標題: AT89C2051單片機串口發送數據控制小燈變化 [打印本頁]
作者: jackiesky    時間: 2019-8-10 20:18
此帖子適用于新手,本人也是新手,用于記錄總結經驗用,如果存在問題,請高手提出寶貴意見!
主要是用于兩個單片機之間通過串口傳遞數據使用,只是一個小測試,先上原理圖。
COMA單片機源代碼如下:
//發送端單片機代碼如下:
#include <reg51.h>
unsigned char code tab0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code tab1[]={0xFF,0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01};
unsigned char code tab2[]={0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF};
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
void Send(unsigned char c)
    SBUF = c;
    while(!TI);
    TI = 0;
void delay10ms(void)   //誤差 0us
    unsigned char a,b,c;
    for(c=7;c>0;c--)
        for(b=74;b>0;b--)
            for(a=95;a>0;a--);
void delay(void)
    for(c=46;c>0;c--)
        for(b=152;b>0;b--)
            for(a=70;a>0;a--);
void main(void)
    unsigned char i;
    InitUART();
                if(!k1)
                    for(i=0;i<sizeof(tab1);i++)
                        Send(tab1[ i]);[ i]
                        delay10ms();
                delay();
                else if(!k2)
                    for(i=0;i<sizeof(tab2);i++)
                        Send(tab2[ i]);[ i]
                        delay10ms();
                delay();
                else if(!k3)
                    for(i=0;i<sizeof(tab0);i++)
                        Send(tab0[ i]);[ i]
                        delay10ms();
                delay();
void UARTInterrupt(void) interrupt 4
    if(RI)
        RI = 0;
        //add your code here!
COMB單片機源代碼如下:
//接收端單片機代碼如下:
#include <reg51.h>
unsigned char receive(void)
        unsigned char dat;
        while(RI)
                RI=0;
                dat=SBUF;
                return dat;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xFD;
    TL1 = 0xFD;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
    REN=1;
void main(void)
    InitUART();
                P1=receive();
測試圖:
作者: rsx9583    時間: 2019-8-11 09:37
對于學習串口通信的還是很有意義的
