標(biāo)題: 單片機(jī)兩路延時(shí)時(shí)間 存儲(chǔ)的程序問(wèn)題 [打印本頁(yè)]
作者: yong761228    時(shí)間: 2019-7-17 12:11
各位師傅您們好,我用STC15W404AS和TM1650編程兩路延時(shí)程序,不能存儲(chǔ)兩個(gè)時(shí)間,哪位師傅幫我看看,怎樣修改,非常感謝。
if(key_timeto)//如果按鍵掃描時(shí)間到,此變量在定時(shí)器中會(huì)被每隔60ms置1一次
                                 key_L = key;
                                     key_timeto = 0; //清0
                                     key = Scan_Key();//讀按鍵
                                     //第一個(gè)按鍵按下
                                     if(key == 0x44)   //此鍵值和數(shù)據(jù)手冊(cè)上對(duì)應(yīng)
                                      if(key_ok==0) //按鍵按下
                                         key_ok = 1;
                                        mode = (mode+1)%2;//切換模式
                                    //第二個(gè)按鍵按下
                                    else if(key == 0x4c)
                                     {        if(mode == 0)//模式0為設(shè)置模式
                                         if(time2<999)
                                        time2 = (time2+1);//按此鍵加時(shí)間
                                      if(mode == 1)//模式1為設(shè)置模式
                                         if(time1<999)
                                        time1 = (time1+1);//按此鍵加時(shí)間
                                     timea=time1;
                                        IapEraseSector(0);//保持改變后的時(shí)間值
                                    IapProgramByte(0,(timea>>8));
                                    IapProgramByte(1,(uchar)timea);
                                     timeb=time2;
                                        IapEraseSector(1);//保持改變后的時(shí)間值
                                    IapProgramByte(1,(timea>>8));
                                    IapProgramByte(2,(uchar)timea);
                                    //第三個(gè)按鍵按下
                                   else if(key == 0x54)
                                         if(time2>0)
                                           time2--;//減時(shí)間
                                    if(mode == 1)//模式1
                                     if(time1>0)
                                       time1--;//減時(shí)間
                                     timea=time1;
                                        IapEraseSector(0); //保存時(shí)間
                                            timeb=time2;
                                           IapEraseSector(1); //保存時(shí)間
                                    IapProgramByte(1,(timeb>>8));
                                    IapProgramByte(2,(uchar)timeb);
                                    key_ok = 0;
        if(update_dis) //30ms到,更新顯示
                        update_dis = 0;
                        TM1650_Set(0x48,0x11);
                        if(stat ==0)
                            if(mode == 1)//如果是模式1
                                                TM1650_Set(0x68,CODE[timea/100]);        //顯示
                                                TM1650_Set(0x6A,CODE[timea/10%10]);
                                                TM1650_Set(0x6C,CODE[timea%10]);
                           else if(mode == 0)
                                           TM1650_Set(0x68,CODE[timeb/100]);
                                           TM1650_Set(0x6A,CODE[timeb/10%10]);
                                           TM1650_Set(0x6C,CODE[timeb%10]);
                        else if(stat == 1)//最后倒計(jì)時(shí)完后顯示的內(nèi)容
                            timea=time1;
                                stat=0;
作者: yong761228    時(shí)間: 2019-7-17 12:13
初始化:uchar key,key_L,key_ok;
          TM1650_Set(0x48,0x11);//初始化數(shù)碼管
          TM1650_Set(0x68,CODE[0]);//初始化后要把顯存先寫數(shù)據(jù)就能顯示
          TM1650_Set(0x6A,CODE[0]);
          TM1650_Set(0x6C,CODE[0]);
          time1 = (IapReadByte(0)<<8)+IapReadByte(1);//讀eeproM中數(shù)據(jù),初始化時(shí)間初值
          time2 = (IapReadByte(0)<<8)+IapReadByte(2);//讀eeproM中數(shù)據(jù),初始化時(shí)間初值
          if(time1 >= 999)//如果時(shí)間值大于999則是第一次上電
             time1 = 000;//則為默認(rèn)值
                 time2 = 002;
         Timer0Init();//定時(shí)器初始化
         timea = time1;//初始化時(shí)間
         timeb = time2;
作者: yong761228    時(shí)間: 2019-7-18 13:48
有哪位師傅可以幫忙看看嗎?
作者: cjm82    時(shí)間: 2019-7-19 23:22
程序有點(diǎn)長(zhǎng),代碼得一行行看,挺費(fèi)腦筋的.這里只說(shuō)說(shuō)思路吧.
粗略看了下,你這程序大概是利用TM1650讀按鍵,根據(jù)輸入來(lái)決定具體操作,保存之類的.
既然程序存儲(chǔ)有問(wèn)題,而且是根據(jù)輸入的東西來(lái)決定保存,那么影響它不能保存的可能是輸入狀態(tài)的那部分代碼沒(méi)寫好導(dǎo)致保存的代碼沒(méi)有得到執(zhí)行,或者用于保存的那部分代碼沒(méi)寫好.你可以先另建個(gè)工程,寫個(gè)很簡(jiǎn)單的小程序.建立個(gè)兩個(gè)常量比如 0xa3和0xb4把他保存到FLASH的某個(gè)地址里,然后再?gòu)倪@個(gè)地址里讀出來(lái),假如讀出來(lái)的數(shù)字也是0XA3和0xb4,那么就點(diǎn)亮LED1,如果不是 就點(diǎn)亮LED2.這樣很容易驗(yàn)證你保存的代碼是否有誤.
用類似的辦法,也很容易驗(yàn)證輸入部分的代碼有無(wú)出錯(cuò)了.
兩者都調(diào)試完,整合一下就可以了.
或者會(huì)用單步調(diào)試的話,用單步調(diào)試也是不錯(cuò)的辦法.(51的單步調(diào)試以前學(xué)的時(shí)候沒(méi)怎么研究過(guò),現(xiàn)在也很少用51,所以懶得去研究了)
作者: yong761228    時(shí)間: 2019-7-20 06:14
cjm82 發(fā)表于 2019-7-19 23:22
粗略看了下,你這程序大概是利用TM1650讀按鍵,根 ...
非常感謝師傅,我昨晚已經(jīng)搞好了,就是根據(jù)您的類似方法,我先存儲(chǔ)1個(gè)時(shí)間,沒(méi)問(wèn)題了,再存儲(chǔ)第二個(gè)時(shí)間。
