標題: error C141: syntax error near 'ADDR3' Keil錯誤求解 [打印本頁]
作者: wqd0829    時間: 2019-9-12 08:52
點亮一小燈 然后從左到右,
#include <reg52.h>
sbit LED   = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
   unsigned int i = 0;
   unsigned char cnt = 0;
   unsigned char sec = 0;
   unsigned char dir = 0;
   unsigned char shift = 0x01
   ADDR3 = 1;
   ENLED = 0;
   ADDR2 = 1;
   ADDR1 = 1;
   ADDR0 = 0;
   TMOD = 0x01;
   TH0  = 0xB8;
   TL0  = 0x00;
   TR0  = 1;
   while (1)
              if (TF0 == 1)
                  TF0 = 0;
                  TH0 = 0xB8;
                  TL0 = 0x00;
                  cnt++;
                  if(cnt >=100)
                     cnt = 0;
                     LED = ~LED;
                               P0 = ~shift;
                               for(i=0; i<30000; i++);
                                 if (dir == 0)
                                  shift = shift << 1;
                                   if ( shift == 0x80)
                                dir = 1;
                                 shift = shift >> 1;
                                  if (shift == 0x01)
                                       dir = 0;
作者: wqd0829    時間: 2019-9-12 08:54
從右到左    亮滅一直顯示SXLSD.C(20): error C141: syntax error near 'ADDR3'  謝謝大佬們
作者: 小白成長記    時間: 2019-9-12 10:37
unsigned char shift = 0x01后面缺少分號;
作者: 沒有你    時間: 2019-9-12 11:14
unsigned char shift = 0x01  這條語句少了分號
作者: 小米不加糖    時間: 2019-9-12 15:27
注意標點符號,基本語法的錯誤編譯的時候是可以檢查出來的。
