標題: 為什么單片機交通燈不發生變化?而且LCD1602顯示的都是亂碼呢? [打印本頁]
作者: Immortal盲點    時間: 2019-8-26 16:18
下面是程序部分
#include "traffic.h"
#include "lcdA.h"
#include "lcdB.h"
bit FLAG=0;
void menu()
int i;
LCD1602_Init_A();
LCD1602_Init_B();
     char TIME=20;
   if(TIME>15)
                  N_S_GREEN=ON;N_S_RED=OFF;N_S_YELLOW=OFF;W_E_GREEN=OFF;W_E_RED=ON;W_E_YELLOW=OFF;
                 LCD_Str_A("RUN!  TIME:    S",1,1);
                 LCD_Str_B("STOP! TIME:    S",1,1);
                 LCD_Str_A("COUNT:",2,1);
                 LCD_Str_B("COUNT:",2,1);
              else if(TIME>10)
                  N_S_YELLOW=ON;N_S_RED=OFF;N_S_GREEN=OFF;W_E_GREEN=OFF;W_E_RED=ON;W_E_YELLOW=OFF;
                  LCD_Str_A("STOP! TIME:    S",1,1);
                     else if(TIME>5)
                  N_S_GREEN=OFF;N_S_RED=ON;N_S_YELLOW=OFF;W_E_GREEN=ON;W_E_RED=OFF;W_E_YELLOW=OFF;
                 LCD_Str_B("RUN!  TIME:    S",1,1);
               else if(TIME>0)
N_S_YELLOW=OFF;N_S_RED=ON;N_S_GREEN=OFF;W_E_GREEN=OFF;W_E_RED=OFF;W_E_YELLOW=ON;
               else if(TIME<=0)
               TIME=20;
                 if(TIME>10)
                             TIMEE=TIME-10;
                             TIMEE=TIME;
           for(i=100;i>0;i--)
       LCD_Write_3_Float_A(TIMEE,1,12);
       LCD_Write_3_Float_B(TIMEE,1,12);
       LCD_Write_3_Float_A(COUNTA,2,7);
       LCD_Write_3_Float_B(COUNTB,2,7);
}void Timer0Init()
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
ET0=1;
TR0=1;
EA=1;
void timer0( ) interrupt 1
int i;
static char COUNT_1S=0;
COUNT_1S++;
if(COUNT_1S==20)
  COUNT_1S=0;
  TIME--;
   if(TIME=0)
    TIME=TIMERED;
void ExtiInit()
EX0=1;
EX1=1;
IT0=1;
IT1=1;
EA=1;
void Exti0() interrupt 0
COUNTA++;
if(COUNTA==100)
  COUNTA=0;
void Exti1() interrupt 2
COUNTB++;
if(COUNTB==100)
  COUNTB=0;
作者: csmyldl    時間: 2019-8-27 00:02
把程序中這一句  void menu() 改為void main()試試
作者: Immortal盲點    時間: 2019-8-27 09:23
csmyldl 發表于 2019-8-27 00:02
但是這個是之后主程序里面要用到的
