我這個(gè)msp430f169測(cè)頻率一直顯示65535Hz,怎么改,大佬幫忙看一下
[打印本頁(yè)]
202538322
時(shí)間:
2019-8-5 16:54
msp430f169 測(cè)量頻率
#include <msp430x16x.h>
void delay(void);
void InitSys();
//void ClearLCD(void);
extern const unsigned char shuzi_table[];
#define LCD_DataIn P5DIR=0x00 //數(shù)據(jù)口方向設(shè)置為輸入
#define LCD_DataOut P5DIR=0xff //數(shù)據(jù)口方向設(shè)置為輸出
#define LCD2MCU_Data P5IN
#define MCU2LCD_Data P5OUT
#define LCD_CMDOut P4DIR|=0x0F //P3口的低三位設(shè)置為輸出
#define LCD_RS_H P4OUT|=BIT0 //P3.0
#define LCD_RS_L P4OUT&=~BIT0 //P3.0
#define LCD_RW_H P4OUT|=BIT1 //P3.1
#define LCD_RW_L P4OUT&=~BIT1 //P3.1
#define LCD_EN_H P4OUT|=BIT2 //P3.2
#define LCD_EN_L P4OUT&=~BIT2 //P3.2
#define LCD_PSB_P P4OUT|=BIT3 //3.3
#define LCD_PSB_S P4OUT&=~BIT3 //3.3
void Delay_1ms(void);
void Delay(unsigned int n);
void Write_Cmd(unsigned char cod);
void Write_Data(unsigned char dat);
void Ini_Lcd(void);
void Disp_HZ(unsigned char addr,const unsigned char * pt,unsigned char num);
void Disp_ND(unsigned char addr,unsigned int thickness);
void Draw_TX(unsigned char Yaddr,unsigned char Xaddr,const unsigned char * dp) ;
void Draw_PM(const unsigned char *ptr);
//void ADC12(void);
void Clock_Init(void);
uint start,end;
uint width; //==用于存放脈寬==
uint period; //==用于存放周期==
uint frequency; //==用于存放頻率==
uint fy[7]; //==用于存放頻率顯示數(shù)據(jù)==
uint pd[7]; //==用于存放周期顯示數(shù)據(jù)==
uint wh[6]; //==用于存放脈寬顯示數(shù)據(jù)==
const unsigned char zhouqi[]={"周期為:(us) "};
const unsigned char us[]={"us "};
const unsigned char pinlv[]={"頻率為:(Hz) "};
const unsigned char hz[]={"HZ "};
void process(void);
/***************************主函數(shù)*************************/
void main( void )
WDTCTL = WDTPW + WDTHOLD; //==關(guān)狗==
InitSys(); //==初始化時(shí)鐘,SMCLK,MCLK均為8M==
P1DIR&=~BIT2;
P1SEL = BIT2; //==設(shè)置P1.2端口為功能模塊使用,即:做捕獲源==
TACTL = TASSEL_2+ID_3+TACLR+TAIE+MC_1;//==定時(shí)器A時(shí)鐘信號(hào)選擇SMCLK,8分頻,同時(shí)設(shè)置定時(shí)器A計(jì)數(shù)模式為連續(xù)增計(jì)模式==
CCTL1 = CM_1+SCS+CAP+CCIE; //==輸入上升沿捕獲,CCI0A為捕獲信號(hào)源==
_EINT(); //==開(kāi)全局中斷允許==
//_BIS_SR(LPM0_bits+GIE);
Ini_Lcd(); //==初始化液晶==
//Clear_GDRAM(); //==清屏==
Disp_HZ(0x80,zhouqi,6);
Disp_HZ(0x88,pinlv,6);
process();
Write_Cmd(0x90);//==寫地址==
Write_Data(pd[6]+0x30);
Write_Data(pd[5]+0x30);
Write_Data(pd[4]+0x30);
Write_Data(pd[3]+0x30);
Write_Data(pd[2]+0x30);
Write_Data(pd[1]+0x30);
Write_Data(pd[0]+0x30);
Write_Cmd(0x98);//==寫地址==
Write_Data(fy[6]+0x30);
Write_Data(fy[5]+0x30);
Write_Data(fy[4]+0x30);
Write_Data(fy[3]+0x30);
Write_Data(fy[2]+0x30);
Write_Data(fy[1]+0x30);
Write_Data(fy[0]+0x30);
delay();
void InitSys()
unsigned int i;
//--- 使用XT2振蕩器 ---
BCSCTL1&=~XT2OFF; //==打開(kāi)XT2振蕩器==
do
IFG1 &= ~OFIFG; //==清除振蕩器失效標(biāo)志==
for (i = 0xFF; i > 0; i--); //==延時(shí),等待XT2起振==
while ((IFG1 & OFIFG) != 0); //==判斷XT2是否起振==
BCSCTL2 =SELM_2+SELS; //==選擇MCLK、SMCLK為XT2,8M==
//ADC12CTL0 |=ENC+ADC12SC;//使能轉(zhuǎn)換;開(kāi)始轉(zhuǎn)換
void process(void)
while(end<start);
//while(end<start)的話就讓其一直等待下去,直到end>start
//width =10000/(end-start); //實(shí)際脈沖寬度的計(jì)算
period =2*width;
frequency=1000000/period;
