標(biāo)題: 單片機(jī)8*8點(diǎn)陣實(shí)現(xiàn)24字母顯示程序和代碼表計(jì)算器下載 [打印本頁]
作者: sudoapt    時(shí)間: 2019-7-27 19:43
首先來說一說74hc595這個(gè)芯片怎么打表如圖所示,詳情見Excel表部分代碼 (注:由于時(shí)間在這里只例舉一部分)
#include<reg52.h>
#include<intrins.h>
typedef unsigned char u8;
sbit ser = P3^4;// ser rclk srclk 是74hc595芯片定義的參數(shù)
sbit rclk = P3^5;
sbit srclk = P3^6;
//由于需要自己算點(diǎn)陣的碼表  這里就列舉一部分
u8 ledduan[7][8] = {0x00,0x3e,0x50,0x90,0x50,0x3e,0x00,0x00,//A
                                                  0x00,0xfe,0x92,0x92,0x92,0x7c,0x00,0x00,//B
                                                  0x00,0x3c,0x42,0x81,0x81,0x81,0x00,0x00,//C
                                                  0x00,0xff,0x81,0x81,0x42,0x3c,0x00,0x00,//D
                                                  0x00,0xff,0x89,0x89,0x89,0x89,0x00,0x00,//E
                                                  0x00,0xff,0x88,0x88,0x88,0x88,0x00,0x00,//F
                                                  0x00,0x7e,0x82,0x8a,0x8a,0x8f,0x00,0x00,};//G
u8 ledwei[] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
//void delay1ms(void)   //誤差 0us
//    unsigned char a,b,c;
//    for(c=1;c>0;c--)
//        for(b=142;b>0;b--)
//            for(a=2;a>0;a--);
void Hc595(u8 dat){
        u8 i;
        rclk = 0;
        srclk = 0;
        for(i = 0;i <8;i++){
                ser = dat>>7;
                dat <<= 1;
                srclk = 1;
                _nop_();
                _nop_();
                srclk = 0;
        rclk = 1;
        _nop_();
        _nop_();
        rclk = 0;
點(diǎn)陣.rar
126.52 KB, 下載次數(shù): 16, 下載積分: 黑幣 -5
