
  397.         .key_i(key),
  398.         .ready_o(done2),
  399.         .data_o(text_out2)
  400.         );
  401. endmodule
全部資料51hei下載地址:
AES_128.7z (4.88 MB, 下載次數: 20)
作者: beck74    時間: 2020-6-23 08:56
謝謝分享。。。