pd[6]=period/1000000;
pd[5]=(period-1000000*pd[6])/100000;
pd[4]=(period-1000000*pd[6]-100000*pd[5])/10000;
pd[3]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4])/1000;
pd[2]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3])/100;
pd[1]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3]-100*pd[2])/10;
pd[0]=period%10;
fy[6]=frequency/1000000;
fy[5]=(frequency-1000000*fy[6])/100000;
fy[4]=(frequency-1000000*fy[6]-100000*fy[5])/10000;
fy[3]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4])/1000;
fy[2]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3])/100;
fy[1]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3]-100*fy[2])/10;
fy[0]=frequency%10;
#pragma vector=TIMERA1_VECTOR //==定時(shí)器A中斷處理==
__interrupt void timer_A1(void)
uint temp;
switch(TAIV) //==向量查詢==
{ case 2: //==捕獲中斷==
if(CCTL1&CM0) //==捕獲到上升沿==
CCTL1=(CCTL1&(~CM0))|CM1; //==更變?cè)O(shè)置為下降沿觸發(fā)==
temp=TAR; //==記錄初始時(shí)間==
period=temp-start;
start=temp;
else if (CCTL1&CM1) //==捕獲到下降沿==
CCTL1=(CCTL1&(~CM1))|CM0; //==更變?cè)O(shè)置為上升沿觸發(fā)==
end=TAR; //==用start,end,overflow計(jì)算脈沖寬度==
width =end-start;
break;
default:break;
函數(shù)名稱:Delay_1ms
功 能:延時(shí)約1ms的時(shí)間
參 數(shù):無(wú)
返回值 :無(wú)
uchar i;
for(i = 150;i > 0;i--) _NOP();
函數(shù)名稱:Delay_Nms
功 能:延時(shí)N個(gè)1ms的時(shí)間
參 數(shù):n--延時(shí)長(zhǎng)度
返回值 :無(wú)
void Delay_Nms(uint n)
uint i;
for(i = n;i > 0;i--) Delay_1ms();
函數(shù)名稱:Write_Cmd
功 能:向液晶中寫控制命令
參 數(shù):cmd--控制命令
返回值 :無(wú)
void Write_Cmd(uchar cmd)
uchar lcdtemp = 0;
LCD_RS_L;
LCD_RW_H;
LCD_DataIn;
do //判忙
LCD_EN_H;
_NOP();
lcdtemp = LCD2MCU_Data;
LCD_EN_L;
while(lcdtemp & 0x80);
LCD_DataOut;
LCD_RW_L;
MCU2LCD_Data = cmd;
LCD_EN_H;
_NOP();
LCD_EN_L;
函數(shù)名稱:Write_Data
功 能:向液晶中寫顯示數(shù)據(jù)
參 數(shù):dat--顯示數(shù)據(jù)
返回值 :無(wú)
void Write_Data(uchar dat)
uchar lcdtemp = 0;
LCD_RS_L;
LCD_RW_H;
LCD_DataIn;
do //判忙
LCD_EN_H;
_NOP();
LCD_EN_L;
LCD_DataOut;
LCD_RS_H;
LCD_RW_L;
MCU2LCD_Data = dat;
LCD_EN_H;
_NOP();
LCD_EN_L;
函數(shù)名稱:Ini_Lcd
功 能:初始化液晶模塊
參 數(shù):無(wú)
返回值 :無(wú)
void Ini_Lcd(void)
LCD_CMDOut; //液晶控制端口設(shè)置為輸出
Delay_Nms(500);
Write_Cmd(0x30); //基本指令集
Delay_1ms();
Write_Cmd(0x02); // 地址歸位
Delay_1ms();
Write_Cmd(0x0c); //整體顯示打開(kāi),游標(biāo)關(guān)閉
Delay_1ms();
Write_Cmd(0x01); //清除顯示
Delay_1ms();
Write_Cmd(0x06); //游標(biāo)右移
Delay_1ms();
Write_Cmd(0x80); //設(shè)定顯示的起始地址
函數(shù)名稱:Disp_HZ
功 能:控制液晶顯示漢字
參 數(shù):addr--顯示位置的首地址
pt--指向顯示數(shù)據(jù)的指針
num--顯示字符個(gè)數(shù)
返回值 :無(wú)
void Disp_HZ(uchar addr,const uchar * pt,uchar num)
uchar i;
Write_Cmd(addr);
for(i = 0;i < (num*2);i++)
Write_Data(*(pt++));
uchar i;
BCSCTL1&=~XT2OFF; //打開(kāi)XT振蕩器
BCSCTL2|=SELM1+SELS; //MCLK為8MHZ,SMCLK為8MHZ
do{
IFG1&=~OFIFG; //清除震蕩標(biāo)志
for(i=0;i<100;i++)
_NOP(); //延時(shí)等待
while((IFG1&OFIFG)!=0); //如果標(biāo)志為1,則繼續(xù)循環(huán)等待
IFG1&=~OFIFG;
void delay(void)
unsigned int i,j;
for(i=0;i<100;i--)
for(j=0;j<100;j--);
ssz666
時(shí)間:
2019-8-6 17:00
因?yàn)槟愣xfrequency時(shí)用的是uint,而你的uint是用unsigned int宏定義的,他的取值范圍為0—65536,所以你最大的顯示數(shù)為65536,你可以把frequency用u32定義就可以了
