標(biāo)題: 基于51單片機(jī)蜂鳴器的兩只老虎音樂代碼 [打印本頁]
作者: 默默米    時(shí)間: 2019-8-10 01:01
#include <reg52.h>
sbit BUZZ = P1^6;  //蜂鳴器控制引腳
unsigned int code NoteFrequ[] = {  //中音1-7和高音1-7對(duì)應(yīng)頻率列表
    523,  587,  659,  698,  784,  880,  988,  //中音1-7
    1047, 1175, 1319, 1397, 1568, 1760, 1976  //高音1-7
unsigned int code NoteReload[] = { //中音1-7和高音1-7對(duì)應(yīng)的定時(shí)器重載值
    65536 - (11059200/12) / (523*2),  //中音1
    65536 - (11059200/12) / (587*2),  //2
    65536 - (11059200/12) / (659*2),  //3
    65536 - (11059200/12) / (698*2),  //4
    65536 - (11059200/12) / (784*2),  //5
    65536 - (11059200/12) / (880*2),  //6
    65536 - (11059200/12) / (988*2),  //7
    65536 - (11059200/12) / (1047*2), //高音1
    65536 - (11059200/12) / (1175*2), //2
    65536 - (11059200/12) / (1319*2), //3
    65536 - (11059200/12) / (1397*2), //4
    65536 - (11059200/12) / (1568*2), //5
    65536 - (11059200/12) / (1760*2), //6
    65536 - (11059200/12) / (1976*2), //7
bit enable = 1;   //蜂鳴器發(fā)聲使能標(biāo)志
bit tmrflag = 0;  //定時(shí)器中斷完成標(biāo)志
unsigned char T0RH = 0xFF;  //T0重載值的高字節(jié)
unsigned char T0RL = 0x00;  //T0重載值的低字節(jié)
void PlayTwoTiger();
    unsigned int i;
    EA = 1;       //使能全局中斷
    TMOD = 0x01;  //配置T0工作在模式1
    TH0 = T0RH;
    TL0 = T0RL;
    ET0 = 1;      //使能T0中斷
    TR0 = 1;      //啟動(dòng)T0
    while (1)
        PlayTwoTiger();  //播放樂曲--兩支老虎
        for (i=0; i<40000; i++);  //停止一段時(shí)間
/* 兩只老虎樂曲播放函數(shù) */
void PlayTwoTiger()
    unsigned char beat;   //當(dāng)前節(jié)拍索引
    unsigned char note;   //當(dāng)前節(jié)拍對(duì)應(yīng)的音符
    unsigned int time = 0;      //當(dāng)前節(jié)拍計(jì)時(shí)
    unsigned int beatTime = 0;  //當(dāng)前節(jié)拍總時(shí)間
    unsigned int soundTime = 0; //當(dāng)前節(jié)拍需發(fā)聲時(shí)間
    //兩只老虎音符表
    unsigned char code TwoTigerNote[] = {
        1,   2,   3, 1,    1,   2,   3, 1,   3, 4, 5,   3, 4, 5,
        5,6, 5,4, 3, 1,    5,6, 5,4, 3, 1,   1, 5, 1,   1, 5, 1,
    //兩只老虎節(jié)拍表,4表示一拍,1就是1/4拍,8就是2拍
    unsigned char code TwoTigerBeat[] = {
        4,   4,   4, 4,    4,   4,   4, 4,   4, 4, 8,   4, 4, 8,
        3,1, 3,1, 4, 4,    3,1, 3,1, 4, 4,   4, 4, 8,   4, 4, 8,
    for (beat=0; beat<sizeof(TwoTigerNote); )  //用節(jié)拍索引作為循環(huán)變量
        while (!tmrflag);  //每次定時(shí)器中斷完成后,檢測(cè)并處理節(jié)拍
        tmrflag = 0;
        if (time == 0)  //當(dāng)前節(jié)拍播完則啟動(dòng)一個(gè)新節(jié)拍
            note = TwoTigerNote[beat] - 1;
            T0RH = NoteReload[note] >> 8;
            T0RL = NoteReload[note];
            //計(jì)算節(jié)拍總時(shí)間,右移2位相當(dāng)于除4,移位代替除法可以加快執(zhí)行速度
            beatTime = (TwoTigerBeat[beat] * NoteFrequ[note]) >> 2;
            //計(jì)算發(fā)聲時(shí)間,為總時(shí)間的0.75,移位原理同上
            soundTime = beatTime - (beatTime >> 2);
            enable = 1;  //指示蜂鳴器開始發(fā)聲
            time++;
        else  //當(dāng)前節(jié)拍未播完則處理當(dāng)前節(jié)拍
            if (time >= beatTime)  //當(dāng)前持續(xù)時(shí)間到達(dá)節(jié)拍總時(shí)間時(shí)歸零,
            {                      //并遞增節(jié)拍索引,以準(zhǔn)備啟動(dòng)新節(jié)拍
                time = 0;
                beat++;
            else  //當(dāng)前持續(xù)時(shí)間未達(dá)到總時(shí)間時(shí),
                time++;   //累加時(shí)間計(jì)數(shù)
                if (time == soundTime)  //到達(dá)發(fā)聲時(shí)間后,指示關(guān)閉蜂鳴器,
                {                       //插入0.25*總時(shí)間的靜音間隔,
                    enable = 0;         //用以區(qū)分連續(xù)的兩個(gè)節(jié)拍
/* T0中斷服務(wù)函數(shù),用于控制蜂鳴器發(fā)聲 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;   //重新加載重載值
    TL0 = T0RL;
    tmrflag = 1;
    if (enable)   //使能時(shí)反轉(zhuǎn)蜂鳴器控制電平
        BUZZ = ~BUZZ;
    else          //未使能時(shí)關(guān)閉蜂鳴器
        BUZZ = 1;
作者: tcoxb    時(shí)間: 2021-3-1 12:38
可以的, 寫得不錯(cuò)
作者: hepen2002    時(shí)間: 2023-3-4 15:43
請(qǐng)問為什么是除以4.上面兩個(gè)
作者: Ibalck    時(shí)間: 2023-8-2 14:12
怎么讓他停下來
